Strange failure: Starter AND flywheel cogs ripped
by lars11
07/29/16 02:22 PM
My email from Castrol about Magnatec
by Tech819
07/29/16 02:13 PM
Audi 5000 / Known Stop-Leak Compatible w/ CHF 7.1?
by Miles07PT
07/29/16 01:41 PM
Observations on Workplace corrosion
by Vdubuk
07/29/16 12:15 PM
Oil filter change NIGHTMARE
by MetalSlug
07/29/16 12:08 PM
First time flushing an 05 Tacoma
by Back40
07/29/16 11:53 AM
600-year-old plumbing works better than modern
by HTSS_TR
07/29/16 11:48 AM
Shopping for brand-new F-150
by jay929
07/29/16 11:35 AM
Audi Broken Oil Control Rings - Why???
by SonofJoe
07/29/16 11:27 AM
Royal Purple VS Mobil 1?
by 340six
07/29/16 11:09 AM
Condensing down to 1 vehicle
by krismoriah72
07/29/16 11:04 AM
Ford Focus door strip coming off
by FordBroncoVWJeta
07/29/16 10:41 AM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
95 registered (69GTX, Anduril, alanwayne1908, andrewlg, 2015_PSD, 4WD, 8 invisible), 2034 Guests and 10 Spiders online.
58632 Members
66 Forums
252405 Topics
#3391928 - 06/08/14 02:40 AM Horn goes off when I turn wheel
Jameson Offline
Loc: New York
Horn honks when I turn my steering wheel to the left....
Basically when the wheel gets to "ALMOST" the full lock, the horn honks and will stay on until I straighten out the wheel. HELP
2002 Ford F350 4x4 XL reg cab
5.4l 2v V-8 Modular - 130k miles
4r100 Auto Trans
Current Oil: Mobil Super HM 5w20
Filter: Motorcraft FL820-S
#3391930 - 06/08/14 03:03 AM Re: Horn goes off when I turn wheel [Re: Jameson]
Mackelroy Offline
Loc: Florida /Texas
I had an old truck one time the turn signal screw inside the steering column came loose and the horn would blow every time while turning the wheel, had to pull the steering wheel to fix. So Id say your looking at something like that.
#3391953 - 06/08/14 06:27 AM Re: Horn goes off when I turn wheel [Re: Jameson]
datech Offline
Loc: us
That's no good. Seriously, your horn ring is somehow messed up. Maybe something broke off or fell in there.
Not much fun and you will have to unhook the battery and pry off the horn button and maybe even remove the wheel/nut.
Do you remember what you did to it to cause this, or anything that happened?
I think had something like that once and it was a wire that wore thru the insulation and was touching.
#3391956 - 06/08/14 06:42 AM Re: Horn goes off when I turn wheel [Re: Jameson]
GMBoy Offline
Loc: Texas
It is not the horn button. The problem is below your steering wheel in the coloumn. The SIR COIL wire is shorting out to ground when turning the wheel. Take off the wheel and look for damaged wires - should be really easy and obvious. Reroute it and tape it up. Easy job. Remove a battery cable and let it sit a few minutes to disable the air bag system. Pull the driver airbag and you may see the wire. If not, take off the nut holding the wheel and look under. Pretty common issue. You can fix it yourself.
#3392183 - 06/08/14 01:10 PM Re: Horn goes off when I turn wheel [Re: Jameson]
Gokhan Offline
Loc: Los Angeles, California
I don't think you will have to remove the steering wheel, which would require a steering-wheel puller. Just take off the cover and fix or replace the defective horn-button mechanism.
If you do pull off the steering wheel, make sure that it's centered when you reinstall it. Centered steering wheel doesn't mean the steering wheel is perfectly straight -- it means that there needs to be exactly equal number of turns to the left and to the right from the steering-wheel position where the wheels are straight. It's probably already centered; so, just mark the current notch, and if isn't, you would have to not only recenter the steering wheel but also have your front toe readjusted, as the two are obviously related so that the steering wheel is both centered and straight. Again, I doubt you will have to pull it off though.
1985 Toyota Corolla LE, 4A-LC engine, ~ 264,000 M
Mobil 1 (M1) 0W-40 SN synthetic
Toyota 90915-YZZF2 filter, 90430-12031 drain gasket
#3392192 - 06/08/14 01:22 PM Re: Horn goes off when I turn wheel [Re: Jameson]
01rangerxl Offline
Loc: Birmingham, AL
Ford clocksprings are notorious for erratic behavior. The clockspring is the assembly that provides power to controls on the steering wheel.
The backlighting on my cruise control buttons has been intermittent for years and switches sides when it feels like it.
2002 Ford Ranger XLT | 3.0 V6 / 5-Speed Automatic / 2WD | 185K miles
1994 Ford Ranger STX | 4.0 V6 / 5-Speed Manual / 4X4 | 180K miles
#3392309 - 06/08/14 03:52 PM Re: Horn goes off when I turn wheel [Re: Jameson]
Gokhan Offline
FWIW, here is what the parts look like in my 1985 Corolla. It was a huge pain to get back the 45130 button assembly on the 45100 wheel in my case, as the 45129A retaining spring was very problematic. I remember spending several hours and then finally bending the 45129A spring by the right amount to get the button assembly seated. Problems in the 45130 button assembly as well as the 45207 contact ring (so that the button can still make contact when you turn the steering wheel) could cause horn problems.
#3394337 - 06/10/14 08:47 PM Re: Horn goes off when I turn wheel [Re: Jameson]
artificialist Offline
Loc: Florida
Sometimes the clock spring causes it, other times if there is play in the steering column the horn and other controls will not function properly.
However, the steering column problem usually happens on GM vehicles made in the 1990s and earlier. I once had to deal with it on a Lexus with over 200,000 miles, what a nightmare!
2010 Lancer Ralliart Sportback
#3394361 - 06/10/14 09:09 PM Re: Horn goes off when I turn wheel [Re: GMBoy]
Joe_Power Offline
Loc: USA - Coast to Coast, Border t...
What he said. Pinched wire. I GUARANTEE it.....
2011 Jeep Wrangler
2015 Chevrolet 2500HD LTZ
2011 Harley Davidson FLHX
Common sense is a flower that doesn't bloom in everybody's garden.
