Stuck ring?
by TurboFiat124
5 minutes 1 second ago
Protectant 303 vs. Wax on fiberglass surfaces
by mbacfp
Today at 03:17 PM
Jeep brakes
by buck91
Today at 03:10 PM
Any thoughts on the Hersheys attempted buyout?
by Vern_in_IL
Today at 02:55 PM
2009 Miata Race Car, M1 5w20
by 09_GXP
Today at 02:48 PM
FRAM TG3600 Cut Open
by HX520W
Today at 02:30 PM
Audi Q3 factory filter CUT OPEN
by car51
Today at 02:29 PM
MC FL910S CUT OPEN
by car51
Today at 02:04 PM
Any here storage your old License Plate
by MetalSlug
Today at 01:20 PM
Is the VCM on honda accord V6's a problem area?
by Tlhfirelion
Today at 01:09 PM
Biker gets instant revenge on car that cut him off
by John_Conrad
Today at 01:04 PM
Another W-10 saga
by Oldmoparguy1
Today at 01:02 PM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
93 registered (1BADDMAX, andyd, 01rangerxl, 87sammy, 09_GXP, 13 invisible), 1930 Guests and 10 Spiders online.
58322 Members
66 Forums
251046 Topics
#3392205 - 06/08/14 01:51 PM Radiator pressure
justinf89 Offline
Loc: Hampton, VA
I've been doing maintenance on a buddys '07 explorer with the v6. I went to check the radiator and it had a lot of pressure after loosening the cap. This was after it sat overnight. I changed to coolant so I've been trying to purge the air, but it won't draw from the expansion tank.
Sound like a new cap is in order? Why wouldn't the pressure equalize overnight?
97 Explorer 4.0L SOHC - 155k - ML 5w-30/PL30001
04 Safari 4.3L - 235k - ML 5w-30/L24011
05 Silverado 6.6L DMX - 135k - Ams AME/EAO52
#3392212 - 06/08/14 01:56 PM Re: Radiator pressure [Re: justinf89]
OneEyeJack Offline
Loc: S California
Compare it with one of your cars.
#3392236 - 06/08/14 02:14 PM Re: Radiator pressure [Re: justinf89]
Chris142 Offline
Loc: apple valley, ca
Is the radiator full?
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3392247 - 06/08/14 02:32 PM Re: Radiator pressure [Re: justinf89]
Warstud Offline
Loc: MIchigan
Make sure the air is purged from the cooling system before you suspect somethings wrong with the Rad Cap. Try jacking up the front end and running it with the cap off.
FYI: On a cold motor the Rad should be full and the expansion tank should be at the Cold mark. When the motor gets up to temperature the expansion tank should read Hot. When you shut the motor off the Rad should draw coolant from the expansion tank
until it fills up and the expansion tank should read Cold again.
#3393461 - 06/09/14 09:02 PM Re: Radiator pressure [Re: Warstud]
asand1 Offline
Loc: Oregon coast
This will only happen when the cap is not plugged
Nissan/Infinity/Mazda Manuals
1996 Maxima 310K
1998 F250ld
