Got me a new Stihl FS 56 trimmer today
by daddi
08/30/16 01:02 PM
Truck cap lights.
by wolfehunter
08/30/16 12:12 PM
filters and oem specs
by mobilaltima
08/30/16 11:50 AM
H11 bulb options
by asiancivicmaniac
08/30/16 11:47 AM
Engine oil accidently added into transmission
by Mazatrol
08/30/16 09:51 AM
Oil for 1996 Mazda B4000 pickup
by schuylkill
08/30/16 09:16 AM
Shell gas $80 rewards cars for $52 Deal ends 9-1
by gojoneeded
08/30/16 09:12 AM
Cleaning a carpet stain....Help!
by mjk
08/30/16 07:39 AM
Windshield: can it be repaired?
by supton
08/30/16 07:12 AM
Sea foam for my car?
by NavyVet88
08/30/16 07:04 AM
Anyone have experience with Chinese stereos?
by 55Test
08/30/16 06:37 AM
A 14.5 billion dollar bill for Apple
by Pop_Rivit
08/30/16 05:58 AM
pperras01, Grabberblu, Dave_PPE, davebe, Logos
58964 Registered Users
81 registered (Alfred_B, asiancivicmaniac, ARCOgraphite, 87sammy, 74Scout, 09_GXP, 7 invisible), 1633 Guests and 9 Spiders online.
58964 Members
66 Forums
253772 Topics
Page 7 of 8 < 1 2 3 4 5 6 7 8 >
#3392971 - 06/09/14 11:37 AM Re: Scotty Kilmer: Don't use MMO! [Re: Mephy]
kschachn Offline
Loc: Upper Midwest
Why would you think that? Is that a manufacturer's claim for the product?
Originally Posted By: Mephy
I use it in the fuel sometimes.
The ratio is very lean 1:800.
I think the main beneficial effect is that better the atomization of fuel.
I do not believe higher dosage will do better.
I see It just as fuel conditioner.
1994 BMW 530i, 206K
1996 Honda Accord, 218K
1999 Toyota Sienna, 350K
2000 Toyota ECHO, 255K
#3393807 - 06/10/14 09:28 AM Re: Scotty Kilmer: Don't use MMO! [Re: kschachn]
Mephy Offline
Loc: Toronto
No,
from my experience, I have better combustion.
I can see from the mileage, the performance of the car and the cleanliness of the exhausting pipe.
Mobil 1 0-40 European Formula
EA Amsoil oil filter
20.000 km OCI.
One bottle of PI before OCI.
Amsoil Interceptor/Dominator 50:50 mix 600:1 each fill up
#3397046 - 06/13/14 10:39 PM Re: Scotty Kilmer: Don't use MMO! [Re: MileHigh18]
friendly_jacek Offline
Loc: southeast US
Originally Posted By: MileHigh18
I usually watch Scotty Kilmer on YouTube, and noticed he commented that you shouldn't use MMO in a modern car because it ruins the catalytic converter. Is there any truth to this?
Yes. 1000 ppm P. P poisons cat converter.
#3397203 - 06/14/14 06:56 AM Re: Scotty Kilmer: Don't use MMO! [Re: friendly_jacek]
dave5358 Offline
Loc: North Bend
If you check the FAQ on the MMO Website it says:
Q: Will MMO cause any damage to oxygen sensors, fuel sensors or catalytic converters?
A: No. MMO has undergone rigorous testing to ensure the safety of all internal components in your vehicle including highly-sensitive oxygen sensors, fuel sensors and catalytic converters.
2006 Forester XT
2008 Corolla LE
#3397381 - 06/14/14 12:20 PM Re: Scotty Kilmer: Don't use MMO! [Re: dave5358]
Loc: southeast US
I don't know how they "tested" and I don't care what they say.
Facts speak for themselves. The damage could be slow and may take more than 100,000 miles to declare itself.
If one has to have add things to gasoline, there are things that don't have sulfur or phosphorus.
I'm not bashing MMO, I use it for piston soaks when needed.
#3397390 - 06/14/14 12:35 PM Re: Scotty Kilmer: Don't use MMO! [Re: MileHigh18]
demarpaint Offline
Loc: NY
I had a little over 212,000 miles when I junked my Aerostar. I used MMO in the gas since I bought it with about 50K miles on it. It went to the junk yard with the original CC and 02 sensor. My 88 E-150 was fed MMO via an inverse oiler since it was about 6 months old, I think. The original CC is still in there as well. I did change the 02 sensor although it wasn't needed. I've used it in the gas in other vehicles as well since the mid 70's. Honestly I believe them when they say is is CC and O2 sensor safe. Opinions vary.
God Bless Our Troops
#3397463 - 06/14/14 03:11 PM Re: Scotty Kilmer: Don't use MMO! [Re: friendly_jacek]
dave5358 Offline
Loc: North Bend
Facts speak for themselves. The damage could be slow and may take more than 100,000 miles to declare itself. If one has to have add things to gasoline, there are things that don't have sulfur or phosphorus.
Per the administrator over at MarvelMysteryOil.com the sulfer content is 1.6ppm. Gasoline in California is 30ppm sulfur; in the rest of the country it may be as high as 300ppm. MMO suggests not using their products in diesel engines build after 2007 - which engines are designed to use super-low sulfur (15ppm) fuel. The concern is that it might affect the vehicle's warranty - nothing else.
The phosphorous is Tricresyl Phosphate, an organophosphate - a very good AW/EP additive, which is also in most motor oils. The TCP content is slightly higher than most motor oils, but given the low MMO fuel additive rate, it's unclear why this would have an adverse effect (or any effect) on the cat.
If using MMO takes 100,000 miles to 'declare itself', you've probably gotten your money's worth out of your catalytic converter. Failures at that mileage are common, out of warranty and have nothing to do with using MMO or not.
'Failure' is a slippery term - it many cases all that has happened is that the vehicle throws a P0420 CEL code. Several things can cause this, including oxygen sensor issues. But, dealers love to replace parts. Replacing a catalytic converter, whether it needs it or not, probably wins them a prize! To the extent it really is the catalytic converter issue, you might Google 'citrus clean catalytic converter'.
2006 Forester XT
2008 Corolla LE
#3397510 - 06/14/14 04:24 PM Re: Scotty Kilmer: Don't use MMO! [Re: MileHigh18]
Triton_330 Offline
Loc: Illinois, USA
Albeit I'm joining in on this discussion a bit late in the game... BUT... here's my 2 or 3 cents anyways.
One thing that hasn't yet been stated, and that IMO is important is... where you get your gas from! I live in a town where the only two gas stations are Casey's gas. The good old boys down at Oreilly's (in a town 12 miles away), as well as the guys at Autozone (in another town 14 miles away) will both tell any customer how BAD Casey's gas is. It's absolutely one of the worst gasses of the quote unquote bad gas stations. One guy at Oreilly's told me he ran Casey's gas once in his mustang (where normally he uses BP) and that just that one fill up alone made his car feel sluggish and ran badly. A later fill up at BP solved the problem. SO, what's my point? Do I think MMO is good? Simply put, MMO, or even other additives like STP gas additive, or those other better ones like Techron, all will help the fuel quality of bad gas, no doubt about it. How do I know. Well, some nay-sayers may not think a simple anecdotal piece of evidence stands to represent any meaning at all, but I ignore them. My F-150 runs smoother with BP, and I try to get it when I'm out of town, but when I have to fill up in town with Casey's, you'd better believe I'm going to throw in some kind of fuel additive, regardless of brand. With that being said, some of my favorites are Techron, STP, Gumout, MMO, and Regane. *Cough* but definitely not Lucas! Call whatever fallacy as you might, but I know from firsthand experience that MMO DOES help with bad quality gas.
The uncertainty of whether my cat will become clogged up by using MMO mixed with bad gas... Heck, I just don't care. All I care is that my butt dyno tells me that running MMO with Casey's gas does help. Nonetheless, straight up BP gas (without any additive) still makes my truck run better than Casey's gas with MMO (or anything else). But, in a small country town with only Casey's, it's difficult getting better gas unless I'm out of town.
'01 Ford F-150 XLT 5.4L w/K&N CAI ~127k
-> PP HM 5w-20 w/Fram Ultra
'89 Chevy Camaro RS 305 TBI ~48k
-> Pennzoil YB 5w-30 w/AC Delco
#3398398 - 06/15/14 07:28 PM Re: Scotty Kilmer: Don't use MMO! [Re: MileHigh18]
morris Offline
Loc: ks, wichita
"compression fitting" NOT on my TWK. i have been using MMO for 30 years but Don cant tell when ill have my first fail!!!!
#3435519 - 07/25/14 04:44 PM Re: Scotty Kilmer: Don't use MMO! [Re: MileHigh18]
webfors Offline
Loc: Great White North.. eh
MMO and Stabil in all my gas storage and small engines has resulted in gas that can go a year and start on the first or second pull. I never drain the gas for long term storage, do not fog the cylinders, and keep the carb bowl full. I can go outside right now and start my snowblower with one pull. Want a video? lol
What does that mean? No hassles.
Friends that don't have a similar regiment are calling their small engine mechanic almost yearly to get them running again. That's a massive hassle in my opinion.
15 Civic, AFE 0w20, FU OF
13 Dodge GC, VWB 5w20, Purolator OF
13 SFV650, T6 5w40, OEM OF
07 VS800, OEM 10w40, K&N OF
Small engines; RT5 10w30
#3435669 - 07/25/14 07:17 PM Re: Scotty Kilmer: Don't use MMO! [Re: dave5358]
Trav Offline
Loc: MA, Mittelfranken.de
If the numbers are correct i cant see how this can cause a sulfur issue.
#3435759 - 07/25/14 08:27 PM Re: Scotty Kilmer: Don't use MMO! [Re: Trav]
dave5358 Offline
Loc: North Bend
There is no sulfur issue with MMO, except in the particular case of the low-sulfur diesels mentioned above.
2006 Forester XT
2008 Corolla LE
#3457292 - 08/16/14 02:31 PM Re: Scotty Kilmer: Don't use MMO! [Re: MileHigh18]
Greasymechtech Offline
Loc: Paradise of Florida
http://ampcolubes.com/home/benefits
We should start collection and send a gallon of mmo and an inverse oiler to scottynilmer.
At what point should a lurker start posting :-)
#3457322 - 08/16/14 03:02 PM Re: Scotty Kilmer: Don't use MMO! [Re: MileHigh18]
Volvohead Offline
Loc: SE Pa
I don't know about today's engines with cats, but we used a lot of this stuff in engines calling for lead (mainly pre-'71) once the leaded fuels went away. And it worked in keeping the valve seats from wearing on unleaded. This was in carbureted delivery systems.
As far as the other posters claiming an effective octane loss, you've got to be kidding. Eight to sixteen ounces in 20 to 24 gallons of gasoline isn't going to reduce the octane in a meaningful measure. We had other ways to compensate for the octane loss in those fuels anyway. But that was enough to keep the older valve seats happy.
But in a modern FI engine with a cat? I'm skeptical of the benefits. I also think there are better additives for a crankcase these days.
As far as this Kilmer guy, never saw him. Sounds like a pitchman to me.
#3459217 - 08/19/14 01:31 AM Re: Scotty Kilmer: Don't use MMO! [Re: dave5358]
babbittd Offline
Loc: Massachusetts
Consumers Union (the Consumer Reports folks) occupy a very unique position - they test brand names, generally without the manufacturer's permission. And, even they get sued. But they are so wrapped in 'public purpose' they are almost an arm of the government. Sadly, they haven't done a review of oils or additives that i have found
Surely you have seen this?
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/259274/Consumer_Reports_1996_NYC_Taxi
