My Son's 2001 ford Focus is at his work with a locked up ignition lock cylinder. The key won't turn. After some research, this appears to be a common issue. Ford dealer wants $300.00 plus towing to fix it. If we can't get it to free up by jimmying the key around and tapping it, I'll have to drill the lock cylinder out (I have a copy of the ford TSB on how to do that). The cylinder must be turned to the acc position to release it, if it cannot be turned, it must be drilled. Ford wants over $100.00 for the replacement cylinder while an aftermarket part that claims to have fixed the issue is around 39.00 with good reviews / results. Good thing I'm on vacation this week.
The moral of the story is; If you notice any problems with your ignition lock cylinder, fix it before total failure.
