Mobil 1 oil filter quality
by dgunay
02/09/16 03:34 PM
help replacing door pins on a 98 corolla
by ziggy
02/09/16 03:26 PM
Bought an oil filter today.
by Taildragger
02/09/16 03:14 PM
15' Audi A4 quattro 2.0T Valvoline 0W40 7510 miles
by skyactiv
02/09/16 02:53 PM
Dodge Grand Caravan - Need Some Info
by Nick1994
02/09/16 02:47 PM
Oil for 1997 4runner with 300K
by claluja
02/09/16 12:54 PM
2003-2009 Lexus GX 470 Rear shocks for sale
by exman123
02/09/16 12:09 PM
Maintenance on a Mint Low Mileage 2001 S2000
by Thugzy
02/09/16 11:54 AM
AutoZone Game...cash and gift cards
by eddielasvegas
02/09/16 11:51 AM
Dual platinum and iridium sparkplugs vs. standard
by DrRoughneck
02/09/16 11:31 AM
Kendall Super-Dxa 15W-40 SynBlend
by 2015_PSD
02/09/16 10:05 AM
2015 Ford F-250 6.7L MC Filter (9,800 miles)
by 2015_PSD
02/09/16 10:01 AM
paulp, ATLjunkcars, jqgz, ukpdxwrx, TerrenceRocks
56865 Registered Users
100 registered (2009Edge, 2015_PSD, 901Memphis, 01_celica_gt, 440Magnum, 97K15004WD, 10 invisible), 1656 Guests and 101 Spiders online.
56865 Members
66 Forums
244453 Topics
Page 1 of 3 1 2 3 >
#3390303 - 06/06/14 01:16 AM three knocks heard at idle after sitting overnight
npfd Offline
Loc: Canada
Hi all,
The car is a 2007 Grand Prix, with the 3800 N/A.
We bought it second hand in 2011 with about 57k kms, now it has about 102k kms.
I used to hear this a while ago, I think even the first winter when we had the car.
Let the car sit overnight, and start it and drive several minutes and at a light at idle, I'll hear three knocks from the engine bay.
Some of the work we did:
Change plugs and wires
Redid the LIM
Ran a few techron tank fuels,
Premium fuel.
Checked the heat shields, one of them is a little loose
PCV changed with new gasket, in 2011
MAF cleaned a few times
Coils checked resistance
I do have to monitor the oil level every month, sometimes need to add a little, a small cup.
After reading on forums, ran Auto RX in the winter time. from November to February.
I used to hear the knocks, but at some point hte first knock was louder then the second after were quieter. Then eventually I would stop hearing the knocks.
Currently been using PF47 Ac Delco filter, and Quaker State 5w30 oil.
It was suggested that maybe the piston crowns are dirty due to the short drives, about 2 miles to and back from work. I do try to try on the highway 20 minutes one way several times a week.
I bought MMO, and was about to put it in the crankcase, but didn't and returned it..
Afraid that it might cause more leaks... after reading a fair amount on forums etc... most favour mmo... but looking at how its a solvent I was afraid it would aggravate the Rear main leak that's been going on since we bought the car.
We usually change the oil every 4 months... or 3x a year... regular dino oil...
Should I run another dose of Auto RX, or the maintenance.. safe to use the MMO maybe a week before changing the oil?
With the job i have right now I can just about keep the operating costs of the car, as any compression test etc,,, wouldn't be done right away maybe soon...
Thank you
#3390309 - 06/06/14 01:31 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
Marco620 Offline
Loc: Midwest, Rural KS
Could be a timing issue or belt/tensioner. Checked those yet. Also if you have messed with coolant during service you could have a trapped air bubble. You might try the Mos2 or motor oil saver from Liqiumoly, just a thought.
#3390311 - 06/06/14 01:33 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
Marco620 Offline
Running a PEA cleaner like redline si-1 might help. Sometimes if you run too low on petrol the fuel pump might be talking at you as well.
#3390432 - 06/06/14 07:45 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
Trav Offline
Loc: MA, Mittelfranken.de
With 60K miles on this 07 engine i am surprised by the rear seal and LIM gaskets.
These engines are not known for carbon knock, carbon knock is usually heard at cold start up and sounds almost like a rod knock, it may take 5 min or more to disappear but it does.
From what you describe i think you may be barking up the wrong tree, i don't think its in the engine. Some more information would be helpful.
*Do you any knocking when first started that disappears quickly and is not heard again the remainder of the running cycle?
*Have you been using the recommended viscosity since you owned it?
*Is this knock sound metallic or more like something moving and clacking like a solenoid?
*Any recent Check engine lights?
*Is this 3 knocks always 3 or does it vary in amount or frequency?
*Does this get louder with lower ambient temperatures?
*Do you hear an electric motor noise at start up or shortly thereafter?
#3390436 - 06/06/14 07:49 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
gregk24 Offline
Loc: FL, USA
First of all welcome to BITOG! I honestly have no idea what the knocking noise is, I would however stop putting in oil additives, Techron is ok every now and then in the tank but all these oil additives could be doing more harm than good. If you want a safe and fairly inexpensive way to clean up the engine gently, start using a good synthetic oil like PU, PP, M1 etc.
2012 Honda Accord EX-L 36K
M1 AFE 0w20 / Fram Ultra
2005 Chevy Uplander 133K
QSD 5w30 / Fram Ultra
1991 Buick Park Avenue 120K
Supertech 5w30 / Fram Ultra
#3390484 - 06/06/14 08:59 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Only three knocks? Might be ABS check.
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#4 24596mi-PP 0W20+Subaru Filter
#3390504 - 06/06/14 09:35 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
brandini Offline
Loc: Richmond, VA
If it's a the same MPG the first start after it sits, it could be the ABS check.
My car does it at 15mph, thought it was bearing or CV related for the longest time but I can go from park to neutral and coast down a hill and it still does it, but only once.
07 Mazda3s Hatch - ZoomZoom - Using EAO-ALM-BF3-MTG-ANT-ATF
#3390618 - 06/06/14 11:24 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
Nick1994 Offline
Loc: Phoenix, AZ
Could be the famous GM piston slap?
2000 Toyota Camry 2.2L 205k
Pennzoil Platinum HM & Fram Ultra
#3390622 - 06/06/14 11:30 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
Loc: N.H, U.S.A.
Mice hitting the fan on the way scrambling off the UIM?
May just be accessory belt memory with a quick backslap. TRy a new belt if the current one is ancient - also check that the tensioner is free.
I'm really hoping its not coolant pooling in a cylinder, but it sure could be.
#3390632 - 06/06/14 11:44 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
npfd Offline
Loc: Canada
Thank you everyone, and welcoming me too Greg.
I forgot to add that yes we did the Coolant drain and refill. We checked a few times with the bleeder so that there is no air.
As for additives, I've only used the Auto RX, and the Techron.
I haven't really checked the belt/tensioner... thought I do hear a slight rattle or pinging on acceleration at times.. thinking it could be the loose heatsheild..
@Trav, the LIM might have been a bad call.... as it was wet around the area, the RMS leak was there when we bought it, back of oil pan and side wet... valve covers felt dry in the back... and the front
- at times a rattle.... at first but don't hear it again.
- yes its the 5w30 with the approved GM standard, 6094.. I think..
- sounds metallic, hammering... like a double knock
- Not yet
- Rarely it varies.... sometimes it sounded faster and usually slower... I'm estimating here, the three knocks lasts about 2 seconds... Not enough time for me to press on the gas to see if its oil pressure related, as a friend suggested...
- yes in cold weather used to be very loud last year, it is more audible in cold weather and warm weather, even in summer you hear it faintly.. very easy to miss if you're not looking for it... and in the winter if you have the radio on, you'll miss it.
Only when driving, after 20 feet I hear what I think is the ABS pump engaging...like a moan...
I'm still a bit stumped why I didn't hear it towards the end of the Auto RX treatment...
I managed to get the service records from the dealer, hard a hard time, and they did oil changes like every year, at about 10k kms...
At times there is a surge at idle, a clunk noise on acceleration, sometimes trouble starting...
Thank you all for the input.
#3390638 - 06/06/14 11:51 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
supton Offline
Loc: NH
I think it's a bad mount. Stuff moving around. Find a watcher, open the hood, and try shifting from drive to park to reverse, to make the engine rock a bit.
2011 Toyota Camry, base, 6spd manual, 107k, hers
2010 Toyota Tundra double cab, 4.6L, auto, 114k, his
#3390698 - 06/06/14 01:15 PM Re: three knocks heard at idle after sitting overnight [Re: npfd]
npfd Offline
Loc: Canada
thank you for the input, forgot to mention happens when I'm stopped, the knock, or sometimes coasting to a stop....
#3390816 - 06/06/14 03:25 PM Re: three knocks heard at idle after sitting overnight [Re: npfd]
Trav Offline
Will it make any noise if you start it and just let it warm up or does the car have to be moving?
I have heard a noise similar to this which turned out to be a noisy electric AIR pump on a 3800 GM.
One that has failed will throw a CEL but the fan inside can wobble when its worn and strike the housing as it winds down to a stop.
That would be a heck of a long shot. LOL
#3391081 - 06/06/14 09:06 PM Re: three knocks heard at idle after sitting overnight [Re: Trav]
edhackett Offline
Loc: Sequim, WA
Sorry, I couldn't help myself. grin
Ed
Never attribute to engineers that into which politicians, lawyers, accountants, and marketeers have poked their fingers.
#3391890 - 06/08/14 12:28 AM Re: three knocks heard at idle after sitting overnight [Re: npfd]
npfd Offline
Loc: Canada
Thank you again for the input, lol at the song.... I do think I'm SOL..
I have remote started it and let it run for 10-15 minutes from afar didn't hear anything....
Usually happens when the car is stopped, at a red light, or let off the gas and moving.... Could the secondary air pump make that much noise? very audible in colder weather... btw I never knew this system existed.... and I Do hear it on the driver side of the motor... and strange thing when I had my head turned left, I thought I heard the knocking from the back too..... probably looking into it too much...
I'm still at a loss why I didn't hear it after the auto rx was in for a while....
Any way to test the secondary pump?
Thank you
Page 1 of 3 1 2 3 >
