Best spark plugs?
by jk_636
05/01/16 08:13 PM
Recoil, .380 versus .32?
by bobbob
05/01/16 07:47 PM
Winter + Slightly off concentration of glycol
by nobb
05/01/16 07:31 PM
Good synthetic oil for ford transit ecoboost?
by Jetstreamz06
05/01/16 07:26 PM
Reuse fram XG for 1 more O/C?
by gabriel9766
05/01/16 07:21 PM
Supertech in the Mid South
by tony58
05/01/16 07:06 PM
Smoke Machine Substitute?
by Ducked
05/01/16 06:45 PM
Gallon jugs of MMO $4 @ WM
by sw99
05/01/16 06:43 PM
55k air filter replacement w/ pictures
by Vern_in_IL
05/01/16 06:38 PM
old B52 movie...
by Tuffy1760
05/01/16 06:18 PM
ST 5w30 ok for 11' Impala 3.5 engine
by car51
05/01/16 05:37 PM
small air compressor greasing
by friendly_jacek
05/01/16 05:00 PM
Doxxy, Jetstreamz06, TalNum, Spinnizle, JustinL
57758 Registered Users
117 registered (andyd, 2015_PSD, Abakev, 15SilvyEcotec, 01rangerxl, 8 invisible), 1707 Guests and 320 Spiders online.
57758 Members
66 Forums
248327 Topics
Page 1 of 2 1 2 >
#3393223 - 06/09/14 05:21 PM MMO first timer. How many miles should I run?
gr8gatzby Offline
Loc: Charlotte, NC
Two weeks ago took possession of a '90 Volvo 740 Wagon(no cup holder version) via eBay. With 180k on the odo, the engine runs well, though it is, by golly, quite possibly the slowest car in history to have been exported from Sweden. No leaks of any kind. According to the instructions, 1qt of MMO should go into the crankcase. How many miles should I run it for a decent cleaning?
'95 Ford F150 | 4x4 | 5.8 | 13MPG
'96 Volvo 850 Wagon | I5 | 5SP | 24MPG
#3393234 - 06/09/14 05:40 PM Re: MMO first timer. How many miles should I run? [Re: gr8gatzby]
cknight49090 Offline
Loc: south haven mi
I would just use oil PYB. I wouldn't put that much MMO in the crankcase anyway.I used it a couple times I don't think it did much if anything JMPO.When I buy a used car I used to change the oil right away and dump it after 500 or 1000 miles but honestly I think it was a waste.You would be better off running it 2500 miles if it worries you.
#3393235 - 06/09/14 05:41 PM Re: MMO first timer. How many miles should I run? [Re: gr8gatzby]
Donald Offline
Loc: Upstate NY
I would get a MityVac 7201 and remove the MMO.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- 4-sale
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3393242 - 06/09/14 05:48 PM Re: MMO first timer. How many miles should I run? [Re: gr8gatzby]
dave5358 Offline
Loc: North Bend
Are there any indications that the previous owner did not change his oil regularly? If it ain't broke... just get the engine hot and drain the oil.
p.s. What engine do you have?
2006 Forester XT
2008 Corolla LE
#3393250 - 06/09/14 05:58 PM Re: MMO first timer. How many miles should I run? [Re: gr8gatzby]
demarpaint Offline
Loc: NY
If you determine it needs a cleaning run a pint for the last 1,500 miles of this OCI. During the cooler months or during the winter I like use MMO if I want to clean an engine. You get the benefit of easier cold weather starts. So when you do a cold weather OCI replace 1 qt of oil with 1 qt of MMO and run the full OCI. Don't exceed 20% MMO in the crankcase. Keep an eye on the oil level.
You can use the product any time of the year, winter has always been my preference though.
God Bless Our Troops
#3393263 - 06/09/14 06:09 PM Re: MMO first timer. How many miles should I run? [Re: demarpaint]
gr8gatzby Offline
Loc: Charlotte, NC
It's the 2.3L naturally aspirated four pot. Only 2.5k was on the current OCI, so I haven't yet changed the oil. ARX anyone?
#3393273 - 06/09/14 06:24 PM Re: MMO first timer. How many miles should I run? [Re: gr8gatzby]
Trajan Offline
Loc: SE PA
Just use oil. MMO hasn't changed its formula since 1923. While oil has improved far beyond that.
http://www.marvelmysteryoil.com/index.php/forums/viewthread/538/
"The original formula is still used today and has not been changed since it was first sold in metal cans. MMO also penetrates metal surfaces to prevent corrosion..."
So, just like Zmax, it penetrates metal.............. (Yeah, I once fell for the hype..... Never again on any oil additive.)
Edited by Trajan (06/09/14 06:24 PM)
Lack of harm is not proof of benefit.
There are in fact two things, science and opinion; the former begets knowledge, the later ignorance. Hippocrates
#3393295 - 06/09/14 06:40 PM Re: MMO first timer. How many miles should I run? [Re: Trajan]
JC1 Offline
Loc: Oshawa, Ontario Canada
I've used both Auto Rx and MMO. You can leave both in for 3000 miles. I doubt that they will do anything. As mentioned use some PYB and you should be ok. Did you open up the valve cover?
Regards, JC.
#3393315 - 06/09/14 06:55 PM Re: MMO first timer. How many miles should I run? [Re: gr8gatzby]
Mystic Offline
Loc: Colorado
The guy here who probably knows more about MMO than anybody else is demarpaint. He can give you the straight stuff. He has been using MMO for about 40 years.
Be sure no to exceed 25% MMO to oil. So if you have a 4 quart capacity you would not use more than 1 quart MMO replacing 1 quart of oil. If you have a 5 quart capacity 1 quart would be 20%, replacing 1 quart of oil.
Guys often use MMO in the wintertime because it thins the oil somewhat. If used in the summertime some guys say use a little thicker oil if possible (if allowed by manufacturer) to make up for the thinning of the oil.
It is probably best to check with demarpaint on how long to leave the MMO in there.
#3393346 - 06/09/14 07:21 PM Re: MMO first timer. How many miles should I run? [Re: gr8gatzby]
Oldmoparguy1 Online   content
Loc: Charlotte, NC
You want some ARX? I have a bottle left over you can have.
Wayne
"Reality is that which, when you stop believing in it, doesn't go away."
#3393387 - 06/09/14 08:01 PM Re: MMO first timer. How many miles should I run? [Re: gr8gatzby]
dave5358 Offline
Loc: North Bend
That engine is easy on oil. Barring some gross neglect or other unmentioned horror, an oil change should be adequate.
2006 Forester XT
2008 Corolla LE
#3393411 - 06/09/14 08:24 PM Re: MMO first timer. How many miles should I run? [Re: gr8gatzby]
andyd Online   content
Loc: Marshfield , MA
Use it as directed. Change the oil maybe after 3K miles. I use a pint when I thin out the 20w50 for winter. Mostly because the 528s are always a pint low.
MMO is like aspirin for engines. In fact, synthetic wintergreen,salicylate,is the stuff in liniment and analgesic balms.
I don't use it in my cars' fuel. I do in all my OPE. My mowers and blowers have less carb troubles since I started giving them a cap full every fill up
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3393424 - 06/09/14 08:35 PM Re: MMO first timer. How many miles should I run? [Re: Mystic]
Trajan Offline
Loc: SE PA
One could also read this thread: http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/1722878/4
#3393433 - 06/09/14 08:40 PM Re: MMO first timer. How many miles should I run? [Re: Oldmoparguy1]
Donald Offline
Loc: Upstate NY
Wayne
I'll take it.
#3393471 - 06/09/14 09:13 PM Re: MMO first timer. How many miles should I run? [Re: gr8gatzby]
toneydoc Offline
Loc: War Eagle
If the oil was changed 2500 miles ago, run it out to 3k miles and changethe oil and filter to your favorite combo and skip the MMO. Save the money and spend it on beer or high quality oil. Either will be better than the MMO
1994 Jeep 145k Castrol 0w40
2014 Camry 13k TGMO 0w20
2010 Sebring 39k Penn Plat 5w20
2014 HD Ultra 16k Valv20w50
2012 Toyota Rav4 21k Mobil 1 0w30AFE
#3393474 - 06/09/14 09:17 PM Re: MMO first timer. How many miles should I run? [Re: Trajan]
dave5358 Offline
Loc: North Bend
If anyone cares to get past THIS hype, you might check AVBLEND's website. This seems to be the same product as Z-Max, also known as Lenckite or Linkite. The product and it's originator has a rather interesting history . Avblend is FAA approved as an oil additive.
It's true that there was an FTC complaint against the Z-Max company some years ago, in part because of the 'soaks into metal' claim, but that case was settled with Z-Max being permitted to continue this specific advertising. Misstatements to the contrary, there was no fine. The 'cash settlement' in the FTC case... didn't happen. FTC simply required Z-Max to establish a fund for any purchaser prior to a certain date who wanted a refund. It's unclear if there were any takers.
Never again? Never again! It's good to see there's a learning curve. Back when Trajan 'fell for the hype', was that when you were in favor of Z-Max before you were against it? Or, against it before you were in favor of it?
Here is Trajan's earlier endorsement of Z-Max - fourth message from the top, although the whole thread is quite fascinating:
"Well, pilots I know love the stuff [Avblend] in their oil, and FAA approvals are not handed out like candy at Halloween.
http://www.avblend.com/faa/faa.html
Different name, but the same formula.
Found this in my net travel: http://www.rlb.50megs.com/oiladitives.html
I'm thinking that to market it to the car crowd, they came up with Zmax, as not many would put Avblend in a ground bound motor.
It's been FAA approved since 1980. And been around far longer. No flopping."
Trajan will have to explain the meaning of "flopping".
This thread is really interesting, both for the information and personalities involved. Read it to the humorous conclusion.
Back on the topic of MMO (that was the subject of this thread, right), MMO has a fair percentage of this same mineral oil in the mix, so a reader might conclude that the mineral oil in MMO might work like the mineral oil in Z-Max or Lenckite or Avblend (for which you-know-who is a bona-fide booster). Could that mean... ?
I'd better quit. I've reached my idiot-overload quotient for the evening.
2006 Forester XT
2008 Corolla LE
#3393495 - 06/09/14 09:37 PM Re: MMO first timer. How many miles should I run? [Re: gr8gatzby]
gr8gatzby Offline
Loc: Charlotte, NC
Wayne, I'm all in if you want to part with it.
#3393507 - 06/09/14 09:47 PM Re: MMO first timer. How many miles should I run? [Re: gr8gatzby]
Mystic Offline
Loc: Colorado
Again, if people would stay on topic it would help. This post is about a guy trying MMO and asking for advice about it. If somebody wants to start their own post on Auto-RX or whatever they should do so.
I don't think anybody can claim that I took this post off topic. The topic is MMO.
#3393518 - 06/09/14 09:54 PM Re: MMO first timer. How many miles should I run? [Re: Trajan]
demarpaint Offline
Loc: NY
The locked threads are the best, check out the Paid Posters thread too.
#3393526 - 06/09/14 10:00 PM Re: MMO first timer. How many miles should I run? [Re: demarpaint]
Mystic Offline
Loc: Colorado
Anybody who is reading, see for yourself what guys at this website take posts off topic and try to discredit anybody who talks in a favorable way about some product they do not like or some product that competes with whatever product they believe in. Anybody who can read can check this post out and see for themselves.
A guy asked for simple information about MMO. He is trying MMO. Is it possible for people who know about MMO to help this guy without all of this nonsense? Since the guy was already trying MMO, he deserves help with the product. Is that fair?
#3393911 - 06/10/14 11:33 AM Re: MMO first timer. How many miles should I run? [Re: gr8gatzby]
KCJeep Online   content
Loc: Mahzurrah!
I like MMO and it does work, albeit slowly which is a good thing anyway. I'd rather slowly dissolve crud than break chunks loose.
I have used it off and on in my crudded up Jeep and it does indeed clean and usually makes the engine quieter as well.
MMO doesn't recommend it's use for OCI's longer than 3k, but many have run it longer than that without issue.
2004 Jeep Grand 4.0 @ 132k Pennzoil HM 5w30 w/ 1 qt 10w40
Fram TG8A
KIA Sedona 57k, Ford Focus 114k, Chrysler Sebring 184k, Chrysler Concorde 115k
#3394202 - 06/10/14 06:22 PM Re: MMO first timer. How many miles should I run? [Re: gr8gatzby]
901Memphis Offline
Loc: Northern Kentucky
I don't think naphthenic solvents like MMO are necessary, just use quality high detergent API SL+ oils and keep an eye on how the filters are handlingthe oci if you can cut them open.
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3394339 - 06/10/14 08:49 PM Re: MMO first timer. How many miles should I run? [Re: 901Memphis]
IGotYourBack Offline
Loc: Kentucky. The Bluegrass State
I've used MMO enough outside of automotive use to know it does break loose mild grease and dirt, thereby a mild cleaner. Very good at preventing outside oxidization on carburetors I have sitting for months at a time for customers as well.
I used this in my slant 6 when I first purchased. I poured half a quart in at the beginning of change, and the rest during the last 100 miles of solid driving.
I drained as soon as I came home. Followed with 10w-40 from then on.
I occasionally use this in my gas tank, I cannot verify the cleaning abilities for the valves myself, but my engineering instructor got me using the stuff.
He is a pilot and said they go through engines on a regular basis, and the pilots running MMO have much less carbon and deposits. Does this help the life? You be the judge.
Another use I like is for vehicles (carbureted) that have sat months/years at a time, is a plastic water bottle filled with gasoline, add a cap full of 2 stroke oil and 2 caps of MMO. Fill the carburetor bowl with the mixture. Helps lubricate the top end which is guaranteed to be bone dry otherwise.
1986 Dodge D100, Slant 6 (Current Daily Driver)
-- Formula Shell 10W40 --
-- STP S3600 --
'77 Ford Maverick, 2 door
'77 Ford Maverick, 4 door
Page 1 of 2 1 2 >
