Coolant Question.
by Farmer
08/27/16 04:20 AM
Stocking up for the Eco
by buck91
08/27/16 12:25 AM
Mobil 1 10w40 HM
by SubyRoo
08/27/16 12:16 AM
What type of glue for door panels?
by Nick1994
08/27/16 12:07 AM
Painting rear of chrome bumpers
by buck91
08/26/16 11:09 PM
Walmart Rifle Clearance
by hatt
08/26/16 10:44 PM
Vehicles That Must Idle For Long Periods Of Time
by BlueOvalFitter
08/26/16 10:30 PM
2013 Taurus SHO Ecoboost
by SHO
08/26/16 10:11 PM
Need recommendation
by double vanos
08/26/16 10:00 PM
Kawasaki must be completely full of gas to start
by jrcowboys
08/26/16 09:36 PM
Un-Screwing
by Ducked
08/26/16 09:05 PM
BG 109 vs 120, any techs experienced w/ both?
by dccode
08/26/16 08:24 PM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
27 registered (dccode, Atesz792, bdcardinal, B320i, bbhero, 2 invisible), 639 Guests and 37 Spiders online.
58935 Members
66 Forums
253609 Topics
Page 5 of 5 < 1 2 3 4 5
#3340558 - 04/12/14 09:41 AM Re: Tdi gelatinous sludge [Re: Thermo1223]
Provi Offline
Loc: Dunbar, WV USA
Originally Posted By: Clevy
Originally Posted By: Provi
This was at about 95k miles when I had to change the oil pan on my 02 ALH Summer 2013.
Those pictures are interesting to say the least. It's almost like the oil turned to tar and left a coating of it only on some surfaces but not others.
I'm not sure how that's even possible. I would think the entire surface under the valve cover would be coated but it's not.
Interesting to say the least.
The splash shield is black plastic so that may look like tar?
Here is the oil that was just sampled after the change.
Originally Posted By: accent2012
Does that TDI have a gear driven oil pump or chain? If chain, I would check the chain tensioners for wear.
It is.
Edited by Provi (04/12/14 09:43 AM)
02 VW Jetta TDI, Valvoline PBX 5w-40 15k mile OCI
12 Honda Civic Hybrid, Castrol Syn blend 0w-20
#3363215 - 05/06/14 09:50 AM Re: Tdi gelatinous sludge [Re: Chugchug]
ironman_gq Offline
Loc: MN
I'm going to say WVO. I know of one guy who decided to do a WVO conversion on a Duramax, worked OK till he went to leave one day and had 0 oil pressure, the whole oil pan looked just like yours, black jello.
#3380966 - 05/25/14 04:46 PM Re: Tdi gelatinous sludge [Re: ironman_gq]
BruceM Offline
Loc: Colonie, NY
I've seen that on engines sith improper wvo systems. If the engine isnt up to full opersting temp and the oil isnt hot you get incomplete combustion and engine oil contamination with wvo. I've been running wvo I my 2000 Ford superduty for 6 years now and 50k +/- miles, and havent had a single problem other than wvo fuel pumps not lasting. One rule on wvo is you shorten your OCI specifically because WVO and diesel motor oils don't play well.
I have a theroy its the zinc in the hedo as I have watched zinc coated galvinzed pipe parts grow a gelatinous coating of wvo in a day. Hot wvo and galvinized pipe (or a galvinized drum) dont mix well. Iirc hdeo's are one of the last remainung high zinc engine oils ouut there.
94 3.2L V6 Taurus SHO MTX
96 3.4L V8 Taurus SHO
00 7.3L V8 F-250 Superduty
#3380975 - 05/25/14 05:03 PM Re: Tdi gelatinous sludge [Re: Chugchug]
yvon_la Offline
Loc: quebec canada
lets assume previous owner did right!the next thing that could have happened is temperature got up and turbo cooked the oil and this is what happened ,bottom line!make sure to let turbo cool
Truck driver
Nissan versa note s 2014 Mobil Delvac 1 LE 5W-30 supertech st-6607(edition 2016) castrol transynd
#3399761 - 06/17/14 12:36 PM Re: Tdi gelatinous sludge [Re: BruceM]
Hohn Offline
Loc: Indiana
While WVO is almost certain to cause as you describe, even B20 I suspect could do this given enough extended operation on B20 (RME or DME) in cold temperatures and long drain intervals.
With lots of short trips in cold temps, blowby would be excessive. Combining high blowby of fatty acid methyl esters with a higher-zinc diesel oil COULD explain the goo that is on display here.
As for turbo causing this, not a chance. The turbo bearings would be shot LONG before this amount of sludge could accumulate. Failing to cool down turbo is actually one of the things you can rule out. Turbo cool down periods are for turbos-- and nothing else.
I work in product development at Cummins, but I can only speculate here as we do not do lengthy testing on B20 or biofuels in general-- I've never seen that kind of goo in field test or test cell engine.
H
Current: 05 Odyssey, 07 IS250AWD
Former:'97 Maxima, 02 Dodge CTD
