Thin oil, thick oil, synth or dino,
by Cruzingoose
33 minutes 0 seconds ago
Compete today? Modernize your skills on own time
by spackard
35 minutes 15 seconds ago
Castrol 0w30 leaving Advance Auto Parts
by bbhero
Today at 10:53 PM
Oil Change Marathon Today
by BlueOvalFitter
Today at 10:01 PM
Raybestos Advance Tech or Police Rotors?
by shiny
Today at 09:57 PM
Oil filtration and circulation question
by Doublehaul
Today at 09:41 PM
Anyone ever replaced brake fluid on Honda Pilot?
by Islandvic
Today at 09:19 PM
Unused WIX 51372-051815C2 cut & post
by WellOiled
Today at 08:37 PM
-31 this morning...without the wind chill!
by Doublehaul
Today at 08:00 PM
Cleaning Throttle body, necessary service now?
by Colt45ws
Today at 07:33 PM
[Cut Open] Ford OE (FL500S equivalent) 4948mi
by DuckRyder
Today at 07:20 PM
[Cut Open] Fram XG3600 - 9098mi
by DuckRyder
Today at 07:16 PM
Tsr71, SubaFool, dookchoppa, Formula413, Cruzingoose
56910 Registered Users
49 registered (bdcardinal, B320i, bigdawg74, 11 invisible), 942 Guests and 127 Spiders online.
56910 Members
66 Forums
244670 Topics
Page 1 of 3 1 2 3 >
#3378912 - 05/23/14 04:13 AM Cheap DIY urethane motor mounts
asand1 Offline
Loc: Oregon coast
My motor mounts were really bad, so
I went to the wrecking yard in Coos Bay and picked up a set of AT motor mounts for $20.00 and stripped them of all original bushing material. I then filled them with 4 tubes of LOCTITE PL S40 polyurethane window, door & siding at $7.99 each.
[url="http://s146.photobucket.com/user/asandberg6/media/96%20MAXIMA/ATmounts1_zps16561e1d.jpg.html"][/url]
Tje jig I put together to locate everything while fulling and curing.
Nissan/Infinity/Mazda Manuals
1996 Maxima 310K
2008 Uplander 80K
#3378913 - 05/23/14 04:16 AM Re: Cheap DIY urethane motor mounts [Re: asand1]
asand1 Offline
Loc: Oregon coast
I then filed them and waited 4 months for curing through and through.
1996 Maxima 310K
2008 Uplander 80K
#3378914 - 05/23/14 04:19 AM Re: Cheap DIY urethane motor mounts [Re: asand1]
asand1 Offline
Loc: Oregon coast
There is a quite measurable improvement over the old mounts. Still spongy, but the engine doesn't knock around when shifting, or goosing the throttle in gear.
Front mount driver side view.
[url="http://s146.photobucket.com/user/asandberg6/media/96%20MAXIMA/installed2_zpsd13bf30c.jpg.html"][/url]
Front mount passenger side view.
[url="http://s146.photobucket.com/user/asandberg6/media/96%20MAXIMA/installed1_zps713ceb2f.jpg.html"][/url]
Rear mount driver side view.
[url="http://s146.photobucket.com/user/asandberg6/media/96%20MAXIMA/installed3_zpsfba95d51.jpg.html"][/url]
Old mounts were in better shape than the wrecking yard mounts. Perfect for filling gaps with construction adhesive wink
[url="http://s146.photobucket.com/user/asandberg6/media/96%20MAXIMA/oldmounts_zps527dcb5f.jpg.html"][/url]
1996 Maxima 310K
2008 Uplander 80K
#3378915 - 05/23/14 04:20 AM Re: Cheap DIY urethane motor mounts [Re: asand1]
asand1 Offline
Loc: Oregon coast
Pictured below are my OE MT motor mounts. Like the AT mounts, they are fluid filled. The electronic mount is actually not an electrorheological fluid, like many believe. It simply has a servo motor that adjusts fluid damping like an adjustable shock to decrease vibration at idle.
I have cut away rubber on these two to drain fluid and fill with Locktite PL Premium construction adhesive.
You can see the rear mount on the right has a good sized cavity on the bottom that was fluid filled. I believe this was the cause of my movement.
I just need to clean these up and fill them when I have some spare cash. I will run the white mounts as long as They keep working before I swap these in, but in about three months these should be done and on stand-by.
[url="http://s146.photobucket.com/user/asandberg6/media/96%20MAXIMA/oldmountscut_zps8fab166a.jpg.html"][/url]
Edited by asand1 (05/23/14 04:33 AM)
1996 Maxima 310K
2008 Uplander 80K
#3378919 - 05/23/14 04:40 AM Re: Cheap DIY urethane motor mounts [Re: asand1]
asand1 Offline
Loc: Oregon coast
Before anyone tries to flame me for being cheap, this was an attempt to solve the problem of a [censored] design. Stock motor mounts are too soft for my liking, and replacement mounts are known to fail within months of installation.
My goal here was to make a semi-solid mount that would never break down and allow movement.
1996 Maxima 310K
2008 Uplander 80K
#3378928 - 05/23/14 05:20 AM Re: Cheap DIY urethane motor mounts [Re: asand1]
eljefino Offline
Loc: ME
So you lived with a rocking motor for four months?
#3378934 - 05/23/14 05:23 AM Re: Cheap DIY urethane motor mounts [Re: asand1]
Shannow Online   content
Loc: Oz
You sir are a legend...thanks for posting.
#3378938 - 05/23/14 05:31 AM Re: Cheap DIY urethane motor mounts [Re: Shannow]
asand1 Offline
Loc: Oregon coast
Thank you.
I lived with a rocking motor for 5 years, because my mounts were shot, despite outwardly looking good. But If your asking if I drove without mounts for 4 months, no. I modded wrecking yard mounts for zero downtime.
1996 Maxima 310K
2008 Uplander 80K
#3378943 - 05/23/14 05:45 AM Re: Cheap DIY urethane motor mounts [Re: asand1]
JustinH Offline
Loc: Texas
So, on rockauto there aren't any decent motor mounts for this car?
'10 Toyota Rav4 Sport
'08 Toyota Matrix
#3378952 - 05/23/14 06:01 AM Re: Cheap DIY urethane motor mounts [Re: JustinH]
asand1 Offline
Loc: Oregon coast
No decent ones according to reviews on Maxima.ORG, and OEM are insanely priced. The design relies on hydraulics and valving rather than just ample rubber to locate and isolate the engine. Its a poor design in my opinion, and one that cannot be cheaply replicated with any kind of quality.
Edited by asand1 (05/23/14 06:05 AM)
1996 Maxima 310K
2008 Uplander 80K
#3378959 - 05/23/14 06:20 AM Re: Cheap DIY urethane motor mounts [Re: asand1]
Char Baby Offline
Loc: Western NY
I have never seen anyone do this. Well Done Sir!
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#3378964 - 05/23/14 06:26 AM Re: Cheap DIY urethane motor mounts [Re: Char Baby]
asand1 Offline
Loc: Oregon coast
3M window weld is the superior product as far as caulk goes, but Mcmaster Carr and energy suspension has a pourable 2 part molding polyurethane. This is a popular mod for the Honda tuners.
1996 Maxima 310K
2008 Uplander 80K
#3379008 - 05/23/14 07:45 AM Re: Cheap DIY urethane motor mounts [Re: eljefino]
Miller88 Offline
Loc: Onondaga County
I'm going on 2 years for the Focus ...
I run the 10w30 becuase 0w20 makes my CVT shift funny
#3379012 - 05/23/14 07:52 AM Re: Cheap DIY urethane motor mounts [Re: asand1]
IndyIan Offline
Loc: Ontario, Canada
Good work! I've been debating/procrastinating upgrading the torque mount in my Focus for a year now. It looks fine but allows a little too much engine movement for my taste. I should call the wreckers and get a used mount and try filling it as well.
07 Focus ZXW, 5spd manual, 131km MM F1 5W20
06 CRV, 5 spd auto AWD, 235km
#3379041 - 05/23/14 08:26 AM Re: Cheap DIY urethane motor mounts [Re: asand1]
Finklejag Offline
Loc: WA
The PT Cruiser goes through motor mounts like crazy. I have seen people on the PT forums fill in the oem mounts with stuff like this. Good job!
2010 Volkswagen GTI 2.0T
Page 1 of 3 1 2 3 >
