Subaru Oil Filter Installed in Dodge Ram Trans?
by dan0928
38 minutes 3 seconds ago
Mobil 5w30 Super 5,000 OCI, bought on clearance...
by FlyNavyP3
Today at 08:42 AM
Android 7 Nougat out.(nexus devices)
by Rand
Today at 07:58 AM
Australia to lose its ute?
by supton
Today at 07:42 AM
Should I continue using HM Oil after gaskets?
by Fahrenheit
Today at 07:03 AM
John Deere 400 garden tractor oil
by Bighorn2500
Today at 06:58 AM
Safety violation? who knows...
by CourierDriver
Today at 06:14 AM
82 Yamaha Virago 750 engine oil
by Trigger
Today at 06:02 AM
Supercheap Auto Father's Day Version 2 sale
by KL31
Today at 05:39 AM
$4 Off Fram Oil and Air Filter Combo
by Tony_Mack
Today at 05:37 AM
U joints
by dlundblad
Today at 04:41 AM
Yamaha Bolt XV950
by FWR132
Today at 02:12 AM
dan0928, basher, Bandita, DaveyJones, OldEuroCarLover
58904 Registered Users
94 registered (Alfred_B, AIRJAC3, 1foxracing, acbent, 2015_PSD, 4WD, 4 invisible), 1527 Guests and 7 Spiders online.
58904 Members
66 Forums
253485 Topics
Page 1 of 2 1 2 >
#3389226 - 06/04/14 11:17 PM Honda ATF temp via scan tool?
bulwnkl Offline
Loc: Arizona
I'd really like to have the ability to watch ATF temps in a 2013 Honda pickup. I know the data is there in the OBD II data, because there is a temp sensor in the tranny, and because Honda can monitor ATF temps with their dealer tools. I had hoped that the ScanGauge II would do it (the company is 'local' to me), but it will not on Hondas.
Do you know of any scan tools that an 'average joe' can afford that will display ATF temps in Hondas? Thanks.
"A government big enough to give you everything you want is a government big enough to take from you everything you have." --Gerald Ford
#3389229 - 06/04/14 11:18 PM Re: Honda ATF temp via scan tool? [Re: bulwnkl]
michaelluscher Offline
Loc: Northeast
Torque pro should be able to do it
'06 Toyota Camry SE V6 3MZ-FE 61k
'01 Mercury Villager Estate VG33E 49k
'06 Ford Taurus SE Vulcan 56k
'13 Chrysler 300 3.6 Pentastar 136k
2016
#3389237 - 06/04/14 11:24 PM Re: Honda ATF temp via scan tool? [Re: bulwnkl]
bulwnkl Offline
Loc: Arizona
Interesting, thanks. I do not personally own a cellular phone of any type, and my work one is a Blackberry. I have a personal Blackberry tablet. I'm thinking Torque PRO will not be an option for me(?)
I'll muck around their forum a bit.
#3389364 - 06/05/14 05:50 AM Re: Honda ATF temp via scan tool? [Re: bulwnkl]
Olas Offline
Loc: Manchester, England
If a blackberry tablet will support Apps then you're done smile
If not, you need to buy a cheap smartphone that supports Apps, or get a multimeter and splice into the wires that connect to the sensor.
Chances are its a thermistor - once you know if its NTC or PTC you can watch the values on your meter and know how hot it is wink
1982 VW Scirocco
1457cc
98 bhp
78000 miles
Redline fluids
Mann/Mahle filters
#3389376 - 06/05/14 06:11 AM Re: Honda ATF temp via scan tool? [Re: bulwnkl]
Vikas Offline
Loc: NorthEast
Since this is not in the standard OBD-II PID, it is more likely that amateur scanners will NOT be able to get the transmission oil temperature. Despite being the name "Pro" in the title, TorquePro is not a professional scanner!
Now if somebody has reverse engineered the Honda scanner (HDS) and found the appropriate PID and managed to convince TorquePro to include that in their software, it will get that temperature. I do not believe that has happened yet.
#3389381 - 06/05/14 06:18 AM Re: Honda ATF temp via scan tool? [Re: Vikas]
Olas Offline
Probably true..
All the more reason to find out the specs of the sensor and splice your multimeter into the wires. You'd be surprised how quickly you learn to convert Ohms to Degrees C.
1982 VW Scirocco
1457cc
98 bhp
78000 miles
Redline fluids
Mann/Mahle filters
#3389383 - 06/05/14 06:23 AM Re: Honda ATF temp via scan tool? [Re: bulwnkl]
Trav Offline
Loc: MA, Mittelfranken.de
I have scan tools that give me this info but they are not cheap. The best and cheapest thing to use is a add on gauge.
On the Honda an in-line electric sending unit will work fine. You could even do a 2 or 3 gauge pod and add engine oil temp and pressure.
#3389446 - 06/05/14 07:45 AM Re: Honda ATF temp via scan tool? [Re: bulwnkl]
supton Online   content
Loc: NH
Scanguage do the trick? Found this thread:
http://www.ridgelineownersclub.com/forums/showthread.php?t=45402
and it indicates that SG will read trans temp.
Looks like the temp sensor wiring is easy to get to:
http://www.hondapartscheap.com/honda/rid...temperature-atf
Part #14.
2011 Toyota Camry, base, 6spd manual, 119k, hers
2010 Toyota Tundra double cab, 4.6L, auto, 129k, his
#3389805 - 06/05/14 02:01 PM Re: Honda ATF temp via scan tool? [Re: bulwnkl]
Hokiefyd Offline
Loc: Top of Virginia
On both of our Hondas, Torque Pro displays the "transmission fluid temperature", but it's simply a mirror of the "engine coolant temperature". It looks like you can program a custom PID into a ScanGauge; that's neat. I don't think you can do this with Torque Pro.
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#3389888 - 06/05/14 03:43 PM Re: Honda ATF temp via scan tool? [Re: bulwnkl]
bulwnkl Offline
Loc: Arizona
The BB Playbook will run most all Android apps. That's why Google no longer lets you download apps from websites; only from them and only if you have a registered android phone. wink
That ROC thread is interesting. My search there missed it, and my live-person phone call to Linear Logic yesterday conflicted with what that person has. I'll have to give LL another call.
On a related note, I know where the factory ATF temp sensor is, and I know what 'normal operating temp' should be, voltage-wise. What I don't know is what temp is 'normal' to Honda's FSM writers. smile The range of voltage the FSM says the sending unit should show me is 0.2 - 4.0 V, with 'normal operating temp' at 1.8 V. Any thoughts as to whether this general info is likely compatible with aftermarket gauges, such as Autometers?
Thanks for the help everyone!
#3390011 - 06/05/14 05:41 PM Re: Honda ATF temp via scan tool? [Re: bulwnkl]
Vikas Offline
Loc: NorthEast
Isn't there an external thermocouple which you can hook up to the transmission case to get an idea about the fluid temperature? It would be lot simpler to do that way rather than splicing in to factory internal temperature sensor.
#3390069 - 06/05/14 07:14 PM Re: Honda ATF temp via scan tool? [Re: Vikas]
bulwnkl Offline
Loc: Arizona
The factory sensor is easy to access, and the wiring would be super-simple; just 2 posi-taps and done.
I've considered an external thermocouple. What's the correlation between external case temp and sump or internal temp in any particular area? IME external pan temps aren't that tightly correlated with bulk or specific-area internal temps on engines. Not so sure about A/Ts.
#3390237 - 06/05/14 10:58 PM Re: Honda ATF temp via scan tool? [Re: Vikas]
Loc: Northeast
Oh do hold up!
It's not perfect, But it's damm close to a multiple thousand dollar SnapOn and Autel scan tools. And if you have a Ford, FORScan is really close to a IDS.
It's Pro, for $25.
2016
#3390419 - 06/06/14 07:13 AM Re: Honda ATF temp via scan tool? [Re: bulwnkl]
Vikas Offline
Loc: NorthEast
I (niether should you) don't expect a $4.95 scanner to substitute $5000 scanner (and annual fee of $5000 to go with it). Granted, that $4.95 scanner does beat all of the other $495 scanners in the market.
And that is NOT a slam on Ian or Torque Pro; it is the best option for us aka non-professionals.
I was not aware of the FORScan. Are there other add-ons for other manufacturers aka HDS/Techstream emulations?
#3391128 - 06/06/14 10:04 PM Re: Honda ATF temp via scan tool? [Re: Vikas]
Loc: Northeast
Understood......
I'd get a Maxidas if I could score the cheap $250 eBay ones
FORScan is a CANBUS FoMoCo exclusive only, there's some support for hybrids, Jag, LR, Mazda etc.....
For Honda's I don't have a solution
There's some knockoff Techstreams on eBay that kinda work, I've gotta get me one.
I hear highly of AutoEnginuity, but $.
2016
#3391183 - 06/06/14 11:28 PM Re: Honda ATF temp via scan tool? [Re: bulwnkl]
Vikas Offline
Loc: NorthEast
I was asking if Torque Pro has any extensions or add-ons for Honda or Toyota.
#3391559 - 06/07/14 04:14 PM Re: Honda ATF temp via scan tool? [Re: Vikas]
Loc: Northeast
http://torque-bhp.com/wiki/Plugins
Unfortunately, Not at this time.
But its a crowd sourced/shareware deal, so it may be created one day.
2016
Page 1 of 2 1 2 >
