Painting rear of chrome bumpers
by buck91
08/26/16 11:09 PM
Walmart Rifle Clearance
by hatt
08/26/16 10:44 PM
Vehicles That Must Idle For Long Periods Of Time
by BlueOvalFitter
08/26/16 10:30 PM
2013 Taurus SHO Ecoboost
by SHO
08/26/16 10:11 PM
Need recommendation
by double vanos
08/26/16 10:00 PM
Kawasaki must be completely full of gas to start
by jrcowboys
08/26/16 09:36 PM
Un-Screwing
by Ducked
08/26/16 09:05 PM
BG 109 vs 120, any techs experienced w/ both?
by dccode
08/26/16 08:24 PM
Harder on engine, idling or restart?
by mattri
08/26/16 08:20 PM
Solvent/cleaner + 2 stroke oil for piston soak
by OldEuroCarLover
08/26/16 08:09 PM
Costco Canada Michelin wiper blades $9.99
by JC1
08/26/16 06:47 PM
Havoline Car Giveaway
by SatinSilver
08/26/16 06:47 PM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
68 registered (andrewp1998, 2004tdigls, AZjeff, ammolab, Americana, AirgunSavant, 4 invisible), 1066 Guests and 31 Spiders online.
58935 Members
66 Forums
253605 Topics
#3392436 - 06/08/14 07:07 PM wont start
BuckShirley Offline
Loc: N.Y
Hello , yesterday i added a bottle of techron injector cleaner and got gas at a different station than usual and today my 09 silverado wont fire ,just turns over ,
im thinking its fuel pump or pressure regulator (checked fuses)
does this seem odd without acting up at all prior to today ,its been running fine
"Back in 82, I could throw a pigskin a quarter mile"
-Uncle Rico-
#3392450 - 06/08/14 07:15 PM Re: wont start [Re: BuckShirley]
Eddie Offline
Loc: Florida, Cape Coral
Did it run fine when you shut it down? If so, I doubt it was the fuel. Something else is most probably the problem. Can you hear the fuel pump running? There is also a fuel pump relay. You may be able to switch relays to see if it is the pump or the rely. Ed
CX5 Touring 2.5L :-)
#3392462 - 06/08/14 07:22 PM Re: wont start [Re: BuckShirley]
yonyon Offline
Loc: NJ, USA
Unfortunately, things do break.
When it's the fuel pump going bad sometimes it makes the driver feel a need to fill up the gas tank. The pump knows it got to you so then when you go to start the truck it won't start. Sometimes they'll be nice and work one more time so you can get home.
When the key is first switched from off to on the pump should run for two seconds and make a humming noise that you can hear while listening closely at the gas tank. Get someone else to turn the key for you because you won't be able to get from the driver's seat to the gas tank in 2 seconds. If you hear the pump run, then you have other things to check.
If you don't hear a hum the pump isn't spinning. Try banging the gas tank at bottom center with a large hammer while someone else tries to start it. The noise will sometimes scare the pump and it will start to work. If it does that, you've caught it! Time for a new pump! If the pump holds its composure and remains silent then you need to check the electricals before condemning the pump.
#3392469 - 06/08/14 07:30 PM Re: wont start [Re: BuckShirley]
BuckShirley Offline
Loc: N.Y
It ran fine before and after i got the gas , it acted up today when i went to start it ,no prior symptoms ,
I have to check again about the pump turning on
-Uncle Rico-
#3392479 - 06/08/14 07:41 PM Re: wont start [Re: BuckShirley]
Trav Offline
Loc: MA, Mittelfranken.de
Check for water in the fuel, it wouldn't be the first time.
With ethanol in the fuel its not as cut and dry as it was with regular gas where the water went instantly to the bottom and killed the engine.
Edited by Trav (06/08/14 07:45 PM)
#3392491 - 06/08/14 07:55 PM Re: wont start [Re: BuckShirley]
BuckShirley Offline
Loc: N.Y
Im not hearing fuel pump charge up , its looking expensive already
-Uncle Rico-
#3392513 - 06/08/14 08:28 PM Re: wont start [Re: BuckShirley]
Warstud Offline
Loc: MIchigan
Try spraying some starting fluid into the throttle body and cranking it over.
#3392515 - 06/08/14 08:33 PM Re: wont start [Re: Warstud]
BuckShirley Offline
Loc: N.Y
I will get some tomorrow !
-Uncle Rico-
#3392524 - 06/08/14 08:42 PM Re: wont start [Re: BuckShirley]
Eddie Offline
As I said before, check the pump relay before going crazy blaming the pump.
#3392544 - 06/08/14 09:03 PM Re: wont start [Re: Eddie]
BuckShirley Offline
Loc: N.Y
it doesnt have one, It has a fuel pump control module
-Uncle Rico-
#3392547 - 06/08/14 09:07 PM Re: wont start [Re: BuckShirley]
toneydoc Offline
Loc: War Eagle
Could be a clogged up fuel filter has happened to me before
1994 Jeep 147k Castrol 0w40
2014 Camry 16k TGMO 0w20
2010 Sebring 40k Valvoline 5w30
2014 HD Ultra 19k Valv20w50
2012 Toyota Rav4 24k Mobil 1 0w30AFE
#3392596 - 06/08/14 10:02 PM Re: wont start [Re: BuckShirley]
Chris142 Offline
Loc: apple valley, ca
bang on the tank with a rubber hammer
02 Wrangler Chevron 10w30
87 F250 napa 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3394101 - 06/10/14 03:35 PM Re: wont start [Re: BuckShirley]
BuckShirley Offline
Loc: N.Y
It was the FPCM , got it back today 1
-Uncle Rico-
#3394207 - 06/10/14 06:28 PM Re: wont start [Re: BuckShirley]
yonyon Offline
Loc: NJ, USA
Good news. How much did it run you?
#3394990 - 06/11/14 05:15 PM Re: wont start [Re: BuckShirley]
BuckShirley Offline
Loc: N.Y
Luckily it was covered under the certified warranty!
-Uncle Rico-
