Originally Posted By: EricF
Belts do not make noise.
squeaks & squeels are from lack of belt tension, a misaligned pully, or a bad pully (or accessory).
spraying belt dressing on a serpentine belt will simply expand the ribs and ruin it. I never even use the stuff on V-Belts. I simply apply more tension.
They make noise when they're all cracked on the inside. Bend the belt over backwards into a loop and you'll see the cracks. How exactly they make the noise I'm not quite sure, but it's either because they're losing grip, losing flexibility, or both. The WD-40 lubricates the belt when it's slipping and momentarily eliminates the squeak.
