Microgreen Oil Filter 50% Off Discount Code
by kohnen
05/26/16 11:24 AM
by kohnen
05/26/16 11:23 AM
Mobil Delvac 1 ESP 5w-40 for 2011 TDI?
by ruleof72
05/26/16 10:49 AM
Husquvarna YTH2046 riding mower
by Donald
05/26/16 10:47 AM
Any machinists?
by NavyVet88
05/26/16 09:28 AM
new XG750R flat-tracker
by Mik
05/26/16 08:55 AM
Walmart Supertech 5w20 full synthetic $8.12
by paulswagelock
05/26/16 08:51 AM
Thoughts on M1 V-Twin 20-50 Oil?
by ZZman
05/26/16 08:07 AM
Real Estate Rates
by AirgunSavant
05/26/16 06:30 AM
15w-40 in my boat, is diesel oil OK?
by chriscpmtmp
05/26/16 05:47 AM
20W-50 for a hydraulic pump in a hydrostatic trans
by ford46guy
05/26/16 03:48 AM
new castrol edge high mileage synthetic
by hiflo
05/26/16 03:32 AM
Rdyno, Darsahn, jerryg, 1971tr350, Mak712
57990 Registered Users
92 registered (AirgunSavant, ARCOgraphite, badtlc, 1JZ_E46, AZjeff, Atesz792, 7 invisible), 1789 Guests and 310 Spiders online.
57990 Members
66 Forums
249424 Topics
Page 2 of 2 < 1 2
#3390519 - 06/06/14 09:48 AM Re: The Impala is acting up again. [Re: redhat]
rshaw125 Offline
Loc: Raleigh ,NC CSA
Be sure to let us know what the dealership says is wrong.
Thanks.
2012 Porsche Carrera S
1995 Plymouth Voyager
#3390613 - 06/06/14 11:20 AM Re: The Impala is acting up again. [Re: dishdude]
GMBoy Offline
Loc: Texas
Originally Posted By: dishdude
I suspect a bum speed sensor, not the transmission.
Me too. The trans only runs as good as the rest of the components including eng and sensors.
The "good news" is that the car finally went into a hard failure and can be diagnoses easier. The BAD news is that the mechanic he went to cleared the codes so she could drive home thus taking all the valuable evidence with it.
#3390626 - 06/06/14 11:36 AM Re: The Impala is acting up again. [Re: redhat]
99Saturn Offline
Loc: NY
Originally Posted By: redhat
Originally Posted By: The_Eric
The reduced power code is typically throttle body/TPS related and could very well give you some transmission grief. The TCM/PCM relies heavily on the engine's sensors to know what it needs to make the transmission do.
Interesting, perhaps this is related to the transmission slamming into gear.
Everyone: As always I appreciate the input and comments.
This probably helps very little, but I had limp mode which led to hard shifting after some further driving to get home, which cleared up right after the code was cleared on our Cobalt (2006). The code I had was related to the Accelerator Pedal Position Sensor with a couple of TSBs for other stuff as well (possible leaks and bad PCM in a certain date range). Throttle body, and TCM were also among the suggestions for issues when I was poking around online.
#3390697 - 06/06/14 01:15 PM Re: The Impala is acting up again. [Re: GMBoy]
antiqueshell Offline
Loc: chicago, Illinois
Originally Posted By: GMBoy
[quote=dishdude] The BAD news is that the mechanic he went to cleared the codes so she could drive home thus taking all the valuable evidence with it.
The codes did not have to be cleared to make the car safe to drive home, it was already in limp mode so there was no need to clear any diagnostic codes. Another clueless tech. The dealer MAY be able to retrieve those past codes if the car holds onto them in a separate hard memory in the ECU that can be read with a GM specific scan tool. What I am saying is that the general scan tool that the mechanic used may only erase codes in soft storage.
#3390879 - 06/06/14 04:40 PM Re: The Impala is acting up again. [Re: Clevy]
901Memphis Offline
Loc: Northern Kentucky
Originally Posted By: Clevy
Originally Posted By: 901Memphis
Originally Posted By: 01_celica_gt
Originally Posted By: NHGUY
Chrysler A413 3spd for life....
3 speed? must be amazing gas mileage.
My 4T65e on a 3.1 Only averages 16 mpg.
Huh
My hemi charger gets significantly better than that when averaging city and highway consumption.
Must be the P0420 code plus my lead foot. Runs great except for the code and the occasional hard shifts. Plenty of power. I get 25 mpg on straight 65-70 cruising but city it abysmal. My last tank was 17 mpg but I average as low as 13-14 mpg if I idle too much. 15-16 mpg is the average with low idle time.
I don't think I'll ever have enough money to get to the bottom of the P0420 code.
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3391027 - 06/06/14 08:09 PM Re: The Impala is acting up again. [Re: antiqueshell]
GMBoy Offline
Loc: Texas
Nope. Once cleared everything is cleared including history code. No way to retrieve anything.
#3391810 - 06/07/14 10:29 PM Re: The Impala is acting up again. [Re: redhat]
redhat Offline
Loc: Western New York
Dealer replaced the gas pedal assembly. They said it was messing up causing the dash to light up like a Christmas tree.
I also told them to keep the car and keep trying it for the transmission issue.
They actually lost the car on the lot and were kinda rude to us. Will be getting a free NYS inspection and fill up our gas tank for the [censored] we've been through for the past couple of days.
09 Accord Sedan 5MT - T6 5W-40, WIX 53756, 97k
14 Civic EX Coupe - TGMO 0W-20, WIX 57356, 22k
#3404539 - 06/23/14 01:27 PM Re: The Impala is acting up again. [Re: redhat]
redhat Offline
Turns out it was the valve body. Dealer cracked the case on the tranny and replaced the valve body, filter, and fluid.
Car used to be kinda sluggish going into gear, now it goes into gear super quick.
#3405236 - 06/24/14 06:56 AM Re: The Impala is acting up again. [Re: redhat]
rshaw125 Offline
Valve body issues the whole time 4T65E's were in production. When I had mine rebuilt the shop put several upgrades into the valve body. I wish GM had done this years ago.
Page 2 of 2 < 1 2
