Just yesterday as I was wondering if my Infiniti FX45 (V8) was built any better than the M and G series for towing and general truck type use (the way I use it). I had the cruise control set on the highway, when I started heading up a hill, the tranny downshifted and I noticed a gray cloud appear between me and the trailer. I let off and the cloud went away, got on the gas again - gray cloud back. My first thought was tranny or head gasket. I have worried since day one about the long term durability of this engine/transmission combo, although I have had zero issues up to this point.
I pulled over and verified that if I revved it, a gray cloud came out from behind the car - so definitely not the tranny, I didn't smell anything sweet and it didn't look like steam. The front of the trailer had a strange gray dust and the exhaust tips were also gray. Underneath the car it sounded like broken glass was rattling around at idle.
I drove the rest of the way home, unhooked the trailer and everything seems to be ok. I assume that one of my (4) cats just disintegrated. What I don't know is which one or why.
I am hoping that it is a post cat as the pre-cats are built into the exhaust manifold, and also potentially can let cat material into the engine causing mass destruction - a la early 2000's altimas.
I have 107K miles and am surprised that a cat let go this early, although I suspect the vehicle is probably not made for the amount of trailer towing that it get subjected to.
At this point there has not yet been a CEL. My journey the rest of the way home yesterday netted the same 10-11 mpg on the highway that I normally get with this load. I don't know if a chunk broke loose and dissolved and I should just ignore it, or if doom is soon to follow. I want to avoid causing more damage.
I have a few questions. The OE cats are ~$750 each online. I don't really want to pay that much unless they are better than the alternatives. And that is assuming it is the post cats. I don't know how to check for damage short of removing them, or possibly renting a FLIR camera.
There are 'OE Fit' cats that are available as well as universal replacements that can be welded in.
I would like to gain performance if possible, certainly I do not want to give up any by using a universal cat that does not flow as well as stock - I don't know if this is a real concern. It seems the direct fit and universal cats are all physically smaller than OE.
Are there any more reputable or less reputable companies I should be aware of? I keep seeing Eastern Catalytic popping up in searches. I also seem to be finding a lot of sites that have the same part numbers showing for the V6 and V8 models, although I am quite certain that they are different.
There are no emissions tests here, but I do want to keep cats on the vehicle.
Suggestions?
Suggestions?
