This is a VW 507 oil intended primarily for engines using ULSD and is a low-SAPS oil.
It may not offer enough TBN for runs to the limits of the MM in your Civic.
Also, is your car still under warranty?
Does this oil list any API spec, since that is the spec that Honda requires for the engine oil?
Realistically, this is a good and typically expensive oil.
The price you got it for is certainly right.
It should do well in your engine but may not have enough TBN to serve for the life allowed by the car's MM using US pump fuel.
If you shorten drains a bit, it should be fine.
