Top Sirloin?
by totegoat
23 minutes 55 seconds ago
Has anyone met a long distance friend?
by motor_oil_madman
44 minutes 26 seconds ago
Daimler's MyTaxi
by Y_K
Today at 09:36 AM
Snatch trap for boat tow rope
by outoforder
Today at 09:20 AM
Why do people put trash in other peoples truck bed
by motor_oil_madman
Today at 09:07 AM
P/S calls for Dexron II or III, Maxlife OK?
by K20FA5
Today at 09:04 AM
2008 Honda Civic slow to start
by InhalingBullets
Today at 08:45 AM
Top Search Today..........
by AirgunSavant
Today at 08:15 AM
Oil choice for Hyundai Veloster
by Kyonic
Today at 08:01 AM
Paul Simon
by Donald
Today at 07:57 AM
2000 Nissan Sentra cranks but will not turn over
by Rtstrider
Today at 07:57 AM
For Sale 12- AC Delco PF 48 oil filters
by dson
Today at 07:39 AM
lowsapsdieseloil, kit2523, rfabrocini, Tobin28, r0k
58600 Registered Users
99 registered (anonobomber, Anduril, Asterix, 09_GXP, Alfred_B, 4 invisible), 1703 Guests and 18 Spiders online.
58600 Members
66 Forums
252262 Topics
Page 1 of 2 1 2 >
#3388300 - 06/03/14 10:29 PM Poor quality power in building
dparm Offline
Loc: Chicago, IL
I've had a bit of an epiphany lately, and it's that my previous apartment building might have had some really poor quality power. It was a high-rise built in the 1970s with 16 floors. Below is a list of strange electronic/computer problems I had in the two years I lived there:
1. Ground loop hum from high-end JBL monitors
Eventually remedied it with a ground loop isolator, but ferrite caps and different power strips/outlets did nothing.
2. Blown caps in one of the aforementioned JBL monitors
One speaker would intermittently hiss and squeal, sometimes very loudly. Was serviced under warranty and several capacitors were replaced. These speakers have two amplifiers each (tweeter + woofer).
3. Computer power supply causing weird POST errors on motherboard
The same Thermaltake PSU + eVGA mobo combo worked perfectly for a year in the previous apartment, then I moved to this place and within a year it would randomly refuse to POST or have strange freezing problems. RMA'd the PSU and the problem went away.
4. Same motherboard started having weird POST errors again
Replaced the Thermaltake PSU with a high-end Corsair unit and the problem went away for about 6 months.
5. Same motherboard had different POST problems
Similar issue but different symptoms. All PSU pins tested fine and voltages were well within spec and very consistent. Motherboard was out of warranty so I decided to just replace it with the latest and greatest. This new mobo had 8-phase PWM and was one of the highest rated/most-awarded ever (Asus Z87-A).
6. New motherboard and PSU has sporadic POST problems
Same issue as before, even though the Asus mobo was a totally different design and manufacturer. Intermittently would not POST and indicated a CPU fault, but flipping the switch on the PSU or hitting reset repeatedly seemed to correct it. Found small percentage of people complaining of this problem with my particular PSU + mobo combination. Same issue happened even when I moved to my current place, but less often. RMA'd the Corsair PSU and got a brand new one.
7. USB DAC developed very strange hiss with certain USB cables
I use an Audinst HUD-MX1 external DAC on my computer and it developed a very strange hiss shortly after I moved in that you could only hear if the USB cable was actually UNPLUGGED, but only from the computer (not from the DAC itself). I never had this issue before.
8. Two different power strips randomly indicated "wiring fault"
The power strips I use have an LED that says you have a wiring problem in your building. In different rooms, on different circuits, they would randomly flash this light on for a few days then it would mysteriously go away.
9. Every 6 months, the building would lose one phase of power
ComEd would inevitably come out to fix it, but during that time I would see bizarre behavior from my electronics. The speakers I mentioned above would power on but didn't produce any sound, for example.
10. Certain light bulbs needed replacing every 6 months
In particular, the 50/100/150 3-way bulbs in two of my lamps on different circuits could barely make it 6 months before needing replacement.
So am I totally crazy here, or did my previous apartment clearly have power problems? It seemed really weird that so many of my electronics had bizarre problems I could never really pinpoint ever since I moved in there. Even brand new stuff developed odd problems very quickly.
I've only been in my new apartment for a week and a half, but all of the above problems I listed are totally absent.
Somewhat OT, new view from my family room:
2011 BMW M3 sedan ZCP
#3388309 - 06/03/14 10:40 PM Re: Poor quality power in building [Re: dparm]
zrxkawboy Offline
Loc: SD
Yeah, sure sounds like it to me. BTW, built in the 70s...did they use Al wire in apartment buildings?
"Think of all the Ford owners who will someday want an automobile." John Dodge
#3388314 - 06/03/14 10:45 PM Re: Poor quality power in building [Re: zrxkawboy]
dparm Offline
Loc: Chicago, IL
Dunno. How could I have tested that without ripping things up?
Logic and previously living with an electrical engineer seem to say that power supplies should have cleaned up the [censored] input power (that's their primary job after all), but perhaps it was just too much for them to deal with on a constant basis. My computer and the speakers were running almost 24/7 and those were the most problematic.
#3388320 - 06/03/14 10:52 PM Re: Poor quality power in building [Re: dparm]
Barkleymut Offline
Loc: Richmond, VA
I used to work in sales for a large copier company. We would not sell a $5k + copier unless it had a fancy "line conditioner". They were at least $50 and looked like this http://www.ebay.com/itm/Ikon-ESP-Transio...=item58a0a1b5fd
I saw a few demos of these units and they really seemed to smooth out the peaks and valleys of the power supply.
09 Vue(95K) 2.4 4spd AT -PU 5w30 / 09 Flex(52K)3.5L PU / Moms car 04 Pilot(105K) 5w20 PP + Puro
#3388323 - 06/03/14 10:57 PM Re: Poor quality power in building [Re: dparm]
spackard Offline
Loc: CA
Something like a CyberPower CP1500AVRLCD should give you a count of overvoltage, undervoltage events, and it's reasonably priced.
#3388344 - 06/04/14 12:13 AM Re: Poor quality power in building [Re: dparm]
mattwithcats Offline
Loc: Virginia
Need to use a UPS with a power conditioner and check for aluminum wiring....
Edited by mattwithcats (06/04/14 12:19 AM)
2009 Smart Pure
Pennzoil Platinum Euro 5W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
#3388350 - 06/04/14 12:41 AM Re: Poor quality power in building [Re: spackard]
RazorsEdge Offline
Loc: USA
thumbsup We've got one for our 55-inch Vizio TV and computer.
#3388408 - 06/04/14 07:09 AM Re: Poor quality power in building [Re: dparm]
dparm Offline
Loc: Chicago, IL
Consumer grade UPSes and line conditioners are a joke. We had a good discussion on it here once before to prove that, and I have friends who are EEs that said they're effectively worthless unless you have an industrial grade one and use highly-sensitive instruments.
The whole point of a power supply is that it filters out garbage and cleans up the power before it hits the actual electronics. So, in a way, a power supply IS a line conditioner.
#3388486 - 06/04/14 09:10 AM Re: Poor quality power in building [Re: dparm]
4wheeldog Offline
Loc: East Mountains, NM
The question is whether the problem is in the power supply to the building, or a problem with the equipment/wiring in the building itself.
If it is dirty power being supplied, a relatively cheap way to clean it up is to install your own transformer between the supplied power and the building.
But I suspect the problem is actually something haywire in the building......Probably lot of things haywire. I would start with getting someone with the correct equipment doing a thermal survey of all the power panels in the building. Not cheap, but a whole lot less expensive than a fire. Just sayin'.
#3388500 - 06/04/14 09:26 AM Re: Poor quality power in building [Re: dparm]
IndyIan Offline
Loc: Ontario, Canada
We get some weird stuff in our buildings, with over and under voltage in some legs of 110V. Usually its a photocopier that keeps having issues that gets the investigation going. Desktop computers though don't seem to care much at all though.
07 Focus ZXW, 5spd manual, 139km VWB 7.5W25
06 CRV, 5 spd auto AWD, 250km M1 EP 5W30
#3388555 - 06/04/14 10:36 AM Re: Poor quality power in building [Re: dparm]
Garak Offline
Loc: Regina, Saskatchewan, Canada
You still might be able to see some benefits, at least with respect to a few devices. When I lived in a rural area some years back, the power was terrible. Components started to fail in my computer. I couldn't keep light bulbs in the place. I did go to a UPS, and at least it kept the computer on a somewhat even keel. Obviously, my light bulbs never saw an improved lifespan. wink At the time, they even marketed light bulbs for rural areas with more flaky power, believe it or not.
My big issue wasn't just with the power being dirty or poor quality, but far too frequent big dips in voltage. I think that's about the only thing the UPS really helped with.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3388597 - 06/04/14 11:46 AM Re: Poor quality power in building [Re: dparm]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Traditional Audio power supplies are very rudimentary, many withwout chokes, and amp output is sensitive to line condition + noise. Computer supplies shold be more robust and have low ripple and noise.
If you have a triac ( or other high power switched supply in uses) somewhere taking a notch out of the line, you will know it through really flakey operation on many devices. At Work, I had my room of parts-handling Seiko robots go crazy (when a laser cutter was running in the next room- which I didn't know at the time) After much hair pulling, Finally Scope'd the line with a tech and it had a 50v notch for 10% or the period missing. NAsty! The modern world is noisier still. IS there data xfer allowed on the neutral leg yet?
Edited by ARCOgraphite (06/04/14 11:47 AM)
2014 Nissan Rogue S CVT, OC#4 19671mi-Castrol EDGE EP 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#6 41243mi-M1EP 0W20+Subaru Filter
#3388610 - 06/04/14 11:59 AM Re: Poor quality power in building [Re: dparm]
Quest Offline
Loc: beaver land EH?
to OP:
Your power line issue is multifaucet'ed: noisy coupled with dips/spikes and so on.
If you live close to industrial area, you'll get these kinds of problems from large motors from industrial side.
The only true way to determine how "bad" your situation is is to find some tech (or your experienced EE friend) to scope the line over a period of time and watch for spikes, dips, EMI/RFI related noise, etc. and then take it from there.
If the situation is beyond your handling/managing, perhaps consider moving to another (assuming power is cleaner there) location?
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#3388615 - 06/04/14 12:03 PM Re: Poor quality power in building [Re: Quest]
dparm Offline
Loc: Chicago, IL
I already did move, as I stated. It was just an interesting conclusion I drew.
As to the earlier comment about PSUs being rudimentary, none of my audio equipment is low-end or even really consumer-grade. My speakers are JBL Pro monitors designed for studio use. They're not really built to the lowest possible price...they are built for performance.
#3388642 - 06/04/14 12:24 PM Re: Poor quality power in building [Re: dparm]
Garak Offline
Yep, if it were me, I'd probably worry about that stuff the most. Back when I lived in a more rural setting, the computer was likely the most sensitive of all my electronics. The rest was limited to a CRT TV, a VCR, and a rather pedestrian CD changer. wink
Page 1 of 2 1 2 >
