AC vs. Evaporative Cooler.
by 3for3
33 minutes 37 seconds ago
Rock auto wix specials
by HankMcMauser
Today at 04:03 PM
Hunk of junk air filter
by rickmeseke
Today at 03:41 PM
MicroGreen filter at 8,114 miles
by Rex
Today at 02:33 PM
Opinions on this 2006 Lincoln
by Milkman
Today at 01:40 PM
I'm sure these have been posted before but...
by Yup
Today at 01:24 PM
Weedeater nylon string cartridge doesn't feed out
by 69GTX
Today at 01:23 PM
Larger Oil Filter for 2006 Highlander 2.4 Four Cyl
by Samzone
Today at 01:01 PM
I bought a Stihl weed trimmer, but...
by skyactiv
Today at 01:01 PM
2010 Tacoma oil selection help
by bchannell
Today at 12:52 PM
Will this "Universal" coolant work on my Car?
by Miller88
Today at 11:37 AM
Repelling heat
by mjoekingz28
Today at 11:27 AM
hokieag07, Welder_Repairman, saredX, Corraun, kevinstoyhauler
58023 Registered Users
86 registered (2015_PSD, 04SE, 60ampfuse, ag_ghost, 69GTX, 3for3, 6 invisible), 1702 Guests and 330 Spiders online.
58023 Members
66 Forums
249603 Topics
Page 5 of 5 < 1 2 3 4 5
#3390524 - 06/06/14 09:54 AM Re: Pinging goes away after vacuum adv disc - why? [Re: wag123]
threeputtpar Offline
Loc: Appleton, WI
Originally Posted By: wag123
Originally Posted By: sasilverbullet
I just ordered a adjustable vacuum advance and some springs for the mechanical advance. Stay tuned...
Now, you need to bum an adjustable advance timing light from someone. If you don't know anybody that has one, buy one for $55 or so off Amazon. You don't need to buy an expensive one because you won't be getting very much use out of it. Make sure you buy one with the adjustable advance, don't cheap out! You don't need one with a digital adjuster, the dial type is fine, that is what I have and I actually prefer the dial.
http://www.amazon.com/Actron-CP7528-Advance-Timing-Light/dp/B000BSWEHS/
wag123, the OP is also in TX. You should see if you're close and offer to lend a tool or a hand.
2013 Honda Odyssey Touring Elite - M1 5W-20 / M1-101 40k miles
2008 Ford Taurus X - Resolute 5W-20 / MC FL-400S 128k miles
#3390755 - 06/06/14 02:33 PM Re: Pinging goes away after vacuum adv disc - why? [Re: threeputtpar]
sasilverbullet Offline
Loc: San Antonio, Tx
Originally Posted By: threeputtpar
...wag123, the OP is also in TX. You should see if you're close and offer to lend a tool or a hand.
LOL Texas is a BIG state! But I'm just north of San Antonio in Bulverde.
14 Honda Civic 4dr EX-L - Mobil 1 Ext Perf 0W-20 & M1 Filter
14 Honda Accord 4dr EX-L 4cyl - Mobil 1 Ext Perf 0W-20 & M1 Filter
#3391005 - 06/06/14 07:42 PM Re: Pinging goes away after vacuum adv disc - why? [Re: sasilverbullet]
Gokhan Offline
Loc: Los Angeles, California
A tachometer / timing light is a must-have for all DIYers with adjustable idle speed and ignition timing. I would definitely have my own.
1985 Toyota Corolla LE, 4A-LC engine, ~ 263,000 M
Mobil 1 (M1) 0W-40 SN synthetic
Toyota 90915-YZZF2 filter, 90430-12031 drain gasket
#3391068 - 06/06/14 08:55 PM Re: Pinging goes away after vacuum adv disc - why? [Re: Gokhan]
artificialist Offline
Loc: Florida
Originally Posted By: Gokhan
I wonder why they wouldn't make some electronic aftermarket distributors. They would be far more reliable and cheaper than the early-20th-century mechanical-distributor technology.
MSD makes a computerized distributor for such old cars. There were some screws you would turn that would change advance by RPM, and vacuum advance had similar adjustments. Instead of a vacuum actuator, the special distributor used a MAP sensor.
I looked online for one that fits a Ford 460, but I didn't see one. I have seen them on more common V8 engines like the Chevy 350 and Ford 302.
2010 Lancer Ralliart Sportback
#3392413 - 06/08/14 06:36 PM Re: Pinging goes away after vacuum adv disc - why? [Re: sasilverbullet]
WooHoo!!! Cheers2
Thanks everyone for helping me conquer this problem! I ordered a Crane Cams adjustable vacuum advance, followed what you guys said, and the directions in the box.
With no vacuum advance I had to adjust the initial timing from 10 to 8 to get all the pinging out.
Then I connected up the vacuum advance and adjusted it until the pinging went away.
Fyi, I had to do a LOT of bending to the arm on the vacuum advance.
Thanks again everyone! USA
Edited by sasilverbullet (06/08/14 06:36 PM)
