Originally Posted By: jrustles
There is no fixed numerical bypass backpressure point. It WILL change if you change your viscosity. Seeing a lower backpressure on low vis oil does not necessarily mean greater flow through the engine- yes, there may be- but greater flow through all other, immediate, closer outlets including housing/gear clearances
and a given backpressure-determined position of the bypass valve, which is certainly almost always open above idle, even on a hot engine. Your observed slower/lower pressure build to plateau is simply due to the increased volume of leakage, particularly through the bypass.
That hasn't been my experience with SBF's and SBC's, which, with hot oil of basically any viscosity, will hit the relief point on the pump and stay there. That pressure is always the same on the oil pressure gauge regardless of whether the oil is 0w-20 or 5w-50. Now, it GETS to that point faster (at a lower RPM) with the heavier oil than the thinner oil, but the end result with my SBF was always 65psi. This behaviour would graph the same as the LSx shown earlier in the thread.
That does however bring up a good point about some particular engines, one of which was a Dodge engine mentioned in another thread that was in fact apparently on the relief at much above idle. It had very high idle oil pressure, which climbed fast, and ultimately meant that the relief was bypassing oil internally much of the time.
I think it is foolhardy for us to think that these systems operate the same in all engines as SteveSRT8 pointed out. The information I posted from Melling in the other thread regarding the spring pressures available for SBC and BBC engines mirrors my experience with them and the SBF. You fit a given spring and that is the pressure at which the pump starts bypassing. And with an HV pump on a relatively tight SBC, you can over-run the relief spring and see pressure well above what you've fitted the pump for.
I am sure it is quite possible for some Japanese engines to have light springs that do in fact result in the oil pump bypassing some of the oil much of the time, operating in the manner in which you've depicted. That isn't the case with any of the American engines I have experience with though, which are easy enough to find the bypass spring pressure settings for. Some members of the Modular family have a 70psi spring for example. IIRC, one of them has one around 90psi. As noted in the Melling PDF I posted recently, one particular Ford engine family has a 125psi relief spring factory.
I believe I posted this in another thread, but perhaps the answer to the specific question as to how often the pump is on the relief is "it depends"
