Originally Posted By: Clevy
Originally Posted By: ZeeOSix
Originally Posted By: KevGuy
The 4 cycle engine has 4 stages: intake, compression, combustion and exhaust.
In a 4 cylinder engine, it's easy....1 cylinder on intake, 1 on compression, 1 on combustion and 1 on exhaust.
In an 8 cylinder engine is it safe to say 2 cylinders on intake, 2 on compression, 2 on combustion and 2 on exhaust???
How does it look for a 6 cylinder engine?
Clevy, each one of those pistons on the TR7 was in a different cycle.
I agree with ZeeOSix on this one.
The basic way to think about it is 2 crank revolutions (720 deg) divided by the number of cylinders. All the pistons in an engine, regardless of how many pistons, must go through their 4-stroke process in 2 crank revolutions. So that will tell you how many degrees each piston is "out of phase" from each other in the 4-stroke process.
So, for an 8 cylinder, 4-stroke engine there is a power stroke from one of the cylinders every 90 degrees (720/8). This also means that each piston is 90 degrees out of phase in terms of where it's at in it's 4-stroke process. So 4 of the 8 cylinders will be half way between strokes when the other 4 cylinders are at one end or the other (ie, TDC or BDC) of their stroke.
On a 6 cylinder, each piston is 720/6 = 120 degrees out of phase in their 4-stroke process.
On the 4 cylinder, it's 720/4 = 180 degrees ... and that's why each piston is at TDC or BDC at the same time.
I cannot say for sure that every manufacturer is the same as far as firing and position however I did work on a triumph tr7 and I'm positive that engine had the 2 center cylinders in the exact same position and the 2 outside cylinders also in the same position.
So the outsides would fire simultaneously and so would the center pistons.
I vaguely remember in the early 80s ford changed the cranks on the Windsor engines to the high output version and I think that's when the Windsor engines fired as zo6 describes.
Weren't some inline 6 cylinders also designed with 2 pistons at the top simultaneously as well.
As far as that triumph goes it was my buddy's car. I want to say it was the stock engine but I can't say for sure.
ZO6 is right that some designs are as he describes but not all.
It was simpler to have 2 pistons at the top at once as far as geometry and maybe strength however today we can forge cranks stronger and with far greater accuracy so we now have engine designs that fire every 90 degrees.
I'm guessing that in an engine design that has 2 pistons at tdc simultaneously might be better for torque but not as good at spinning high rpm,and an engine that fires every 90 degrees might be better for attaining high rpm.
Just guessing though.
And please correct me if I'm wrong. I'm not positive and might have everything backwards.
