There is a broad awareness that grit in the oil from airborne particles is increases engine wear, but recent factual published studies remain uncommon. "A Study in Sand: Investigating the Damage Done by Desert Dust," by Mark Townsend, and published in"Lubes'N'Greases," February 2012, studies the issue in some detail. Some fragmentary conclusions: The roadside dust samples had an average particle size of 253 microns. The most wear-increasing dust particle sizes are in the 1 to 125-micron range per additive maker Lubrizol. Air filters work best down only to the 100 microns level. The dust comes from both the air and and roadside. Photographs of material wear shows major wear increases from higher dust contaminants in oil. I infer from the study that modern oil and air filters are far from fully effective in removing dust particles (and, by implication, all particles reaching the oil supply regardless of origin).
Lessons? Very few. Dust concentrations, size distribution, and abrasiveness, likely vary widely both geographically and seasonally. The driver has no effective ongoing knowledge, though driving in a dust storm is an obvious insult to oil cleanliness. The study did not examine differences in air and oil filter quality in car brands or filter brands. A fair recommendation is, as the study suggests, to change oil more often if the engine is operated in a high dust environment. This is a very imprecise recommendation since important facts are probably not knowable to the vehicle operator. Perhaps future engines can come with better oil contamination sensors. I was most surprised by the relatively low filtering effectiveness of engine air filters. Perhaps that is why the maker of my car can get by with a 40,000 mile suggested engine air filter replacement schedule. The filter lasts a long time by not doing much.
