Maybe I’m too old for that fan. Last summer my family was too busy with summer courses etc. and no boating. Last time the boat was used was 2 years ago. It was winterized very well and I didn’t expect any problems. To play it safe, I drained old gas (even though it was stabilled x2) and got some fresh 100% gasoline, 91 octane ($4.09 per gallon). Then I checked the battery (on solar charger all the time). Oops, 10.5V. Then I load tested it. It went to zero. Granted the battery was over 10 year old (OEM) and I expected to go bad.
I went to get a new one at Advance Auto ($91-coupons). I charged the battery some as it was not the freshest (01/14). I cranked a bit to get the gas in the carb etc. Then I attempted to start using the gas pumping ritual/dance that worked in the past. Nothing x 10 (I charged the battery to full in between the cranks).
Oops, almost noon already, I was supposed to be in the bank before they closed. Later, I pulled the plugs. Look clean, almost new NGK, but 3 of 4 wet with gas. I flooded the thing! Then I cleaned the plugs and tried to start the flooded engine. After several tries, one cylinder started but action lasted several seconds after it would die backfiring and coughing.
Again, one plug dry, 3 wet. ???? Maybe I had the ignition wires crossed? I checked against my notes that always worked and everything looked OK. I went online and found merc manual. Weird, the firing order is different. I pounded that a bit and decided if I wired like the manual had, not even one cylinder would fire. At least I knew there was a spark in one cylinder. I checked the distributor, clean; wires, fine.
Then I thought about carb, did it foul again despite draining it completely last winter? I spriced some carb fluid inside and tried starting several times. Noting, one cylinder action again.
What else? I had a set of spare plugs. Why not? I remover the plugs (again) dropping some tools in the engine well. Guess what. The engine started! Looks like 3 of 4 plugs went bad (shorted), Weird.
But, what’s that noise? Sounds like sparking. There are sparks flying from the coil to the ground. Great! I called WestMarine and of course they don’t have it in stock. No one in town has it either! I ordered one online and decided no boating this weekend. I decided to spend the rest of the day changing oil, filter and gear oil.
I’m not going to bore you with the description how the filter got stuck, it took not one, but 2 screwdrivers (one bent) nailed though it to budge it. I cut my finger on sharp shards of metal in the process. When it was time to pump gear oil in the outdrive, the hand pump lost prime and I had to fight with it to get it started.
Anyhow, I spent over $200 and entire day of hard work and the boat is not any closer to the water. Sorry, I had to vent.
Happy Memorial Weekend to everyone!
