So yesterday I decided to change the air filter on my wifes 2007 Cadillac AWD V-6 STS 160,000 miles. When I pulled out the old Air Filter I thought I saw water in the bottom of the air box so I pulled out the top of the box and the plastic piping that connects the air box to the engine intake to clean it.
What I found wasn't water but engine oil in both the pipe and air box(intake manifold was dry). No problem I say! I just need to get a new PCV valve and that should take care of it.
I go to NAPA and Autozone and they both say they don't list or stock a PCV for this car. OK, I'll just run down the street and stop off at the Chevy/Buick/GMC Dealer and get one. Guess what? No Dice. In the diagram they show the hose coming out of the rear end of the left valve cover to the air intake pipe and a"fitting engine crank case ventilation" Part #12578316 but no PCV valve.
So I have 2 questions:
1. Does this car have a PCV, might it be hidden inside the engine?
2. What could be causing oil to leave the left valve cover and travel to the Air Box?
