Originally Posted By: fdcg27
I really don't understand all of this disdain for timing belts.
I do understand. Timing belt should be changed well before the 150K stated. By the 200K stated, nearly due for a second TB change on Honda. These maintenance items do cost money, even do it yourself. If this is an attempt to defend Honda, even Honda has moved to timing chains on most 4 cyl engines.
Quote:
We drove Hondas for years with this type of cam drive and never had a problem.
Drove many domestics and some imports some chain, some belt and never had a cam drive problem except did have to replace the Timing Belts as suggested in the owners manual. Replaced hydraulic tensioner, pulleys in the Honda. And except had Honda recall for defective TB tensioner.
Quote:
The typical change isn't that hard to do or that costly to have done,
Depends what is considered costly or not that hard. Did my Honda TB. Not extremely easy or hard. Dealer $tealer near $1000 if do water pump, hydraulic tensioner, pulleys. Should replace the hydraulic tensioner on Hondas as they often start to leak. Too loose tensioner equals slipped TB and may mean bent valves and engine rebuild in an interference engine like Hondas.
Quote:
and will likely happen once in the life of the car.
Depends on mileage at the life of the car. See above.
Quote:
No biggie
Depends.
Quote:
and it's not as thought timing chains never fail.
For TB, manufacturer recommends it be changed. Timing chains have better odds of a chain lasting the life of the car without replacement, whatever life of car is.
Quote:
They are also a whole lot harder and more expensive to replace.
But chain needs replacement less often.
Quote:
Any new car has a design service life of 150K with no major repairs.
Not my Honda V6 auto trans, or my co workers Pilot AT, or my friend's TL auto trans.
Quote:
This means that with good maintenance, 200K is easy to reach with nothing major breaking.
