People running thru red lights. You ever follow th
by motor_oil_madman
05/03/16 08:30 PM
747-400 versus 747-8
by mjoekingz28
05/03/16 08:22 PM
14psi bypass pressure for small engines?
by motor_oil_madman
05/03/16 07:47 PM
'13 Wrangler 2.5" lift
by JXW
05/03/16 07:37 PM
group 7 v6128 ford 6.7 7k miles
by robo339
05/03/16 07:34 PM
Napa Synthetic
by wolf_06
05/03/16 07:34 PM
How do you guys do it?
by Duffyjr
05/03/16 07:04 PM
House electrical panel buzzing
by Mr Nice
05/03/16 06:15 PM
Happy Birthday Merkava_4
by Trav
05/03/16 04:56 PM
When should you use grease with moly?
by Jetstreamz06
05/03/16 04:54 PM
VOA Motul 4100 Power 15W50
by GermanAutohaus
05/03/16 04:31 PM
Ace Hardware Pennzoil Yellow May 4th to 9th $2.99
by BigD1
05/03/16 04:23 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
122 registered (69GTX, andyd, AirgunSavant, 2002 Maxima SE, 01rangerxl, ABerns, 9 invisible), 1711 Guests and 319 Spiders online.
57779 Members
66 Forums
248427 Topics
Page 1 of 3 1 2 3 >
#3389856 - 06/05/14 03:02 PM is 0W-20 always better for mpg than 5W-20?
Jasper8146 Offline
Loc: Ballwin, MO
I just read the Motor oil 101 to 109 here on BITOG and if I understood correctly what he was saying, it seemed to me that he was saying that all motor oils were actually too thick at room temperature to give optimal lubrication and optimal mpg at initial start up but that 0W oils were thinner than others and thus minimized the problem. So, my question is for a 2014 Kia Forte 2.0 GDI which recommends 5W-20 or 5W-30, if I'm not doing any abusive driving or high speed driving in Arizona during the summer, would 0W-20 and 0W-30 be better choices if my goal is to achieve the highest fuel economy? Am seriously thinking about the Toyota 0W-20 as it seems to have gotten rave reviews here on BITOG and other places. On the other hand, I don't want to jeopardize the warranty either, especially if using the 0W-20 is not going to make a meaningful difference in mpg. What are people's thoughts here about this? This vehicle only has 2300 miles on it and am just about to do my first oil change. Thanks in advance for the input.
#3389864 - 06/05/14 03:15 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: Jasper8146]
4wheeldog Offline
Loc: East Mountains, NM
I doubt the mileage increase will be anything you could put your finger on.
We also do not know what Kia knows about 0/20 in their motors that we do not. I suspect that they just did not consider them, when making the specification, but it is a new car, and you really do not have a lot to gain but going outside the manufacturer's specs.....JMHO.
#3389867 - 06/05/14 03:17 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: Jasper8146]
surfstar Offline
Loc: Santa Barbara, CA
You'll save more money by buying 5w20 on sale, vs the gas savings obtained with 0w20.
#3389871 - 06/05/14 03:24 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: Jasper8146]
Clevy Offline
Loc: Saskatoon canada
The only difference between those 2 grades will be at start up,and only once the ambient temps get into the negatives,so for your Arizona conditions there will be no meaningful difference so pick a 5w-20 grade in the flavour you like best,or what's on sale and call er done
2006 Charger RT
Miles x 2 per oil filter
#3389876 - 06/05/14 03:29 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: Jasper8146]
6starprez Offline
Loc: North Carolina
I doubt your 2014 Kia Forte 2.0 GDI calls for a 5W30. I'm sure the required oil is 0W20 or 5W20 and using a 0W in place of 5W will not void your warranty.
'12 Impreza Sport Limited 93K - PUP 5W30
'02 Odyssey EX 205K - Castrol Edge HM 5W-30
'99 Explorer Limited 5.0 193K - Delo 400 XLE 10W-30
#3389884 - 06/05/14 03:38 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: 6starprez]
Jasper8146 Offline
Loc: Ballwin, MO
I just double checked the owner's manual and 5W-20 and 5W-30 are both recommended for all temperatures. Surprisingly, it even says 10W-30 is okay for temperatures of 0 fahrenheit and above.
#3389889 - 06/05/14 03:43 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: Jasper8146]
4wheeldog Offline
You will see a bigger difference in mileage (Although still very small) between 5/30 and 5/20 than you will between 5/20 and 0/20.
#3389895 - 06/05/14 03:49 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: Jasper8146]
SLATRON Offline
Loc: upstate NY
Amsoil site says 5w20 or 5w30 at all temps but 5/20 is preferred, & 10w30 ok above 0*f
Using a 0 grade instead of 5 won't make much MPG gains, but I feel most useful in winter months for cold starts.
Edited by SLATRON (06/05/14 03:53 PM)
#3389900 - 06/05/14 03:52 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: Jasper8146]
901Memphis Offline
Loc: Northern Kentucky
I would use a synthetic 5w20 during the warranty period.
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3389911 - 06/05/14 03:58 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: Jasper8146]
tig1 Offline
Loc: Illinois
Possibly.
2007 Ford Fusion 179,000 miles
M1 0-20 AFE
2007 Ford Focus 153,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#3389926 - 06/05/14 04:07 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: Jasper8146]
FetchFar Offline
Loc: Colorado
That makes sense, good advice. Look at it this way, the "perfect" oil-of-the-future will not get much thicker when cold and not thin out when hot, same viscosity all the time. We can't do that with current technology, but we can get closer to that when we use a 0W-20.
Like others have said, there is a small fuel economy advantage to using a 0W-20. Small. Anyway, we have had similar discussions about durability of engines using a 20 vs. 30 (or 40), and, to me, this sums it up: http://priuschat.com/attachments/fuel-efficient-motor-oil-technical-article-pdf.11772/ I don't think a 20 is a durability problem, and just looking at the Stribeck Curve convinces me the Shell tribologists are right, saying no problem.
'07 BMW 530xi N52 engine, E60 chassis, 255 hp
'11 Chevy Camaro LS, 3.6L V6, Zeta chassis, 312 hp
'40 Chevrolet Special Deluxe 2-Door Town Sedan
#3389957 - 06/05/14 04:33 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: FetchFar]
Shannow Online   content
Loc: Oz
Can you explain how you look at the Streibeck curve, without knowing either the geometry or the applied load ?
Bottom axis is (operational viscosity x surface speed / applied load).
Unless you know those, you can't read the Streibeck curve.
Unless I'm missing something and there's another way.
#3390020 - 06/05/14 05:52 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: Shannow]
FetchFar Offline
Loc: Colorado
Originally Posted By: Shannow
Bottom axis is (operational viscosity x surface speed / applied load.
Not "load", its actually pressure. Thats load per unit area, maybe thats where the missing geometry you mention comes from. Therefore, more surface area means a thicker oil film, all other things (visc, speed) being equal.
#3390026 - 06/05/14 06:04 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: Shannow]
FetchFar Offline
Loc: Colorado
I discussed this before on these forums in more detail, but, essentially, the bearing engineer knows the worst-case load force (max torque), at a low rpm (lugging), and knows what viscosity oil he wants to use, and then he determines the bearing surface area that will give minimum friction on the Stribeck Curve plus some margin to allow for normal viscosity drops with oil ageing (fuel dilution, VI degradation, etc.). A good choice would be a Stribeck Curve choice of 0.4 on the http://www.stle.org/resources/lubelearn/lubrication/ chart, near minimum friction, yet allows for less viscosity should it occur. .... Now notice the small difference between a 30 oil vs. a 20 oil, and notice that using the thinner oil really doesn't move you to the left on the Stribeck Curve much at all (notice log scale).
#3390079 - 06/05/14 07:31 PM Re: is 0W-20 always better for mpg than 5W-20? [Re: Jasper8146]
Loc: Oz
I'm fairly familiar with the curve, and that the applied load is pressure...how do you know what the applied load (pressure) IS for the different geometries and families of engines ?
...and therefore where on the curve that you are when stating that 20s are right ?
You also need to get the right curve that includes the extensi0n off to the left for friction modified boundary conditions, because as per the paper you linked a few posts back, engines are increasingly operating way off to the left of the chart (which, yes, is logarithmic)
Page 1 of 3 1 2 3 >
