three knocks heard at idle after sitting overnight
Canada
Hi all,
The car is a 2007 Grand Prix, with the 3800 N/A.
We bought it second hand in 2011 with about 57k kms, now it has about 102k kms.
I used to hear this a while ago, I think even the first winter when we had the car.
Let the car sit overnight, and start it and drive several minutes and at a light at idle, I'll hear three knocks from the engine bay.
Some of the work we did:
Change plugs and wires
Redid the LIM
Ran a few techron tank fuels,
Premium fuel.
Checked the heat shields, one of them is a little loose
PCV changed with new gasket, in 2011
MAF cleaned a few times
Coils checked resistance
I do have to monitor the oil level every month, sometimes need to add a little, a small cup.
After reading on forums, ran Auto RX in the winter time. from November to February.
I used to hear the knocks, but at some point hte first knock was louder then the second after were quieter. Then eventually I would stop hearing the knocks.
Currently been using PF47 Ac Delco filter, and Quaker State 5w30 oil.
It was suggested that maybe the piston crowns are dirty due to the short drives, about 2 miles to and back from work. I do try to try on the highway 20 minutes one way several times a week.
I bought MMO, and was about to put it in the crankcase, but didn't and returned it..
Afraid that it might cause more leaks... after reading a fair amount on forums etc... most favour mmo... but looking at how its a solvent I was afraid it would aggravate the Rear main leak that's been going on since we bought the car.
We usually change the oil every 4 months... or 3x a year... regular dino oil...
Should I run another dose of Auto RX, or the maintenance.. safe to use the MMO maybe a week before changing the oil?
With the job i have right now I can just about keep the operating costs of the car, as any compression test etc,,, wouldn't be done right away maybe soon...
Thank you
Could be a timing issue or belt/tensioner. Checked those yet. Also if you have messed with coolant during service you could have a trapped air bubble. You might try the Mos2 or motor oil saver from Liqiumoly, just a thought.
Running a PEA cleaner like redline si-1 might help. Sometimes if you run too low on petrol the fuel pump might be talking at you as well.
With 60K miles on this 07 engine i am surprised by the rear seal and LIM gaskets.
These engines are not known for carbon knock, carbon knock is usually heard at cold start up and sounds almost like a rod knock, it may take 5 min or more to disappear but it does.
From what you describe i think you may be barking up the wrong tree, i don't think its in the engine. Some more information would be helpful.
*Do you any knocking when first started that disappears quickly and is not heard again the remainder of the running cycle?
*Have you been using the recommended viscosity since you owned it?
*Is this knock sound metallic or more like something moving and clacking like a solenoid?
*Any recent Check engine lights?
*Is this 3 knocks always 3 or does it vary in amount or frequency?
*Does this get louder with lower ambient temperatures?
*Do you hear an electric motor noise at start up or shortly thereafter?
First of all
to BITOG! I honestly have no idea what the knocking noise is, I would however stop putting in oil additives, Techron is ok every now and then in the tank but all these oil additives could be doing more harm than good. If you want a safe and fairly inexpensive way to clean up the engine gently, start using a good synthetic oil like PU, PP, M1 etc.
If it's a the same MPG the first start after it sits, it could be the ABS check.
My car does it at 15mph, thought it was bearing or CV related for the longest time but I can go from park to neutral and coast down a hill and it still does it, but only once.
Mice hitting the fan on the way scrambling off the UIM?
May just be accessory belt memory with a quick backslap. TRy a new belt if the current one is ancient - also check that the tensioner is free.
I'm really hoping its not coolant pooling in a cylinder, but it sure could be.
Thank you everyone, and welcoming me too Greg.
I forgot to add that yes we did the Coolant drain and refill. We checked a few times with the bleeder so that there is no air.
As for additives, I've only used the Auto RX, and the Techron.
I haven't really checked the belt/tensioner... thought I do hear a slight rattle or pinging on acceleration at times.. thinking it could be the loose heatsheild..
@Trav, the LIM might have been a bad call.... as it was wet around the area, the RMS leak was there when we bought it, back of oil pan and side wet... valve covers felt dry in the back... and the front
- at times a rattle.... at first but don't hear it again.
- yes its the 5w30 with the approved GM standard, 6094.. I think..
- sounds metallic, hammering... like a double knock
- Not yet
- Rarely it varies.... sometimes it sounded faster and usually slower... I'm estimating here, the three knocks lasts about 2 seconds... Not enough time for me to press on the gas to see if its oil pressure related, as a friend suggested...
- yes in cold weather used to be very loud last year, it is more audible in cold weather and warm weather, even in summer you hear it faintly.. very easy to miss if you're not looking for it... and in the winter if you have the radio on, you'll miss it.
Only when driving, after 20 feet I hear what I think is the ABS pump engaging...like a moan...
I'm still a bit stumped why I didn't hear it towards the end of the Auto RX treatment...
I managed to get the service records from the dealer, hard a hard time, and they did oil changes like every year, at about 10k kms...
At times there is a surge at idle, a clunk noise on acceleration, sometimes trouble starting...
Thank you all for the input.
I think it's a bad mount. Stuff moving around. Find a watcher, open the hood, and try shifting from drive to park to reverse, to make the engine rock a bit.
thank you for the input, forgot to mention happens when I'm stopped, the knock, or sometimes coasting to a stop....
Will it make any noise if you start it and just let it warm up or does the car have to be moving?
I have heard a noise similar to this which turned out to be a noisy electric AIR pump on a 3800 GM.
One that has failed will throw a CEL but the fan inside can wobble when its worn and strike the housing as it winds down to a stop.
That would be a heck of a long shot.
Thank you again for the input, lol at the song.... I do think I'm SOL..
I have remote started it and let it run for 10-15 minutes from afar didn't hear anything....
Usually happens when the car is stopped, at a red light, or let off the gas and moving.... Could the secondary air pump make that much noise? very audible in colder weather... btw I never knew this system existed.... and I Do hear it on the driver side of the motor... and strange thing when I had my head turned left, I thought I heard the knocking from the back too..... probably looking into it too much...
I'm still at a loss why I didn't hear it after the auto rx was in for a while....
Any way to test the secondary pump?
Thank you
I don't think its anything to do with the ABS, IIRC there is no mechanical check of the system that would be audible just an electronic check which is complete when the ABS light goes off.
AIR pumps can make a lot of noise when worn and it is located on the driver side under the side of the front bumper.
The only cars i can remember that made hydraulic cycling noises was the Citroen's, the old DS, CX and SM cars especially were an orchestra of knocks, clicks and double clicks but nothing like that on US cars.
Testing the AIR pump is easy enough just jump the relay, also check any solenoids in the system as they can make noise also.
I don't want to send you down a path with this thought, its a way off guess looking for the obscure nothing more.
You need a second person, start the car cold with the hood open let it run a min or two while you listen then have someone put it in drive and hold the brake (e brake on) and keep listening for a few min.
I cant thing of anything that would give three distinct knocks in this engine internally then stop but externally mounted solenoids and other parts could, it could also be in the transmission but that would be remote.
Next time your at the red light where is usually does this put it in neutral and see if there is any difference.
Diagnosing something like this is a difficult enough when you have the car in front of you on a message board its darn near impossible except for endless guessing.
I think the ARX is just a coincidence unless it was a lifter or something but that shouod be a noise easy enough to identify.
Thank you very much again Trav,
I will have to look into testing out the air pump, as for someone to listen in on the issues will be hard...
I tried it in neutral while waiting at the light, same knock.. actually now I notice that he first knock sounds a little different than the next two which are identical to each other.
Sure, rods, or worn valves can't make this sound...
Tongiht was louder, cause the temp was 15 degrees celsius.... with it 25+ knock is much fainter and quicker sounding...
hehe yes diagnosing via forum is hard...
Thank you again
Thank you for the reply... I had the A/C refilled a tad due to it not working as well..... and I did see some spray marks around it this passed spring....
I did try with the AC engaged, and still heard the knocks....
I will have to look into things a bit more.. thanks... would it be a rod?
Could it be the knock sensor testing the fuel octane by advancing timing til knock is audible then retarding it?
I'm thinking the engine has significant carbon accumulation in the combustion chambers which is raising compression,so at start up when the ecu isn't reading the o2 sensors the stock timing is too much so once knock is heard timing is adjusted?
Just throwing out ideas.
