Lowes charcoal sale
by Bandito440
05/28/16 10:17 PM
Jeepers Creepers! (Jeep Patriot)
by daves87rs
05/28/16 10:10 PM
Need a tire
by Leo99
05/28/16 09:58 PM
Small Engine Oil Pressure
by funflyer
05/28/16 09:06 PM
Any harm in using a Motorcraft FL910S on a Tacoma?
by jongies3
05/28/16 08:50 PM
A/C performance woes...
by SEMI_287
05/28/16 08:49 PM
Red Line 10W30 Motorcycle oil particle count
by bulwnkl
05/28/16 08:08 PM
Microgard 51334 cut open
by dlundblad
05/28/16 08:07 PM
Differential Fluid Selection..
by Warstud
05/28/16 07:13 PM
The morality of riding a bike married with kids
by fdcg27
05/28/16 07:00 PM
Best synthetic oil for cleaning out an engine.
by anylettuce
05/28/16 06:58 PM
2013 ford fusion AC stank.
by leeaspell
05/28/16 06:46 PM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
76 registered (AirgunSavant, 69GTX, 4WD, 2015_PSD, albertdi, 5 invisible), 1166 Guests and 332 Spiders online.
58001 Members
66 Forums
249543 Topics
#3380511 - 05/25/14 05:13 AM Kia picant crdi 1 litre
ac_tc Offline
Loc: sweden
My son just bought a kia crdi with a 1000cc 3 cylinder turbo diesel.
And to my surprise does the manual say use oil with atleast CH ( no gas "S" in manual.)
This thing uses hdeo...
I wonder if the servce station ever used this kind of oil?
Anyway, i use 10w-40 hdeo in all of my stuff and havent had any trouble with that.
But my son doesent have access to an electrical outlet so he cant use the cars engine heater. It can get cold in the winter here (-30 degC/ extreme, -10/ normal, +-0/ common
and he have to get this thing started.
- With what should i dilute my lovley hdeo with to get things turning??
I can get 0w-30 b4 oil.
I can get all kinds of oils in the 5w-40 range and some 5w-30.
It will se a 8 k oci wich means tvice a year. Manual says 12 k and once a year for normal duty and 6 k for severe duty. He mostly commute on a highway so it gets run rather fast/ hard wich makes me place it inbetween severe and normal duty.
Right now it gets 44-50 mpg with minimal differences between city and highway driving.
-98 Dodge Durango 5.9 4*4 HDEO 10w- 40 ci4
-04 PT Cruser GT 10w- 40 HDEO ci4
-Everything else HDEO 10w- 40 ci4/STOU 10w-30/THF
#3380559 - 05/25/14 07:12 AM Re: Kia picant crdi 1 litre [Re: ac_tc]
fdcg27 Offline
Loc: OH
If the wording in the OM is "at least CH" then any oil meeting or exceeding that API spec should be fine.
If it happens to be a dual rated fleet oil, like a CJ/SM, that should be no problem since the oil would still exceed the required diesel spec.
There are a number of API CJ/SM 5W-40s out there, any one of which would be good for cold weather.
There are also some even lighter grades of HDEOs and dual rated fleet oils sold in really cold climates. Canada sees grades that we don't see here, for example.
The 10W-40 CI oil you're using in your other cars would be fine for the warmer months.
Using a CJ oil with its relatively light add pack should be no problem with the drain intervals you contemplate, since I assume that you were using kilometers as the unit of distance.
The car sounds like a neat little fuel saver.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 155K Defy 10W-40
#3380624 - 05/25/14 08:45 AM Re: Kia picant crdi 1 litre [Re: ac_tc]
andyd Offline
Loc: Marshfield , MA
How difficult would it be to rig an extension cord? You have time to plan what ever you do.
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3380746 - 05/25/14 11:12 AM Re: Kia picant crdi 1 litre [Re: ac_tc]
yvon_la Offline
Loc: quebec canada
any oil rated cj-4 acea 9 will do!(within the manufacturer viscosity)
Truck driver
Nissan versa note s 2014 Mobil Delvac 1 LE 5W-30 supertech st-6607(edition 2016) castrol transynd
#3380760 - 05/25/14 11:31 AM Re: Kia picant crdi 1 litre [Re: ac_tc]
bigjl Offline
Loc: London, England
The only small diesel in the UK is the 1.1crd as fitted to the Rio, not.sure if that is the same engine as in the Picanto.
But that is specced for 5w30 C3 low saps oil.
14 Kia Picanto 1.0 City 10k miles. Kia 5w30
07 Citroen Berlingo Multispace 1.4i 39k 10w40 Maxlife
#3380948 - 05/25/14 04:25 PM Re: Kia picant crdi 1 litre [Re: ac_tc]
yvon_la Offline
Loc: quebec canada
then you ll need something like :mobil delvac1 le 5w30
Truck driver
#3381300 - 05/26/14 05:09 AM Re: Kia picant crdi 1 litre [Re: ac_tc]
ac_tc Offline
Loc: sweden
No particel filter on it. its a 2007.
Sadly xw-30 hdeo isnt avail.
searching for a acea letter that corresponds to api ch/ci
or an appropriate acea letter for passcar diesels.
-an extension cord is out of the question, he doesent even
have a regular parking place.
#3381303 - 05/26/14 05:42 AM Re: Kia picant crdi 1 litre [Re: ac_tc]
Garak Offline
Loc: Regina, Saskatchewan, Canada
An ACEA E7/E9 would do the trick nicely, and is generally a CJ-4 oil, which supersedes the CH/CI specification.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3381322 - 05/26/14 06:59 AM Re: Kia picant crdi 1 litre [Re: ac_tc]
ac_tc Offline
Loc: sweden
seems like a b4 would do the trick.
and can get a 0w-30 b4 oil, make it a 50/50 and i would end with a 5w-35 or something....
( 10w-40 ci4+ hdeo is around 4$/ L compared to 15$/ L for
0w-30...) And i use rather much of hdeo per year so its
convinient to get it in 5 gallon cans.
#3381597 - 05/26/14 03:33 PM Re: Kia picant crdi 1 litre [Re: ac_tc]
Garak Offline
A B4 probably would. A 0w-30 B4 should have sufficient HTHS. However, the B4 oils I've seen here usually meet API diesel specs older still, closer to CF. That's why, to be sure, I'd lean towards one of the E specifications I indicated, since those having CJ-4 will be certainly backwards compatible. There should be 5w-40 versions available, too. The cost may be another issue.
#3381626 - 05/26/14 04:49 PM Re: Kia picant crdi 1 litre [Re: Garak]
Rollins Offline
Loc: Europe
Is this the little monster producing 112 lb·ft @ 2000rpm ?
These are the Hyundai/Kia original oils:
http://lotusauto.com.ua/images/HYUNDAI_KIA_oil.pdf
Here is how a virgin sample of their 5w-30 API CH-4 looks like (thanks to oil-club.ru )
http://www.oil-club.ru/forum/index.php?a...attach_id=13241
Exxon-Mobil facilities in Uddevalla should be still producing Delvac 1 5w-40 CI-4+ (in case the OEM oil is too expensive...).
But with the oil sump capacity of 5,3l.(sic!) and OCI twice a year things can get a bit costly so making a home blend looks like a good idea...
Edited by Rollins (05/26/14 05:00 PM)
#3382738 - 05/28/14 04:37 AM Re: Kia picant crdi 1 litre [Re: ac_tc]
ac_tc Offline
Loc: sweden
Well i found the oil now and its avail at my
local oildealer:
OKQ8 T910
Ultra High Performance Diesel Engine Oil SAE 5W-30
 ACEA E9, E7, E6
 API CJ-4 / SN
Lägsta flyttemperatur,( lowest float temperature) °C -48
Lägsta pumpbarhetstemperatur,( lowest pumpability) °C -45
This should be more than adequete...
#3382739 - 05/28/14 04:53 AM Re: Kia picant crdi 1 litre [Re: ac_tc]
Garak Offline
That looks like it would do the trick nicely.
#3382814 - 05/28/14 07:35 AM Re: Kia picant crdi 1 litre [Re: ac_tc]
yvon_la Offline
Loc: quebec canada
wow!ac-tc nice find!grats
Truck driver
