a friend of mine asked me to help change their spark plugs... the old plugs were so worn you could drive a truck through the gap and there was quite a bit of oil on the plug as i pulled them out (they do have an obvious valve cover leak so it could have been pooled up near the top of the plug and ran down as i was removing)
got the new plugs put in, everything bolted back together and it sounds like it's missing and it's throwing a code (but no CEL) i tried a few times removing and replacing the cover to see if i just wasn't getting things lined up right but it's no good
before i did this they had a P0301 code which i cleared and now they have P0300
what suggestions would you have of things to try... i was thinking maybe try new plug boots first
