postal LLV wiper switch arm broke off
by Tuffy1760
37 minutes 51 seconds ago
2GR-FE Water Pump Noise
by The Critic
Today at 03:36 AM
Castrol & Shell oil sale in Oz
by SR5
Today at 02:45 AM
UOA Mobil Delvac MX 15w40?
by nyumski
Today at 02:13 AM
2015 Silverado - Put some chrome
by Realtech214
Yesterday at 10:22 PM
Ticks!
by spasm3
Yesterday at 09:54 PM
shop didn't replace clamps on steering rack
by motor_oil_madman
Yesterday at 09:46 PM
First SSD on Xubuntu 16.04
by Eric Smith
Yesterday at 09:20 PM
Purolator Boss PBL25277
by Quattro Pete
Yesterday at 09:11 PM
Pan w/ drain plug for 62TE
by JTK
Yesterday at 09:04 PM
2007 Explorer 4.0 upper and lower intake gaskets.
by ls1mike
Yesterday at 08:55 PM
Cars... where they belong: On the road!!!
by Spillips
Yesterday at 08:29 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
34 registered (alarmguy, bbhero, Abakev, Astro_Guy, BlueOvalFitter, bandz7, 3 invisible), 704 Guests and 314 Spiders online.
57779 Members
66 Forums
248392 Topics
Page 1 of 2 1 2 >
#3310443 - 03/13/14 10:53 AM 50w drive train oil
sdan27 Offline
Loc: Michigan
Would a non-synthetic 50w drive train oil that is TO-4 rated be suitable for us in a 10-speed Eaton transmission in a semi-truck? The truck and transmission are 2002 model years and are well past any kind of warranty coverage. The truck is only driven locally and this time of year only drives 20-30 miles a day.
'94 F250 Powerstroke. LF9691 primary oil. AH1141 air filter. FS1282, FF5320 fuel filter. WF2071 coolant filter.
#3311440 - 03/14/14 07:42 AM Re: 50w drive train oil [Re: sdan27]
supercity Offline
Loc: Australia
It should be, above freezing temperatures.
#3312000 - 03/14/14 04:35 PM Re: 50w drive train oil [Re: sdan27]
2hellandback Offline
Loc: Idaho
Why would you give up better fuel economy and better shifting? and most likely better protection ? Even if your 50w was free you would still come out ahead using synthetic...
Edited by 2hellandback (03/14/14 04:37 PM)
#3318129 - 03/20/14 02:46 PM Re: 50w drive train oil [Re: sdan27]
camelCase Offline
Loc: Southeastern, USA
Yeah, in a truck like that I wouldn't cheap out on a non-synthetic. Bite the bullet now and get a better fluid. It will shift better, protect better, and last longer.
#3383533 - 05/28/14 09:12 PM Re: 50w drive train oil [Re: sdan27]
used_0il Offline
Loc: canada
The answer is yes, not why, what if or how come.
#3383536 - 05/28/14 09:15 PM Re: 50w drive train oil [Re: sdan27]
Clevy Offline
Loc: Saskatoon canada
What is 50w?
I've never seen anything labelled even remotely as such. So please specify what product you are referring to because 50w isn't a thing.
2006 Charger RT
Miles x 2 per oil filter
#3383667 - 05/29/14 12:35 AM Re: 50w drive train oil [Re: Clevy]
MolaKule Offline
Loc: Iowegia - USA
Originally Posted By: Clevy
What is 50w?
50W transmission lubes are common in multi-gear ratio HD truck transmissions.
I would ask, what is the speced transmission oil weight, and is this a PowerShift design?
Edited by MolaKule (05/29/14 12:36 AM)
Some days I amaze myself. The other days I leave the keys in the Refrigerator. smile
#3383899 - 05/29/14 11:48 AM Re: 50w drive train oil [Re: sdan27]
Texan4Life Offline
Loc: Texas
Depends what does eaton spec for the transmission?
2005 Dodge Ram 1500, 5.7L
[Current Fill: PP 0w-20][Baldwin B2-HPG]
#3384195 - 05/29/14 06:17 PM Re: 50w drive train oil [Re: sdan27]
Doug Hillary Offline
Loc: Airlie Beach Australia
Hi,
sdan27 - As Molakule states this is a common viscosity in Eaton multispeed transmissions. Check the correct viscosity for yours though - the TO4 requirement is a OEM Spec
I used both Castrol and Delvac Syn 50 lubricants in my 13spd and 18spd Eaton gearboxes for many years. They reduced operating temps by about <10C over a mineral lubricant.
These had a Pour Point <40F and a viscosity around 17cSt @ 100C
They greatly extended seal and component life along with greatly extended OCIs (out to 1m> kms)
Regards
Doug
#3386429 - 06/01/14 05:05 PM Re: 50w drive train oil [Re: sdan27]
xxch4osxx Offline
Loc: Cedarbrae, Ontario
The 18 speed trannys at work all take 50 weight oil. The boss buys the Delvac brand. The only reason he needed to change it is because the coolant/transmission oil cooler started leaking coolant into the transmission oil and he had to flush the transmission a few times to get all of the coolant out.
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
#3389158 - 06/04/14 09:56 PM Re: 50w drive train oil [Re: sdan27]
chevrofreak Offline
Loc: Billings, MT
Citgo Citgear synthetic HD 50 is a good inexpensive option
I <3 Red Line oil
#3412937 - 07/02/14 08:55 PM Re: 50w drive train oil [Re: chevrofreak]
krismoriah72 Offline
Loc: wv
50wt synthetic change every 2000hrs or every 5 yrs
80w90 change every 500hrs
If ur keeping the truck 5 more years fill with syn and forget it. $140 a bucket.
If ur keeping the truck 1 year..fill it with 80W90 and forget it. $60 a bucket
#3879610 - 10/08/15 10:54 PM Re: 50w drive train oil [Re: sdan27]
JR Offline
Loc: Michigan born but my heart bel...
Synthetic 50wt only. If this is not followed, you will schred the trans into a slush box.
-harvey
#3879614 - 10/08/15 10:56 PM Re: 50w drive train oil [Re: MolaKule]
Clevy Offline
What is 50w?
Thank you.
2006 Charger RT
#3879618 - 10/08/15 10:59 PM Re: 50w drive train oil [Re: Doug Hillary]
Clevy Offline
Originally Posted By: Doug Hillary
Hi,
Now that is great info to know.
I'm impressed that temps were reduced. I assume any reduction in heat will affect component life making it last longer between service.
I wonder how this stuff would work in a Harley tranny.
Not trying to thread jack,just thinking out loud
2006 Charger RT
Page 1 of 2 1 2 >
