First time to own a diesel, anything different I should be concerned with as far as oil?
6.7L Cummins and 300 miles on it, the manual says oil change intervals of 15K which seems long for regular oil. Also, states 5w40 or 15w40 which I planned to run 5w40 synthetic Rotella if that's a good choice. I'd like to run a quality synthetic.
Quote:
In ambient temperatures above 0°F (-18°C), we recommend you use 15W-40 engine oil such
as MOPAR®, Shell Rotella® and Shell Rimula® that meets Chrysler Materials Standard
MS-10902 and the API CJ-4 engine oil category is required. Products meeting Cummins®
CES 20081 may also be used. The identification of these engine oils is typically located on
the back of the oil container.
In ambient temperatures below 0°F (-18°C), we recommend you use 5W-40 synthetic
engine oil such as MOPAR®, Shell Rotella® and Shell Rimula® that meets Chrysler
Materials Standard MS-10902 and the API CJ-4 engine oil category is required.
