I use the PH3980. The PH3387A is the Fram equivalent of the AC Delco PF47. The PF47 is recommended for my 4.3 equipped GMC van. GM used to recommend the PF52 for this engine, which crosses to the PH3980. I figure the shorter filter is probably adequate, but the longer one is much easier to install and remove.
