So, I flushed my brakes the other day (fluid was black, yuck) and while it was being done, my brother got overzealous with his pumping and the reservoir got too low and air started coming out of the bleed valve that I was working on (driver rear). I quickly realized it and ran over and filled the reservoir back up and kept bleeding that wheel until fluid started coming back out.
I took it for a ride and the brakes feel fine, in fact the pedal feels firmer than it ever has and I can lock them up now pretty easy (maybe HARD reverse stops over-adjusted the rear shoes), which I like.
Just to be sure, I went ahead and re-bled my brakes just to be sure no residual air is in the system.
Well, the "issue" I'm having is that the wheel that I ran out of fluid with (driver side rear), never quite bleeds right, IMO.
When I first crack the bleeder, it spits a TINY bit and then flows smooth; it does this no matter how many times I manual bleed (have helper pump and hold while I crack the bleeder and have the helper follow through with the pedal and then hold it down while I tighten the valve back up).
The other bleeders don't do that, they flow smooth at first crack of the bleeder. The thing is, I think Ive encountered bleeders that always spit a little before they flow smooth on air-FREE systems (I just can't 100% remember this for sure, LOL).
I'm thinkin' its' from the initial pressure release of the valve when cracking, because it only happens when I open it slow; a fast open seems to not create the spit.
So, the question is, is a little spit normal on some bleeders OR do I have constant air in the line (braking + pedal feel tells me no, also NO loss in fluid is occurring and NO pedal drop and NO spongyness)?
If there is air, I don't see how it can constantly be there if I am purging it (spitting it out, if that's the case). I understand if there's air TRAPPED that I cant get out, but if that was the case and the spitting is in fact air purging, at some point the spitting/purging should stop.
I changed the bleeder valve just to be sure that wasn't the issue.
My biggest fear is that I have a constant of sucking in air somewhere, but that sounds impossible, seeing as the reservoir is filled up on the re-bleeds.
I also don't want to mess with bleeding the master cylinder (bench bleed or otherwise) if I don't really have a problem.
Any insights, past experiences?
TIA
FYI, my car is an 87 Cutlass Ciera. I have rear drums and JA2 (Heavey duty) brakes. NO ABS.
TIA
