Originally Posted By: used_0il
Obviously this has turned into a court case instead oil discussion. The following oil designations ; 15W30, 20W30, 25W30, 15W20, 10W20 could all be grades
Yes they could, as can 20W20, but not 25W20
but they are not SAE grades.
Yes, they are, as the xW is defined, as is the latter number...an oil that meets both the cold and the hot is labelled as an xWy, if it meets those specification.
A marketer may put 3W20 on the label, but not with SAE ahead of it. I have seen 3W20 on bottles of race oil and its a joke. At what temperature would the 3W tests be conducted at -32.5C and -37.5C? Next winter I'm going to use 3W30 because it is not going to be cold enough to warrant 0W30, but too cold for 5W30.
Strawman much ?
They are not grades in the J300 tables, and are therefore not what we/I was discussing when you claimed that 15W30 was not an SAE grade...it is, 3W is not...simple
http://www.ideas4ag-ed.com/uploads/3/7/0...l_viscosity.pdf
Better get out the butterfly net, the prozac, the thorizine....Think like a man then take away reason and accountability is about the only need for a 3W rating to ever exist. What, are 5C degree increments too far apart? Medic!
classy...bet you are the life of the party when someone disagrees with you.
