Manual says every 10 K on oil changes
by ceast
30 minutes 40 seconds ago
Brake fluid ageing?
by LucasDK
33 minutes 49 seconds ago
If Anybody has 60K Lying around
by GumbyJarvis
Today at 02:03 PM
144$ lot of 48 Fl-400s/L20195 Eq Filters
by GumbyJarvis
Today at 01:29 PM
AT Whine
by DWC28
Today at 01:14 PM
GM AutoTrak II fluid
by nthach
Today at 12:49 PM
GM 2500HD 75w-90 or 75w-110
by Stewart Fan
Today at 12:03 PM
tire question
by Durango
Today at 12:02 PM
Winter's Over, Time to Start Next Year's Firewood
by doitmyself
Today at 11:54 AM
Heard of Hemi Tick- is there "Hemi Shudder"?
by JennyHemi
Today at 11:07 AM
Lost my mind, about to buy Genesis Coupe 3.8
by FutureDoc
Today at 10:27 AM
Tire Sizing Help
by coopns
Today at 10:23 AM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
96 registered (2010Civic, Al, 69GTX, 2009Edge, 901Memphis, 01rangerxl, 14 invisible), 1998 Guests and 240 Spiders online.
57779 Members
66 Forums
248413 Topics
Page 3 of 3 < 1 2 3
#3384669 - 05/30/14 07:53 AM Re: Cheap DIY urethane motor mounts [Re: IndyIan]
javacontour Offline
Loc: Illinois
That's the insane part about the price. It's not a fluid filled mount. Apparently the manual transmission car is sort of a unicorn when it comes to a few of the motor mounts.
I plan to try this with the easy to get to mounts first, and if it works, I'll invest the time in more difficult to reach mounts.
Originally Posted By: IndyIan
Is the mount fluid filled? I guess you have very little to lose by trying a filled/solid mount but I think you'll find it too buzzy for a DD.
Some companies make urethane inserts to fill the holes in the OEM mount, I wonder if putting in an insert and then drill holes into it to soften it until you like it, would work?
network down, IP packets delivered via UPS -BOFH
#3384680 - 05/30/14 08:08 AM Re: Cheap DIY urethane motor mounts [Re: asand1]
JHZR2 Offline
Loc: New Jersey
will be interesting to see how they hold up. Not sure if you did much to ensure bonding to the other parts (granted you used adhesives), and if it is the right stuff for the heat and everything else.
Still, nice job! I hope they last and keep us posted. OE stuff cannot be THAT different, other than how they pour/craft and cure the materials...
#3391136 - 06/06/14 10:17 PM Re: Cheap DIY urethane motor mounts [Re: asand1]
javacontour Offline
Loc: Illinois
Here is my attempt for the Protégé 5
https://www.dropbox.com/sh/7j6qt4nb7x8y4zl/AACkbXZ_-ohOQ5UVmpMor48ha
I supported the engine, removed the mount. You can see the mount is completely torn. I cleaned it with brake parts cleaner and then filled it with the 3M windshield urethane. It is supposed to be fast setting. From what I've read, 48 hours should be enough. I am giving it over 72 hours while I am on a long weekend with oilBabe.
For some reason, a good quality mount for a manual transmission P5 is $150-200. So $18 in urethane and 90 minutes time is a worthy gamble to see if this works.
The other mounts are more realistically priced so if needed, I will buy replacements.
#3391150 - 06/06/14 10:42 PM Re: Cheap DIY urethane motor mounts [Re: asand1]
tom slick Offline
Loc: Central Coast, Calif.
I hope it works out but if it doesn't take a look at these
http://store.awrracing.com/categories/Engine-Mounts/Mazda-Protege5/
You get what you pay for...
So keep in mind how much you paid for this advice.
#3392003 - 06/08/14 08:36 AM Re: Cheap DIY urethane motor mounts [Re: asand1]
Cujet Offline
Loc: Jupiter, Florida
Of course, there are other "synthetic rubber" options that cure rather rapidly. No need to wait 4 months!
I've done similar things with engine mounts, transmission mounts, suspension bushings and yes, even pneumatic tires.
1) Polysulfide rubber sealants (for aircraft fuel tanks and for sealing the fuselage) such as PRC-Desoto PR-1422 (B2 cures in 2 hours, B-1/2 cures in 1/2 hour)
2) 2 part polyurethane of nearly any durometer you want (softness) I typically use 30 durometer. This stuff is cheap, easy to mix, easy to mold (such as in a paper cup) , makes great suspension bushings and so on. The pic says "RTV" which means "room temperature vulcanizing". It does not mean it's silicone sealant.
Turbo's rule.
#3392011 - 06/08/14 08:40 AM Re: Cheap DIY urethane motor mounts [Re: asand1]
Cujet Offline
Another quick note:
The 30 durometer poly is great for various applications. One use is to fill small Chinese tires so they don't leak down overnight. Another good use is to re-fill leaking "liquid filled" engine mounts and suspension bushings. Just mix up a batch and inject it in the empty mount/bushing using the holes you drill. Works like a champ.
Turbo's rule.
#3484898 - 09/16/14 11:21 PM Re: Cheap DIY urethane motor mounts [Re: asand1]
asand1 Offline
Loc: Oregon coast
Today I picked up the 3M 08693 window urethane for $11.23 at NAPA auto parts and filled my original MT mounts. I cut a couple lengths of 1/2" aluminum tube to help fill the voids in one mount, this allowed me to complete the whole job with just one tube of urethane.
[url="http://s146.photobucket.com/user/asandberg6/media/96%20MAXIMA/windowurethane_zpsb1c1ea1f.jpg.html"][/url]
[url="http://s146.photobucket.com/user/asandberg6/media/96%20MAXIMA/mount3_zpsbb2bd3ad.jpg.html"][/url]
[url="http://s146.photobucket.com/user/asandberg6/media/96%20MAXIMA/mount1_zps24064c13.jpg.html"][/url]
[url="http://s146.photobucket.com/user/asandberg6/media/96%20MAXIMA/mount2_zps449f3868.jpg.html"][/url]
Nissan/Infinity/Mazda Manuals
1996 Maxima 310K
2008 Uplander 80K
#3492314 - 09/24/14 03:24 PM Re: Cheap DIY urethane motor mounts [Re: asand1]
asand1 Offline
Loc: Oregon coast
Today I installed the new DIY mounts. The white mounts were not pretty. The rear mount tore loose and formed a gap above the eye.
[url="http://s146.photobucket.com/user/asandberg6/media/96%20MAXIMA/failedwhitemount2_zps9e81db73.jpg.html"][/url]
[url="http://s146.photobucket.com/user/asandberg6/media/96%20MAXIMA/failedwhitemount1_zpsc9709dc7.jpg.html"][/url]
Mounted the new DIY urethane mounts and bolted the cross member in, torqued to 65ft/lbs.
[url="http://s146.photobucket.com/user/asandberg6/media/96%20MAXIMA/mounted_zpsaa3ffeb0.jpg.html"][/url]
Car shakes a bunch at startup, but idle is still smooth.
1996 Maxima 310K
2008 Uplander 80K
#3492360 - 09/24/14 04:09 PM Re: Cheap DIY urethane motor mounts [Re: asand1]
asand1 Offline
Loc: Oregon coast
Edited by asand1 (09/24/14 04:13 PM)
1996 Maxima 310K
2008 Uplander 80K
#3492652 - 09/24/14 09:51 PM Re: Cheap DIY urethane motor mounts [Re: asand1]
asand1 Offline
Loc: Oregon coast
1996 Maxima 310K
2008 Uplander 80K
Page 3 of 3 < 1 2 3
