I don't remember my engine making noise before this last oil charge. It sound like the .5 - 1 second knock before the oil pressure builds back up. Am I imagining that it did not do this before this oil change or is it normal?
Is this a sign of a bad oil filter? If so I have a cartridge type. Can i pull it out without draining the oil? I do not want to drain the oil. Too much money in there right now.
Thanks!
Thanks!
