car idles fines and starts right up, unlike my Toyotas which take 2-3 seconds before starting up, this civic probably starts in a split second.
The civic seems to have original wires, distributor rotor & cap. Now I personally don't know of anyone who replaces the distributor rotor & cap ever...but honda-tech.com and others seem to suggest changing it. How would I know if mine needs changing? other then "OMG it is 18-19 years old" logic, is there a way of testing it? I figured I need a voltmeter to test the wires, what is the range suppose to be again?
An Acura tech suggests "Measure the resistance, over 25k Ohms, replace (you will usually see 7-10k Ohms) A cheap multimeter is cheaper than a new set of wires replaced needlessly. Then with engine running, mist wires with water and watch for arcing. This will tell you if the insulation is cracked. If you see arcing, replace all the wires. I have never seen a set of wires go bad with less than 200K on the odometer."
There is a really good deal from AAP currently. All of these items have limited lifetime replacement, which sounds awesome. I have until Saturday to score free home shipping, so please let me know your suggestions soon, Thank You.
NGK spark plug wires 32.48 + tax shipped
BWD distributor rotor 11.39 + tax shipped
BWD distributor cap 10.25 + tax shipped
Since this is related to spark, I forgot to mention I easily get 32-33 mpg @ 70-80mph highway which falls in the range of the EPA suggested mpg for my car.
