'91 Mazda B2600i transfer case and trans oil?
by Jason280
46 minutes 9 seconds ago
How to cut power to breaker box ?
by Merkava_4
Today at 02:21 AM
Spark plugs in hi-per applications
by mjoekingz28
Today at 01:07 AM
OK, before I lube it ...
by BrocLuno
Today at 12:53 AM
Toyota Japan Fluid SDS
by SXE10
Yesterday at 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
Yesterday at 11:25 PM
Considering a differential swap
by buck91
Yesterday at 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
Yesterday at 09:51 PM
Car Acronyms
by Marco620
Yesterday at 09:46 PM
Vibration with new tires - your thoughts
by Bandito440
Yesterday at 09:41 PM
Carpet cleaning methods.
by Run
Yesterday at 09:26 PM
Fram XG16 4522mi 5.7 Hemi
by AntsinmyEyes
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
31 registered (Char Baby, Atesz792, b1amgm47, 1foxracing, crainholio, 4 invisible), 732 Guests and 13 Spiders online.
58295 Members
66 Forums
250918 Topics
Page 1 of 2 1 2 >
#3385803 - 05/31/14 07:27 PM Fuel injector cleaner is damaging??
lawman1909 Offline
Loc: USA
Hey guys, so my chevy cruze is starting to feel slower and I was told it may be my fuel injectors. I then said I would just get fuel injector cleaner and dump a bottle in my tank, and immediately the counter clerk said no, those are bad and can blow the seals and hurt my injectors! Is this true? Or am I safe to try it out and will it help?
2014 Honda CR-V AWD LX
M1 0W-20 EP/Fram Ultra 7317
Bless all LEO's, Fire, EMS, and military personnel both active and retired. USA! USA!
#3385807 - 05/31/14 07:36 PM Re: Fuel injector cleaner is damaging?? [Re: lawman1909]
Eddie Offline
Loc: Florida, Cape Coral
I have used TECHRON SYSTEM CLEANER for 20 years and never a problem. Sometimes self appointed experts give bad advice. Ed
CX5 Touring 2.5L :-)
#3385815 - 05/31/14 07:45 PM Re: Fuel injector cleaner is damaging?? [Re: lawman1909]
dave1251 Offline
Loc: Maricopa, AZ
Depends on what type of fuel injector cleaner is used. But the PEA cleaners you can buy off the shelf are good and relatively safe.
don't use.
#3385820 - 05/31/14 07:56 PM Re: Fuel injector cleaner is damaging?? [Re: lawman1909]
fdcg27 Offline
Loc: OH
No name-brand fuel system cleaner is going to hurt your car in any way.
Techron, Gumout, Valvoline, 3M and Red Line are all brands that contain PEA, the stuff that cleans without leaving any residue and none of these will do any harm.
It's possible that some solvent based products might cause problems, but many members have used solvents like Kreen and Seafoam in their fuel with only good results.
There's also MMO, which may work and seems to cause no harm for those here who've used it.
I'd use any PEA based fuel systmem cleaner without hesiation.
I'd have to have real problems before I considered a solvent based one.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 155K Defy 10W-40
#3385831 - 05/31/14 08:07 PM Re: Fuel injector cleaner is damaging?? [Re: lawman1909]
sciphi Offline
Loc: Upstate NY
If it's a 1LT or above with the 1.4 turbo engine, fuel injector cleaner won't help a whole lot with what you're experiencing. The weather is warmer, and warmer air means more predetonation, especially with the turbo. The only way to make it feel as quick as it does during cold weather is to run slightly higher octane fuel. 89 octane will do the trick for the summer, and once the daily temperatures go down below 60*F or so, 87 octane will be fine again.
Try a few tanks of 89 octane, and see if that helps.
2013 Toyota RAV4 XLE
2012 Chevrolet Cruze Eco
#3385845 - 05/31/14 08:25 PM Re: Fuel injector cleaner is damaging?? [Re: sciphi]
lawman1909 Offline
Loc: USA
Thanks. I actually have the 1.8L engine. I will try gumout and see how it does.
#3385871 - 05/31/14 09:11 PM Re: Fuel injector cleaner is damaging?? [Re: lawman1909]
Mud Offline
Loc: Texas
Have you changed the air filter and cleaned the MAF sensor if equipped?
57 Chevy 2drHdtop 454/400/F9
11 Mercedes E350 4Matic
11 Silverado 5.3/6spd
73 VW Bug in progress
97CVPI/02CV/03CVSport sold
#3385913 - 05/31/14 10:18 PM Re: Fuel injector cleaner is damaging?? [Re: lawman1909]
Miller88 Offline
Loc: Onondaga County
Cleaning MAF always makes a car feel better after a few years!
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3385930 - 05/31/14 10:44 PM Re: Fuel injector cleaner is damaging?? [Re: lawman1909]
901Memphis Offline
Loc: Northern Kentucky
If you get Gumout make sure you get Regane high mileage or all in one. I don't believe that the lower tier Gumout such as the gas treatment or fuel injector cleaner ones have nearly as much pea in them. Gumout has about 8 flavors of fuel additives on most shelfs.
2002 Buick Century 125k - Built 4T65e(Maxlife) - Syn Frankenbrew + XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3385958 - 05/31/14 11:29 PM Re: Fuel injector cleaner is damaging?? [Re: lawman1909]
Kuato Offline
Loc: In transit...
Listen to BITOG.
Don't listen to "counter clerk".
Your oil's condition is pure speculation until you get an UOA.
13 F150 5.0, 50k mi - Schaeffer 9000
04 Wrangler 2.4, 198k mi - Amsoil SS 5w30
#3386087 - 06/01/14 07:29 AM Re: Fuel injector cleaner is damaging?? [Re: lawman1909]
Trav Offline
Loc: MA, Mittelfranken.de
No commercially available brand name product available today will bother the injectors or seals.
A long time ago something like Nitro 9 may have caused some corrosion issues inside the early injectors.
#3386198 - 06/01/14 10:59 AM Re: Fuel injector cleaner is damaging?? [Re: lawman1909]
sciphi Offline
Loc: Upstate NY
The summer predetonation sluggishness won't affect your 1.8. Like others have said, try Gumout Regane or Chevron Techron Concentrate.
Also, I've noticed that my car's computer adapts to my driving style. If the driving has been a lot of put-putting around, it'll drive like it when I want to get on it. A good Italian tuneup to reset the computer will help also.
#3386378 - 06/01/14 04:01 PM Re: Fuel injector cleaner is damaging?? [Re: sciphi]
dailydriver Offline
Loc: Bucks County, Pa.
Are the 1.8s also direct injected, or just the 1.4 turbos??
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#3386387 - 06/01/14 04:18 PM Re: Fuel injector cleaner is damaging?? [Re: dailydriver]
sciphi Offline
Loc: Upstate NY
Neither. Both are port-injected. They were designed with DI in mind, but it wasn't implemented due to getting good fuel efficiency without it and the cost of implementing DI just for the US market on these global engines. Also, I think a engineer married a bean counter somewhere, and they decided to KISS! Fine by me, as it sidesteps all the potential DI problems and still returns great fuel economy.
#3386435 - 06/01/14 05:11 PM Re: Fuel injector cleaner is damaging?? [Re: sciphi]
dailydriver Offline
Cool, somehow I thought the 1.4 Ecotecs were DI.
Despite the problems it would incur, I wonder if the performance/power levels would have been higher with DI in the Ecotecs? shrug
M1-206 oil filter
#3387464 - 06/02/14 11:01 PM Re: Fuel injector cleaner is damaging?? [Re: lawman1909]
y_p_w Offline
Loc: SF Bay Area
Kind of an older thread, but why would someone consistently using Chevron gas need to put this stuff in the tank?
I consistently fill up at Costco. Since all stations have been upgraded to their high performance additive, I haven't bothered using any additives in a bottle. I still have some though. Not sure what to do with them other than maybe add them on the road or once in a while just to get rid of the stuff.
#3387650 - 06/03/14 08:19 AM Re: Fuel injector cleaner is damaging?? [Re: y_p_w]
dave5358 Offline
Loc: North Bend
Originally Posted By: y_p_w
...why would someone consistently using Chevron gas need to put this stuff in the tank? I consistently fill up at Costco. Since all stations have been upgraded to their high performance additive, I haven't bothered using any additives in a bottle. I still have some though. Not sure what to do with them other than maybe add them on the road or once in a while just to get rid of the stuff.
From another contemporary thread
Originally Posted By: Joenpb
A common misconception with Top Tier fuel is that it's all you need to counter the additional gumming from ethanol fuel, those additives simply aren't enough...<snip>
I'm not sure how you would test for 'too much' or 'not enough'. If you used Top Tier gasoline even occasionally, that should keep the crud level manageable, or under control. Is there any benefit to keeping the fuel system even cleaner, beyond what the included additives accomplish?
2006 Forester XT
2008 Corolla LE
#3388125 - 06/03/14 07:32 PM Re: Fuel injector cleaner is damaging?? [Re: lawman1909]
Turk Offline
Loc: MN
Let us know the results!! thumbsup
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
Page 1 of 2 1 2 >
