Andrews AFB
by AirgunSavant
8 minutes 54 seconds ago
Luber Finer cut open
by Tech819
22 minutes 9 seconds ago
Meguiars wax
by whip
Today at 08:02 AM
Weird problem with laptop. Thoughts?
by d00df00d
Today at 07:42 AM
Silverado 6.2L Fram TG 3 years and ~45,000 miles
by DriveHard
Today at 07:15 AM
Old bike, new engine -synth or dino oil?
by mr_blackstock
Today at 06:56 AM
F1 - 2016 Austrian Grand Prix
by gofast182
Today at 06:16 AM
Toughest Minivan Transmission
by outoforder
Today at 06:06 AM
Castrol Power 1 Racing 2T
by Jetronic
Today at 05:57 AM
Idle Jitters No Codes
by Merkava_4
Today at 03:10 AM
Long commute, OCI and synthetic vs blend?
by rebelx
Today at 02:18 AM
good prepaid cell phone?
by Oldtom
Today at 12:42 AM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
81 registered (AirgunSavant, Alfred_B, ARCOgraphite, 123Saab, Atesz792, 2015_PSD, 7 invisible), 1617 Guests and 12 Spiders online.
58322 Members
66 Forums
251026 Topics
#3392693 - 06/09/14 04:44 AM Noisy lifters!
19jacobob93 Offline
Loc: Gold Coast, QL, Australia
The hydraulic lifters in my engine are starting to get very noisy! It started getting noticeable last year at around 130,000kms and I thought it was because I let Dino oil go to over 20,000kms before a change and I overheated it in that time (May have started it)
This past year or so I started changing my oil every 7,500kms with the odd change at 2,000 or so yet the lifters are louder than ever! I only use top brand 10w30/40 as recommended in the manual and written on the filler cap
Should I worry about the noise or will it cause no harm?
What are the long term effects of driving with rattly lifters?
Car: 2000 Ford Falcon AU2 - 4.0L SOHC I6 @247,000km
Oil: Valvoline Engine Armour 10W30 + LM MoS2 (7.5k OCI)
Fuel: 95 unleaded + TCW3
#3392740 - 06/09/14 06:54 AM Re: Noisy lifters! [Re: 19jacobob93]
Robenstein Offline
Loc: Central IA
I dont know how your valvetrain is set up, but the noise could be wear related(too much valve lash)or like you said it could be the lifters are getting sticky.
I have fixed a couple sticky lifters in a pushrod activated engine with Marvel Mystery Oil, but you may need to have the valve lash checked to fix the noise.
2011 Triumph Speedmaster
1986 Chevy Monte Carlo SS
1970 Chevy Nova
2006 Scion TC
#3392750 - 06/09/14 07:07 AM Re: Noisy lifters! [Re: 19jacobob93]
yvon_la Offline
Loc: quebec canada
How are valve train adjusted now a days?hydraulic like in the old days?could be lifter had very hot oil and cooked the oil in the lifter .wich would stick the lifter.or if oil too thick for engine was used .like honda recommend 0w20 so if you d use 5w40 it might be a problem.
Truck driver
Nissan versa note s 2014 Mobil Delvac 1 LE 5W-30 supertech st-6607(edition 2016) castrol transynd
#3392765 - 06/09/14 07:32 AM Re: Noisy lifters! [Re: 19jacobob93]
JHZR2 Offline
Loc: New Jersey
Could be many things. Id give b-12 chemtool a careful application and see how that does, as well as restore csl. These worked for me, it seems.
My advice on this topic though is that this can happen even on strong running, well maintained engines, and the gentler solvents can't necessarily do the job.
#3392780 - 06/09/14 07:56 AM Re: Noisy lifters! [Re: yvon_la]
19jacobob93 Offline
This seems the most likely, I ran the car for 20 minutes once with no coolant and the temp gauge was off the scale! These engines have a fail safe cooling sytem (fires on coolest cylinders) and a dual head gasket which means they can be run without coolant but I guess the oil can't withstand these temps even if the engine can.
Also I added a full bottle of Lucas additive shortly after this which gave me a cold start knock so I changed it.
Maybe both these took their toll on the lifters!
Also these are self adjusting hydraulic lifters
#3392855 - 06/09/14 09:07 AM Re: Noisy lifters! [Re: 19jacobob93]
ARCOgraphite Online   content
Loc: N.H, U.S.A.
In the old days Id say run some whale oil derived DEXRON or type F ATF for a while - buts its mineral oil now.
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#6 41243mi-M1EP 0W20+Subaru Filter
#3392873 - 06/09/14 09:25 AM Re: Noisy lifters! [Re: 19jacobob93]
4wheeldog Offline
Loc: East Mountains, NM
Those lifters are only self adjusting if they are in the range that gives them room to adjust. I'll bet there is a procedure in the workshop manual for initial setting. I would give that a shot, if I were you. Either that, or the lifters are collapsed, from the overheating.
Edited by 4wheeldog (06/09/14 09:26 AM)
#3392907 - 06/09/14 10:22 AM Re: Noisy lifters! [Re: 19jacobob93]
Clevy Offline
Loc: Saskatoon canada
Lucas?
Oh dude. That stuff is utter garbage.
It's nothing more than very thick non additized oil therefore all it does is thicken the oil in the sump and dilutes the oils additive package.
If you used that then overheated there is absolutely no doubt in my mind it's created deposits and could very well be restricting oil flow.
Nothing is better than tearing it down and cleaning it manually however if that's not an option then I suggest using an idle flush type product and following the instructions to the letter,then using a conventional oil 1 grade thicker than specified and substituting a quart of oil with either mmo or seafoam or whatever your can find locally and run shortish intervals,like 1500-2000 miles,and monitor the oil daily to see just how quickly it blackens.
If it's very fast you can assume there is a deposit problem,so from there you can assess just how many times you need to repeat the process.
Overheating the engine fried the oil in some spots creating deposits,and those cooked on deposits may not even clean up with a flush type product,it may require manual cleaning.
2006 Charger RT
Miles x 2 per oil filter
#3393453 - 06/09/14 08:58 PM Re: Noisy lifters! [Re: 19jacobob93]
asand1 Offline
Loc: Oregon coast
Flush or MMO. Could also be low oil pressure from worn main bearings. A mechanical test gauge would be a good idea.
Nissan/Infinity/Mazda Manuals
1996 Maxima 310K
1998 F250ld
#3393638 - 06/10/14 03:11 AM Re: Noisy lifters! [Re: 19jacobob93]
MileHigh18 Offline
Loc: TN
Lucas. Ugh.
2002 Trailblazer LT 119K
Pennzoil Platinum 5-30
#3393775 - 06/10/14 08:43 AM Re: Noisy lifters! [Re: JHZR2]
Doog Offline
Loc: North Coast
+1 The B12 will do it. Then do a rinse with cheap 15w40
The difference between a beer and your opinion is that I asked for a beer... well except for just now..:-)
