Originally Posted By: Olas
There is no specific volume in the UK for an exhaust to comply with, the only rule we have is a yearly roadworthiness inspection.
In relation to the exhaust, thew wording is;
Requirements
Complete, secure, without serious leaks and silences effectively.
Test procedure
The exhaust system must be free from serious leaks or advanced corrosion. The entire system must be securely fixed to the vehicle as intended either by using exhaust mounts or the common rubber fitting mounts. The exhaust system must have the required number of silencers for your specific make and model of car. Your vehicle may fail the MOT due to noise levels if deemed to be excessive by the MOT inspector.
So, as you can see, the volume of the exhaust must not be 'excessive'.
The MOT tester who likes the sound of triple DCOE's will have a very different perception of 'excessive' as compared to the meek MOT tester who talks as quietly as a mouse and only listens to quiet classical music.
( It pays to be friends with your tester in this country
sorry, i was thinking of an IVA, not the standard MOT...my apologies. been too long since I'd seen that particular "wheeler dealers"(Series 9, episode 8 "Gardener Douglass Cobra") and got things switched around in my head.
http://en.wikipedia.org/wiki/Single_vehicle_approval
https://www.gov.uk/vehicle-approval/individual-vehicle-approval
