I understand going with a better brand of oil. I don't understand changing the weight. If the engine is in proper order, you are misinformed in thinking that a different weight of oil is required for the hotter months. The engine runs at the same temperature and really does not "know" the difference in temperature. If that oil is not okay in the owners manual, I would suggest you do not use it. BITOG readers at this point generally accept that thin is in.
The 4.0 Jeep engine is not a modern car engine. In fact, it has more in common wit 1940s tractor engine, and will do just fine on a 40 weight oil, especially with 192,000 miles.
It would probably also "do fine" on 0W20 also. I don't see what the mileage has to do with the choice of oil weight. As far as the engine itself, it is a solid, fuel injected unit connected to a catalytic converter. It compares to an old tractor engine in the same way it compares to a moderin, DGI, Turbo engine.
Just to be clear to the OP, the car is specced for 10W 30, and there is no reason for a different weight. Using the higher weight will not deliver any advantage, but will not cause any problem either.
The engine has actually been spec'd for a 10w40 over the years it was in production. From my UOAs I have noticed it tends to shear the oil a bit. If you think an old inline six compares to a "moderin" turbo engine I think you have some reading to do.
Sorry for the typo. The engine in this vehicle was spec'd for 10W30 in all the years that the vehicle with this engine was on the market. That engine has ancient roots to be sure, but could easily be sold today with modern components. I have worked on engines both old and new, and don't need to read any more to know that moving to a 10W40 is based mostly on hokum.
