Run Oversized Fram Ultra 25k & Multiple OCIs
by WillsYoda
02/07/16 11:35 AM
Rislone Zinc Additive
by hjones
02/07/16 11:34 AM
Edge Ep & purolator Boss filter
by hjones
02/07/16 11:30 AM
Gas is dangerous
by Stelth
02/07/16 11:03 AM
Mobil 1 Syn @ Costco
by CowboyHokie
02/07/16 10:55 AM
Subaru 2011 Outback
by Al
02/07/16 10:51 AM
How are these exhaust parts?
by mclasser
02/07/16 10:44 AM
Cabin Air Filter
by Trav
02/07/16 09:31 AM
Warm fuzzy feeling
by marine65
02/07/16 09:26 AM
tires wearing prematurely
by motor_oil_madman
02/07/16 09:17 AM
Superbowl and Willie Woods
by Donald
02/07/16 08:32 AM
Rural King Synthetic
by MarkM66
02/07/16 08:32 AM
Nazmorgul, bhans, truthtracer, Recreator, 18LateModelFan
56842 Registered Users
91 registered (901Memphis, AandPDan, 90crvtec, Al, Andy636, 6 invisible), 1659 Guests and 191 Spiders online.
56842 Members
66 Forums
244362 Topics
Page 2 of 4 < 1 2 3 4 >
#3379666 - 05/23/14 11:01 PM Re: Why Aren't Headers Standard Equipment? [Re: morris]
Quest Offline
Loc: beaver land EH?
Originally Posted By: morris
WHY? cause car makers make cars ONLY good enough.
popcorn2 popcorn2 popcorn2
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#3379716 - 05/24/14 12:00 AM Re: Why Aren't Headers Standard Equipment? [Re: JerryBob]
dailydriver Offline
Loc: Bucks County, Pa.
If one is talking about full length, tuned, scavenging LONG TUBE headers, then the OEMs will NEVER use them now, since they do NOT allow the catcon(s) to be placed close enough to the exhaust ports in order to 'light off' properly, and STAY hot enough to function once the engine is running for a while.
They would never pass a 49 state sniffer test, let alone the crazy C.A.R.B standards.
If one is talking about factory/OEM length 'shorties', yes, they do allow the catcons to be placed close enough for light off and proper function (despite their worse heat retention than cast iron manifolds), BUT the OEMS would be VERY hesitant to use them due to; cost of 304/321/inconel stainless tubing material, the brittleness of this material, the aforementioned higher under hood noise issues, and the potential warping of the thinner mounting flanges and all of the exhaust/vacuum leak emissions/ECM problems that come with those leaks. frown
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#3379720 - 05/24/14 12:07 AM Re: Why Aren't Headers Standard Equipment? [Re: JerryBob]
OVERKILL Online   content
Loc: Ontario, Canada
Stock M5 exhaust (foreground):
You'll note the cats are a fair ways back from the headers, which I would categorize as "mid length", as they aren't shorties and they aren't long-tubes either.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3379773 - 05/24/14 05:29 AM Re: Why Aren't Headers Standard Equipment? [Re: JerryBob]
SteveSRT8 Offline
Loc: Sunny Florida
Every SRT8 you see has a nifty pair of factory shorties wrapped in a sheet metal shroud. Flow well all the way to 600 crank hp or so. Quiet as a mouse!
Since many new engine designs have no exhaust manifold at all these days expect fewer headers!
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3379794 - 05/24/14 06:43 AM Re: Why Aren't Headers Standard Equipment? [Re: JerryBob]
edwardh1 Offline
Loc: Coastal South Carolina
noise and rust
I know women who are always late, they do not allow travel time, they think like Star trek, you leave one place and materialize somewhere else.
#3379836 - 05/24/14 08:02 AM Re: Why Aren't Headers Standard Equipment? [Re: OVERKILL]
fdcg27 Offline
Loc: OH
Apparently, some low-po cars also come with headers from the factory.
My 318i has headers, although I guess it's fairly hi-po for its displacement, and it does make a lovely snarl when wound through the gears.
The rest of what was said above explains why most engines come with cast iron exhaust manifolds.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 152K Defy 10W-40
#3379839 - 05/24/14 08:05 AM Re: Why Aren't Headers Standard Equipment? [Re: JerryBob]
Miller88 Offline
Loc: Onondaga County
Mazda skyactiv has 4-2-1 headers and play with valve timing to get the converter to light off.
I run the 10w30 becuase 0w20 makes my CVT shift funny
#3379910 - 05/24/14 10:25 AM Re: Why Aren't Headers Standard Equipment? [Re: JerryBob]
GMBoy Offline
Loc: Texas
A lot of the reasons OEM's do not use headers is due to noise. Traditional exhaust manifolds are quieter and cheaper to make. Also a lot of late model manifolds look almost like headers anyhow. I just looked under the hood of a new 2015 Tahoe as it went down the line.
Edited by GMBoy (05/24/14 10:27 AM)
#3380070 - 05/24/14 02:11 PM Re: Why Aren't Headers Standard Equipment? [Re: JerryBob]
supton Offline
Loc: NH
How many cars "need" headers? A few hp gain at an rpm that few use.
2011 Toyota Camry, base, 6spd manual, 107k, hers
2010 Toyota Tundra double cab, 4.6L, auto, 114k, his
#3380211 - 05/24/14 06:19 PM Re: Why Aren't Headers Standard Equipment? [Re: supton]
fdcg27 Offline
Loc: OH
How many cars "need" more than four cylinders and two liters of displacement?
It isn't always or even usually about need, it's about want.
#3380247 - 05/24/14 07:25 PM Re: Why Aren't Headers Standard Equipment? [Re: circuitsmith]
Trav Offline
Loc: MA, Mittelfranken.de
Originally Posted By: circuitsmith
Modern cast manifolds are far better than the "log" manifolds of yesteryear.
True but the old SBC iron Ram Horns are hard to beat and perform as well as or better than many tube headers.
Header performance without the drawbacks.
#3380470 - 05/25/14 12:33 AM Re: Why Aren't Headers Standard Equipment? [Re: JerryBob]
TiredTrucker Offline
Loc: Central Iowa
The primary reason OEM's don't do stuff like this, except in their high end offerings, is production cost, pure and simple. OEM's, like most any business right down to a mom and pop hotdog stand, will try to trim every dollar from production cost they can. To that end, they will only use what they need to get the results they need. Even a $1 part, if it is not necessary, will be trimmed off of production. When you factor the number of vehicles produced, that $1 saving runs into the millions of dollars. Sure, this is all about profits, but they have to compete in the marketplace with everyone else making vehicles. And the majority of potential customers don't think in terms of headers, superchargers, etc. They want a vehicle that does what they want, and the cheapest price they can get it for.
Hey! That is exactly what the OEM's are doing themselves!
Burn it down.
#3380689 - 05/25/14 10:00 AM Re: Why Aren't Headers Standard Equipment? [Re: JerryBob]
Bamaro Offline
Loc: Balto.
Its a cost - benefit issue. (Cost includes durability)
2015 Elantra
2009 Cobalt totaled by inattentive driver
1970 Camaro
2009 Civic
2015 Rogue
2014 Mazda3
#3381064 - 05/25/14 07:37 PM Re: Why Aren't Headers Standard Equipment? [Re: OVERKILL]
dailydriver Offline
Does Bimmer play with the timing/firing order/etc. in order to get the catcons to light off, like Mazda does with the high compression skyactivs??
Yes, those are about mid lengths, but it perplexes me that they did not put the catcon right at the flange of the header (already quite far away from the exhaust port) for faster/more efficient light off, and instead put it way back in the connecting/intermediate pipe. ???
I am guessing that unibody/subframe clearance and interference problems are the reason?
M1-206 oil filter
#3381115 - 05/25/14 08:27 PM Re: Why Aren't Headers Standard Equipment? [Re: dailydriver]
Subframe and transmission.
The engine has a big electric air pump that runs for a bit on cold start, I assume to aide in lighting off the cats.
02 Expedition
06 Charger R/T
14 Charger SRT-8
