Originally Posted By: Shannow
Makes CATERHAM's test results impossible if it is a regulator,and always operating
It's not
always off it's seat, that's for sure.
But I still insist that one cannot tell by a pressure ramp observed on a pressure gauge exactly when it lifts, and even less so by what degree, that's true. One needs to see a
flow chart for that. Melling's got plenty, and those plots confirmed that on one of their high pressure, high flow SBC units, the valve lifted off about 1800ish engine RPM. The chart has been posted somewhere on here.
Originally Posted By: KrisZ
And? Are you suggesting that the positive displacement pumps and their relief valves found in cars behave differently? If so let's hear it, and a verifiable source would be nice as well.
Steam is gas phase and compressible, hydraulics are not and hydraulic pressure is
unforgiving. The bypass valve is the only thing that moves in the system, the only thing that can take shocks and make (intentionally designed-in) excess volume 'disappear'.
In fact, the supply side of the oil system will see hydraulic pulses caused by the pump gear lobes themselves, until the bypass opens, then it becomes the 'shock absorber' for that little hydraulic frequency. If there was no bypass valve, an oil pump could hydraulically split itself, if the oil filter didn't rupture first.
The backpressure is as mentioned before, an artifact. One could remove the engine from the pump and get 0psi backpressure, and theoretically 100% of the pump's displacement output. To observe a pressure gauge to determine flow, and where the flow was being directed would be futile in such a case.
The observed pressure gauge behavior seen by some (with stock pump configs) of a lowering of backpressure across the board and at redline, from say running 0w20 on an unchanged pump and engine, is tantamount to opening up engine clearances
and lowering bypass spring pressure with a 5w40.
This is due to not only the engine, but bypass also being able to "accept" more oil volume
at a lower pressure. In other words, the same excess displacement of the pump is being handled by all leakage points at a lower net backpressure. The backpressure equilibrium as a whole is lowered, and the pressure gauge behavior could be misconstrued as complete inoperation of bypass in the upper RPM range! And this is all before considering internal pump leakage, which is naturally increased. I'm not persoanlly worried, however considering pump leakage from below-spec vis is really only an issue at hot idle, and 8-10psi in my case@600rpm is fine!
ASME's take on the issue...
https://www.asme.org/engineering-topics/...better-oil-pump
Quote:
As the market and government regulations push automakers to improve emissions and fuel consumption, they are evaluating all opportunities in the engine system to reduce losses. The oil pump is one important component that consumes engine power as it protects engine components from frictional wear and overheating by delivering oil at the correct pressures.
Fixed-displacement oil pumps currently circulate oil in most automobiles. Designers typically oversize the pumps to handle the harshest engine operating conditions. Most of the time, they consume more power and deliver significantly higher oil pressure than needed. They contain pressure-relief valves as a crude, cost-effective, and reliable way to avoid excessively high oil pressures. But these designs are inefficient, losing significant amounts of energy at high oil flows typical in internal-combustion engines.
Nice
If I'm reading that correctly, they confirm that auto oil pumps are intentionally designed to displace well more than required for the 'harshest engine operating conditions' which I take to mean hot idling at 600rpm with the hottest, most sheared, viscosity broken oil in the crankcase
Originally Posted By: turtlevette
People shim the stock spring all the time to get more pressure through most of the rpm range.
Indeed!
As the engine wears, yes, that # will go down. That doesn't mean that the engine is receiving inadequate lubrication though.
Sure, even 7psig is fine for basic lubrication! With relation to backpressure, increasing clearances is tantamount to reducing pump displacement. High flow pumps are great for engines with high oil demanding features like piston oil cooling jets. Some manufacturers (BMW) have other funky oil supply pipes for the valve train in the rocker cover etc. as well as turbo bearings on any given turbocharged vehicle, which is very common today.
But so too, oil pumps are changing. This discussion will soon be made obsolete. And who can imagine how lengthy, ambiguous, theoretical and heated discussions about variable pressure, variable displacement oil pumps will get here on BITOG!
