'91 Mazda B2600i transfer case and trans oil?
by Jason280
06/28/16 03:59 AM
How to cut power to breaker box ?
by Merkava_4
06/28/16 02:21 AM
Spark plugs in hi-per applications
by mjoekingz28
06/28/16 01:07 AM
OK, before I lube it ...
by BrocLuno
06/28/16 12:53 AM
Toyota Japan Fluid SDS
by SXE10
06/27/16 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
06/27/16 11:25 PM
Considering a differential swap
by buck91
06/27/16 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
06/27/16 09:51 PM
Car Acronyms
by Marco620
06/27/16 09:46 PM
Vibration with new tires - your thoughts
by Bandito440
06/27/16 09:41 PM
Carpet cleaning methods.
by Run
06/27/16 09:26 PM
Fram XG16 4522mi 5.7 Hemi
by AntsinmyEyes
06/27/16 09:26 PM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
39 registered (alarmguy, 2015_PSD, AZjeff, AirgunSavant, Bandito440, BeerCan, 4 invisible), 1063 Guests and 13 Spiders online.
58295 Members
66 Forums
250918 Topics
Page 1 of 2 1 2 >
#3393239 - 06/09/14 05:47 PM 2001 Jeep GC 4.0 with Rotella T6 5679 miles
Donald Offline
Loc: Upstate NY
The continuing saga of my reman 4.0 engine. The engine runs fine, decent mileage, no smoke.
Polaris flagged the lead as abnormal (orange) and the oxidation critical (red).
(first to last)
Html:
Test#	1	2	3	4	5
Mileage	9622	5184	5606	5334	5679
Iron 	146	43	26	28	55
Chrom 	4	1	1	1	1
Nickel	1	0	0	0	0
Alum 	4	1	1	1	2
Copper  23	12	16	20	24
Lead    15	8	4	3	47
Tin     2	1	1	1	2
Cadmi   0	0	0	0	0
Silv    0	0	0	0	0
Vanad   0	0	0	0	0
Silicon 25	12	13	8	12
Sodiu   18	6	6	9	15
Potas   6	1	5	0	0
Titan   0	1	0	0	0
Moly    61	58	67	62      61
Antim   1	0	0	1	0
Mang    2	0	0	0	0
Lith    0	0	0	0	0
Boron   280	163	30	21	23
Magn  	14	14	892	1041	1049
Calc  	3611	2651	1008	814	737
Bari   	0	0	0	0	0
Phos	772	723	868	942	921
Zinc  	923	864	1103	1189	1143
Fuel	<1	<1	2.2	2.0	<1
Soot	<.1	<.1	<.1	<.1	<.1
Water	<.1	<.1	<.1	<.1	<.1
[email protected]	11.1	10.2	12.9	13.3	13.5
TBN   	3.4	4.47	4.22	NES	4.13
Oxi    	20	25	17	NES	30
Nit     16	12	13	NES	14
Test#1 PU
Test#2 PU
Test#3 T6
Test#4 T6
Test#5 T6
Obviously the sharp jump in lead is a concern. Copper + lead = bearing failure.
Current change is PP (old formulation).
Edited by Donald (06/09/14 05:49 PM)
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3393253 - 06/09/14 06:01 PM Re: 2001 Jeep GC 4.0 with Rotella T6 5679 miles [Re: Donald]
actionstan Offline
Loc: Ohio
If its a reman, does it have a warranty? If so I might bring it up with the shop that did it/company that supplied the engine, just to see what they say. Those seem like high/inconsistent numbers, I would personally be a little worried.
1999 Saturn SL1
2013 KIA Forte
#3393259 - 06/09/14 06:06 PM Re: 2001 Jeep GC 4.0 with Rotella T6 5679 miles [Re: Donald]
NHGUY Offline
Loc: USA
Factory rebuilt? Marshall engine?
#3393260 - 06/09/14 06:07 PM Re: 2001 Jeep GC 4.0 with Rotella T6 5679 miles [Re: Donald]
Donald Offline
Loc: Upstate NY
The reman engine has almost 60K miles on it. Way past the warranty I was given.
Should I consider any action? Even if I knew which bearing was failing what would I do?
#3393280 - 06/09/14 06:26 PM Re: 2001 Jeep GC 4.0 with Rotella T6 5679 miles [Re: Donald]
Kuato Offline
Loc: In transit...
Tough question, what to do....T6 should be giving great wear but there's obviously something going on within the engine. You could always try replacing the bearings and see what happens.
Shot in the dark? I'd consider calling the reman company, and find out the specifications on the rebuild to insure they used the right sized bearings; if they were too thick, making the clearances too tight, then you might expect heavy wear, at least until they were back to "normal" clearances.
Your oil's condition is pure speculation until you get an UOA.
13 F150 5.0, 50k mi - Schaeffer 9000
04 Wrangler 2.4, 198k mi - Amsoil SS 5w30
#3393291 - 06/09/14 06:36 PM Re: 2001 Jeep GC 4.0 with Rotella T6 5679 miles [Re: Donald]
901Memphis Offline
Loc: Northern Kentucky
Switch to a 10w30 conventional like PYB and see that lead drop.
2002 Buick Century 125k - Built 4T65e(Maxlife) - Syn Frankenbrew + XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3393303 - 06/09/14 06:47 PM Re: 2001 Jeep GC 4.0 with Rotella T6 5679 miles [Re: Kuato]
actionstan Offline
Loc: Ohio
If the bearings go back to "normal clearances" wouldn't they at that point be worn, along with the crank, and highly scuffed? I think that would then cause quicker wear, and eventually knocking because loss of oil pressure. The bearing and crank surfaces need to remain smooth.. if clearances were too tight.. I don't think this would be possible.
1999 Saturn SL1
2013 KIA Forte
#3393389 - 06/09/14 08:02 PM Re: 2001 Jeep GC 4.0 with Rotella T6 5679 miles [Re: Donald]
Chris142 Offline
Loc: apple valley, ca
bump it up to 15w40.lets see what that does
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3393398 - 06/09/14 08:08 PM Re: 2001 Jeep GC 4.0 with Rotella T6 5679 miles [Re: Donald]
Eddie Offline
Loc: Florida, Cape Coral
Over reacting to one OCI. Check again after a 5-6K OCI.
CX5 Touring 2.5L :-)
#3393423 - 06/09/14 08:35 PM Re: 2001 Jeep GC 4.0 with Rotella T6 5679 miles [Re: 901Memphis]
Donald Offline
Loc: Upstate NY
This is the 3rd oil change with T6 and this is the first oil change where the lead really shot up.
#3393427 - 06/09/14 08:36 PM Re: 2001 Jeep GC 4.0 with Rotella T6 5679 miles [Re: Kuato]
Donald Offline
Loc: Upstate NY
This was a reman not a rebuild. They would have turned the crank and used the proper bearings for a machined crank.
#3393430 - 06/09/14 08:39 PM Re: 2001 Jeep GC 4.0 with Rotella T6 5679 miles [Re: Donald]
Donald Offline
Loc: Upstate NY
So if the bearings get loose don't they start squirting more oil on the cylinder walls than the oil rings can handle.
Maybe thats only the rod bearings and a main bearing has the problem.
#3393476 - 06/09/14 09:18 PM Re: 2001 Jeep GC 4.0 with Rotella T6 5679 miles [Re: NHGUY]
Donald Offline
Loc: Upstate NY
Yes a Marshall reman.
#3393741 - 06/10/14 08:01 AM Re: 2001 Jeep GC 4.0 with Rotella T6 5679 miles [Re: Donald]
dlundblad Offline
Loc: Midwest
Sorry to see you haven't gotten this issue straightened out Donald. Will the engine manufacturer do anything about this? 60,000 miles is such a shame.
I second the 15w40 trial run, but either way I don't think any oil will make much of a difference.
2003 Grand Cherokee 4.0 PYB 10w30/ TG16
2002 Volvo S60 2.4T M1 0w40/ Mahle ox149d
#3393754 - 06/10/14 08:13 AM Re: 2001 Jeep GC 4.0 with Rotella T6 5679 miles [Re: Donald]
Donald Offline
Loc: Upstate NY
So can one assume its just one bearing? How easy would it be to find that bearing? If its a rod or main bearing could just the bearing be replaced or could the crankshaft have an issue which would require machining.
Page 1 of 2 1 2 >
