My $250 Saturn climbed Mt Washington
by eljefino
07/24/16 03:07 PM
Coolant change issue
by renegade_987
07/24/16 03:05 PM
Shell X100 30/40?
by FordCapriDriver
07/24/16 02:59 PM
Do you reuse ring gear bolts?
by buck91
07/24/16 02:54 PM
Wonder if anyone with NASCAR has noticed...
by mrsilv04
07/24/16 02:42 PM
Brake Pad Anti Rattle Clips
by Miller88
07/24/16 02:02 PM
Video: Napa Proselect 21334 cut open
by cronk
07/24/16 01:12 PM
what viscosity on a new build? 351W/408 street
by tomcat27
07/24/16 12:14 PM
What is this plant?
by skyactiv
07/24/16 11:16 AM
Recycling
by mjoekingz28
07/24/16 10:30 AM
Craftsman Action Bypass Lopper ~$11.70
by Sayjac
07/24/16 09:51 AM
2017 Fusion Hybrid
by AirgunSavant
07/24/16 09:50 AM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
80 registered (Abdulla, 09_GXP, bdcardinal, AandPDan, bbhero, barkingspider, 8 invisible), 2005 Guests and 9 Spiders online.
58578 Members
66 Forums
252193 Topics
Page 2 of 3 < 1 2 3 >
#3392093 - 06/08/14 10:39 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
Trav Offline
Loc: MA, Mittelfranken.de
I don't think its anything to do with the ABS, IIRC there is no mechanical check of the system that would be audible just an electronic check which is complete when the ABS light goes off.
AIR pumps can make a lot of noise when worn and it is located on the driver side under the side of the front bumper.
The only cars i can remember that made hydraulic cycling noises was the Citroen's, the old DS, CX and SM cars especially were an orchestra of knocks, clicks and double clicks but nothing like that on US cars.
Testing the AIR pump is easy enough just jump the relay, also check any solenoids in the system as they can make noise also.
I don't want to send you down a path with this thought, its a way off guess looking for the obscure nothing more.
You need a second person, start the car cold with the hood open let it run a min or two while you listen then have someone put it in drive and hold the brake (e brake on) and keep listening for a few min.
I cant thing of anything that would give three distinct knocks in this engine internally then stop but externally mounted solenoids and other parts could, it could also be in the transmission but that would be remote.
Next time your at the red light where is usually does this put it in neutral and see if there is any difference.
Diagnosing something like this is a difficult enough when you have the car in front of you on a message board its darn near impossible except for endless guessing.
I think the ARX is just a coincidence unless it was a lifter or something but that shouod be a noise easy enough to identify.
#3395293 - 06/12/14 12:58 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
npfd Offline
Loc: Canada
Thank you very much again Trav,
I will have to look into testing out the air pump, as for someone to listen in on the issues will be hard...
I tried it in neutral while waiting at the light, same knock.. actually now I notice that he first knock sounds a little different than the next two which are identical to each other.
Sure, rods, or worn valves can't make this sound...
Tongiht was louder, cause the temp was 15 degrees celsius.... with it 25+ knock is much fainter and quicker sounding...
hehe yes diagnosing via forum is hard...
Thank you again
#3395310 - 06/12/14 02:34 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
MDettling Offline
Loc: Oregon
A/C compressor? Just a shot in the dark.
#3400227 - 06/17/14 11:38 PM Re: three knocks heard at idle after sitting overnight [Re: npfd]
npfd Offline
Loc: Canada
Thank you for the reply... I had the A/C refilled a tad due to it not working as well..... and I did see some spray marks around it this passed spring....
I did try with the AC engaged, and still heard the knocks....
I will have to look into things a bit more.. thanks... would it be a rod?
#3400235 - 06/17/14 11:57 PM Re: three knocks heard at idle after sitting overnight [Re: npfd]
Clevy Offline
Loc: Saskatoon canada
Could it be the knock sensor testing the fuel octane by advancing timing til knock is audible then retarding it?
I'm thinking the engine has significant carbon accumulation in the combustion chambers which is raising compression,so at start up when the ecu isn't reading the o2 sensors the stock timing is too much so once knock is heard timing is adjusted?
Just throwing out ideas.
2006 Charger RT
Miles x 2 per oil filter
#3401916 - 06/20/14 12:03 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
npfd Offline
Loc: Canada
Thank you Clevy for the input....
Could be a possibility just not sure on how to go about testing the knock sensor...
I thought it could be the combustion chamber.. ran BG 44k, once, and the oil level dropped, ran lucas upper lube, and ran the Techron 2 times so far, might do a third soon...
I did read online of a Red Line, additive.. how would that be?
Thank you
#3401930 - 06/20/14 12:46 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
Clevy Offline
Thank you
Look at the mds of the products your interested in. There is a product called "guaranteed to pass" with 25-35% amines,so if the redline or techron branded stuff is less concentrated I'd try to find gtp instead.
Or double dose weaker stuff.
For significant build up 1 tank won't be enough and I'd even consider a piston soak via a vacuum line with mmo or something.
Again,just ideas,
2006 Charger RT
#3441232 - 07/31/14 12:07 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
npfd Offline
Loc: Canada
another not so good update, after about 1.5 months i had to add oil from one bar to 4....
After we had some rain, then washed the car, noticable oil spots on the driveway, rear part of engine..
When it rained, had the car nosed in, washed, car reversed in...
Since we got the car I've noticed it being 'wet' around the oil filter adaptor, in recent times, about a year, valve covers, bottom sides of engine a bit...
I notice more oil 'usage' in summer than in winter... pcv was changed in 2012 January... maybe try changing to another one..
Whenever I added the techron, I noticed a different smell on startup, as approaching the car...
thanks
#3441326 - 07/31/14 06:24 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
moklock Offline
Loc: FL
Sounds exactly like the noisy vent valve Saturn VUEs commonly did, but that part is at the rear of the vehicle. Same scenario though, drive off in cooler weather come to a first stop- three knocks. The vent valve circuit being tested. Its supposed to be silent but the valves get noisy after awhile.
Could be some other solenoid underhood like the purge doing the same thing.
#3498402 - 09/30/14 10:55 PM Re: three knocks heard at idle after sitting overnight [Re: npfd]
npfd Offline
Loc: Canada
Thank you Moklock,
I noticed a few weeks ago, I heard the first know then got on the gas to accelerate and didn't hear the rest.
I could be making things up, but its not the first time I've had my head, turned left, and heard the knock from the back of the car.
Unless its the solenoid getting stuck?
The exhaust smells on startup, even reversing into the cloud of it.. unless there's a small leak somewhere..
Thank you
#3536809 - 11/13/14 12:37 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
npfd Offline
Loc: Canada
hi all another update,
I do recall last year, that after I shut the car off while sitting in it for 5 minutes, I heard that double knock while sitting.. sounded in the front as always.
Now with the weather being colder, I shut off the car, I happen to do things near it for a while and hear half a knock to full knock in the back of the car.... and looking up on the web here, other GM's cars with evap knocks...
http://www.saturnfans.com/forums/showthread.php?t=112013
Most likely it could be just the evap system, but with knocks like that does the canister have to changed?
Thank you all again for the suggestions, its been very helpful.
#3706220 - 04/20/15 11:46 PM Re: three knocks heard at idle after sitting overnight [Re: npfd]
npfd Offline
Loc: Canada
Just another update....
Usually check the oil every month, this time went 1.5 months, and itwas about a quart low.
One thing is the temperature has warmed up from the - 5 celsuis to about 10 c now.. would the warm weather have burned out all the condensation? I try to drive it at least 5 kms one way.. to warm it up....
I don't do much mileage and just surprised it would do that.
I read up on something like this
http://www.lubegard.com/C-182/LUBEGARD+Engine+Flush
any ideas please?
Thank you
npfd
#3706304 - 04/21/15 04:55 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
Ducked Offline
Loc: Taiwan
My guess would be pre-ignition, due to carbon in the cylinder(s).
Of course that is just a guess, based on an intermittent sharp tap I was getting at idle when I first got my current car.
(Probably not the same sound and not nearly so regular, but then it isn't the same car)
Arranging for the engine to suck water into the intake seemed to fix it, and the price was right.
#3708288 - 04/22/15 11:37 PM Re: three knocks heard at idle after sitting overnight [Re: npfd]
npfd Offline
Loc: Canada
thank you Ducked,
is this the procedure of spraying mist water in the intake?
I'm not comfy trying that out yet.... any other addivites, that worked for you?
Thank you
#3708330 - 04/23/15 02:29 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
Ducked Offline
Loc: Taiwan
thank you Ducked,
Thank you
Never tried anything else that worked. In my implementation, I ran an IV line into one of the (many) rubber tubes hanging off the (mid-80's) carburettor that saw intake manifold vacuum. If I did (or do) it again I'll try and arrange misting or suction into the air intake.
Other improvised solutions I've heard of include:-
(a) Brake fluid dropped onto the piston crown though the plug hole (theory being that its a powerful solvent, eg for paint - suppose you could apply other solvents in the same way)
(b) A grain or few of rice, ditto (theory being that they rattle around for a while, dislodging carbon, and then they burn off - I got a similar but more drastic effect with a broken bit of piston ring;no remaining carbon but lots of little dings in the piston crown and the plug side-electrode flattened)
Water seems less likely to be damaging than either of those. Dunno about commercial products. I used something called Redex (UK market) sometime in the 80's. Didn't seem to do anything.
Nice things about water: Cheap, Open-source formulation, fairly fully-understood mechanism of action, low toxicity, No abrasive residue (assumes distilled water. I was using aircon condensate which should be close. Scottish tap water is probably mostly close enough too).
Spraying water in by hand is likely to take a tediously long time though.
Edited by Ducked (04/23/15 02:36 AM)
