Oil change recomendations for '11 Ranger 2.3 Liter
by ryan2022
33 minutes 14 seconds ago
Suggestions for 94 Lexus LS400 ATF
by Gasbuggy
58 minutes 44 seconds ago
GOST Diesel fueln
by m37charlie
Today at 11:10 AM
Old interesting finds
by car51
Today at 10:53 AM
Filling nail holes in drywall
by Drew99GT
Today at 10:47 AM
1987 ford 460 motorhome, which oil to use?
by digler
Today at 10:30 AM
My ride in a B-17
by cb4017
Today at 10:28 AM
Speaking of missing members
by Oldmoparguy1
Today at 10:10 AM
Wiper blades $3.88 at Home Depot
by Jimmy9190
Today at 09:57 AM
Verizon
by AirgunSavant
Today at 09:28 AM
Any body tried somthing like this?
by Shellman
Today at 09:27 AM
Who's running Castrol Magnatec 5W-30 ?
by Merkava_4
Today at 09:23 AM
paul2005tb, Martyaus, carmelo, Shellman, SSO
58272 Registered Users
77 registered (AirgunSavant, AZjeff, abycat, Astro14, AlienBug, 6 invisible), 2036 Guests and 15 Spiders online.
58272 Members
66 Forums
250836 Topics
#3392149 - 06/08/14 12:06 PM What grease for EPS steering gears?
Scout1 Offline
Loc: Seattle WA
I have the common "sticky steering" problem on my 2003 BMW Z4. BMW refuses to recall these so instead of replacing the steering column for $3k, there appears to be a fix where some lubricant is squirted into the gearbox. This fix involves drilling a new hole so that can be done so it's not for the faint of heart.
I'm trying to figure out what grease would be best. I've read on the Bimmer Forums that folks have had success but there doesn't appear to be a consensus on the type of lubricant that should be injected. Some use standard grease (I assume Moly) others use silicon gun oil. The gears are some sort of plastic or nylon and BMW seems to use a urea grease on the newer models.
Reading on the WEB I figure I would want to use a synthetic PAO or silicon based grease without moly or EP additives. Anyone have any advice? What's urea grease all about?
Edited by Scout1 (06/08/14 12:07 PM)
Scout1
Truth will always bear up against falsehood, as oil does above water
#3392328 - 06/08/14 04:33 PM Re: What grease for EPS steering gears? [Re: Scout1]
123Saab Offline
Loc: PA
Twenty-twenty-twenty four hours to go I wanna be sedated
Nothin' to do and no where to go-o-oh I wanna be sedated
#3392477 - 06/08/14 07:37 PM Re: What grease for EPS steering gears? [Re: 123Saab]
Scout1 Offline
Loc: Seattle WA
Thanks for the link! So the polyurea greases are mostly for high temp applications and it's a thickener basically. Not really a consideration for my fix I figure. Reading more about these urea greases it sounds like they are mostly for lubed forever applications and if succesful, I'll have a zerk fitting on my gearbox I can shoot more in if I need to...
Scout1
#3422601 - 07/12/14 12:10 PM Re: What grease for EPS steering gears? [Re: Scout1]
Scout1 Offline
Loc: Seattle WA
Thought I'd give a follow-up. I went ahead and installed the zerk fitting and pumped in some Valvoline Cerulean grease. Seems to work fine and has fixed the problem to a certain extent. I don't think any lubricant can totally fix a binding condition, which I'm fairly certain this is, but the steering feel on my Z4 has improved considerably with the grease in there.
Why the Cerulean? I learned that lithium complex greases are the most widely compatible so I went conservative. Cerulean isn't synthetic and doesn't have a lot of exotic additives so it's pretty basic mineral oil grease. Seems to help a lot with my problem.
Scout1
