Honda EM7000is stored too long with fuel
by henni
07/01/16 10:04 AM
1967 Ford F250- cooling system flush w/ Cascade??
by ryanschillinger
07/01/16 10:02 AM
Oil for FTO MIVEC used on track
by Spetz
07/01/16 09:13 AM
[Cut Open] Motorcraft FL500S - 5316mi
by DuckRyder
07/01/16 09:04 AM
Oil life monitors
by doublebase
07/01/16 09:02 AM
DENSO IKH20TT quality question
by inquirer
07/01/16 08:53 AM
OTC additives and products - what do we know?
by Kwuality
07/01/16 08:37 AM
Highway conditions in the Midwest
by grampi
07/01/16 08:22 AM
Indian head shellac or something?
by JHZR2
07/01/16 08:15 AM
Need Help! Tombstone
by AirgunSavant
07/01/16 07:38 AM
Truck bedliner - pros and cons and option
by ryan2022
07/01/16 07:33 AM
Delo 400 SD 15w30 From Amazon
by AirgunSavant
07/01/16 07:27 AM
EdandSherry, Shalmaneser, Shipmate29, garytcosta, lifteddiesel90
58332 Registered Users
90 registered (09_GXP, ABerns, adamrc, 1foxracing, 440Magnum, Analyzer, 7 invisible), 1819 Guests and 11 Spiders online.
58332 Members
66 Forums
251091 Topics
#3380126 - 05/24/14 03:59 PM #0 Lithium grease for the Mantis?
andyd Offline
Loc: Marshfield , MA
Would regular NLGA 2 grease be okay?
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3380163 - 05/24/14 04:59 PM Re: #0 Lithium grease for the Mantis? [Re: andyd]
46Harry Offline
Loc: hawthorne, Ca.
If the machine were mine, I would find a source for the correct lube. #0 grease is really thin and getting close to a semi fluid grease like #00 that is used in farm equipment. #2 grease will be to viscous to be used where a #0 grease is specified.
#3380264 - 05/24/14 08:04 PM Re: #0 Lithium grease for the Mantis? [Re: 46Harry]
westwind999 Offline
Loc: Canada
John Deere Corn Head Grease maybe?
Most auto parts stores seem to only stock #2 not sure why.
#3381101 - 05/25/14 08:11 PM Re: #0 Lithium grease for the Mantis? [Re: andyd]
vssjim Offline
Loc: McLean, Va.
most of the gear box lubes for power equipment are very thin a runny so I would not use any thing as heavy as a #2.
#3382396 - 05/27/14 07:33 PM Re: #0 Lithium grease for the Mantis? [Re: andyd]
andyd Offline
I have time. I found the manual on line and found out how to check the lube. It was OK. To check, the pan has unscrew from the housing. It is in the tilth constantly. I had to spend 15 minutes cleaning the tines, then wire brush the dirt out of the phillips heads. The cover came loose from a perfect cork gasket I have a qt of MTL that I'm using in The Ariens snow blower's augur drive. I bought MTL because it was the only one that said it was safe for brass. Other labels skirted the issue. The Mantis has a brass ring gear.It is a similar application. IIRC, the MTL is 80/90.
