0W20 in the Ranger?
by iambretto
07/27/16 10:11 AM
Sears/Kmart DieHard Gold 40R on sale 50% off
by slacktide_bitog
07/27/16 10:11 AM
Motorcycle tire repair out on the road, best kit?
by LoneRanger
07/27/16 10:11 AM
Weedeater air filter oil???
by Drew99GT
07/27/16 10:08 AM
Brand Comparison between 5w-40 vs. 15w-40
by mbacfp
07/27/16 10:07 AM
Friend only wants to do what he wants?
by motor_oil_madman
07/27/16 09:58 AM
LC9/LC9S Slide Wear
by Hokiefyd
07/27/16 09:51 AM
MaxLife ATF use where ford Mercon V call for ?
by MetalSlug
07/27/16 08:41 AM
Your FINAL though on Quaker State oil line
by MetalSlug
07/27/16 07:45 AM
Amsoil SS 5w30, 10K, 04 Chevy Tahoe, 206K
by dhellman12
07/27/16 07:30 AM
2004 Chevy 2500HD, 60k Amsoil ATF, 194K
by dhellman12
07/27/16 07:17 AM
The History of Snake Oil
by Char Baby
07/27/16 07:16 AM
uicgrad, snydercn, surfbum, Tmemz4, woollum86
58613 Registered Users
73 registered (bulwnkl, bds1984, Anduril, BeerCan, Andrei, AirgunSavant, 6 invisible), 1838 Guests and 13 Spiders online.
58613 Members
66 Forums
252308 Topics
#3392436 - 06/08/14 07:07 PM wont start
BuckShirley Offline
Loc: N.Y
Hello , yesterday i added a bottle of techron injector cleaner and got gas at a different station than usual and today my 09 silverado wont fire ,just turns over ,
im thinking its fuel pump or pressure regulator (checked fuses)
does this seem odd without acting up at all prior to today ,its been running fine
"Back in 82, I could throw a pigskin a quarter mile"
-Uncle Rico-
#3392450 - 06/08/14 07:15 PM Re: wont start [Re: BuckShirley]
Eddie Offline
Loc: Florida, Cape Coral
Did it run fine when you shut it down? If so, I doubt it was the fuel. Something else is most probably the problem. Can you hear the fuel pump running? There is also a fuel pump relay. You may be able to switch relays to see if it is the pump or the rely. Ed
CX5 Touring 2.5L :-)
#3392462 - 06/08/14 07:22 PM Re: wont start [Re: BuckShirley]
yonyon Offline
Loc: NJ, USA
Unfortunately, things do break.
When it's the fuel pump going bad sometimes it makes the driver feel a need to fill up the gas tank. The pump knows it got to you so then when you go to start the truck it won't start. Sometimes they'll be nice and work one more time so you can get home.
When the key is first switched from off to on the pump should run for two seconds and make a humming noise that you can hear while listening closely at the gas tank. Get someone else to turn the key for you because you won't be able to get from the driver's seat to the gas tank in 2 seconds. If you hear the pump run, then you have other things to check.
If you don't hear a hum the pump isn't spinning. Try banging the gas tank at bottom center with a large hammer while someone else tries to start it. The noise will sometimes scare the pump and it will start to work. If it does that, you've caught it! Time for a new pump! If the pump holds its composure and remains silent then you need to check the electricals before condemning the pump.
#3392469 - 06/08/14 07:30 PM Re: wont start [Re: BuckShirley]
BuckShirley Offline
Loc: N.Y
It ran fine before and after i got the gas , it acted up today when i went to start it ,no prior symptoms ,
I have to check again about the pump turning on
-Uncle Rico-
#3392479 - 06/08/14 07:41 PM Re: wont start [Re: BuckShirley]
Trav Offline
Loc: MA, Mittelfranken.de
Check for water in the fuel, it wouldn't be the first time.
With ethanol in the fuel its not as cut and dry as it was with regular gas where the water went instantly to the bottom and killed the engine.
Edited by Trav (06/08/14 07:45 PM)
#3392491 - 06/08/14 07:55 PM Re: wont start [Re: BuckShirley]
BuckShirley Offline
Loc: N.Y
Im not hearing fuel pump charge up , its looking expensive already
-Uncle Rico-
#3392513 - 06/08/14 08:28 PM Re: wont start [Re: BuckShirley]
Warstud Offline
Loc: MIchigan
Try spraying some starting fluid into the throttle body and cranking it over.
#3392515 - 06/08/14 08:33 PM Re: wont start [Re: Warstud]
BuckShirley Offline
Loc: N.Y
I will get some tomorrow !
-Uncle Rico-
#3392524 - 06/08/14 08:42 PM Re: wont start [Re: BuckShirley]
Eddie Offline
As I said before, check the pump relay before going crazy blaming the pump.
#3392544 - 06/08/14 09:03 PM Re: wont start [Re: Eddie]
BuckShirley Offline
Loc: N.Y
it doesnt have one, It has a fuel pump control module
-Uncle Rico-
#3392547 - 06/08/14 09:07 PM Re: wont start [Re: BuckShirley]
toneydoc Offline
Loc: War Eagle
Could be a clogged up fuel filter has happened to me before
1994 Jeep 146k Castrol 0w40
2014 Camry 15k TGMO 0w20
2010 Sebring 40k Valvoline 5w30
2014 HD Ultra 18k Valv20w50
2012 Toyota Rav4 22k Mobil 1 0w30AFE
#3392596 - 06/08/14 10:02 PM Re: wont start [Re: BuckShirley]
Chris142 Offline
Loc: apple valley, ca
bang on the tank with a rubber hammer
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3394101 - 06/10/14 03:35 PM Re: wont start [Re: BuckShirley]
BuckShirley Offline
Loc: N.Y
It was the FPCM , got it back today 1
-Uncle Rico-
#3394207 - 06/10/14 06:28 PM Re: wont start [Re: BuckShirley]
yonyon Offline
Loc: NJ, USA
Good news. How much did it run you?
#3394990 - 06/11/14 05:15 PM Re: wont start [Re: BuckShirley]
BuckShirley Offline
Loc: N.Y
Luckily it was covered under the certified warranty!
-Uncle Rico-
