anybody good in theorycrafting mathematic?
by yvon_la
05/24/16 06:51 AM
Aeroshell 22 v Mobil 28
by rooflessVW
05/24/16 06:36 AM
QSAD 5W20 VOA Bottled 2/25/16
by dustyroads
05/24/16 06:29 AM
What polish/wax to apply before Collinite 845
by pennzoil_guru
05/24/16 05:46 AM
Native American Advertising
by tony1679
05/24/16 05:45 AM
Akebono ProACT ceramic pads
by dlundblad
05/24/16 04:37 AM
3D printed plastic lower receiver
by Merkava_4
05/24/16 04:19 AM
How to install an AR-15 in your F150
by Merkava_4
05/24/16 03:39 AM
12 quarts Redline 5w30 $96.00 York pa area
by spiderbypass
05/24/16 03:00 AM
Trying to prevent high mileage leaks
by twincam00
05/24/16 02:04 AM
food depot
by urrlord
05/24/16 12:13 AM
Re-surfacing original GM wheels
by HM12460
05/23/16 10:28 PM
WeekendWarrior, emily, lex73, showstopr30, any_user
57966 Registered Users
76 registered (2015_PSD, badtlc, 2009Edge, Bandito440, Al, 1foxracing, 7 invisible), 981 Guests and 124 Spiders online.
57966 Members
66 Forums
249332 Topics
Page 1 of 2 1 2 >
#3378596 - 05/22/14 06:17 PM graphene please!
yvon_la Online   embarrased
Loc: quebec canada
Any do graphene ?i know this is awsome in all the ways,the issue?oh where oh where are you graphene additive creator(oil)
Truck driver
Nissan versa note s 2014 Mobil Delvac 1 LE 5W-30 supertech st-6607(edition 2016) castrol transynd
#3378633 - 05/22/14 06:59 PM Re: graphene please! [Re: yvon_la]
Loc: quebec canada
I would take say mobil delvac 1 le 5w30 reciepe ,replace pretty much every thickner and zink (equal measure)with graphene ,and voila a nice good oil
Truck driver
#3378641 - 05/22/14 07:10 PM Re: graphene please! [Re: yvon_la]
expat Offline
Loc: Canada
Graphene is pure carbon in the form of a very thin, nearly transparent sheet, one atom thick. It is remarkably strong for its very low weight and it conducts heat and electricity with great efficiency. Wikipedia
What is your Question?
Or do you mean Graphite?
#3378705 - 05/22/14 08:27 PM Re: graphene please! [Re: yvon_la]
gathermewool Offline
Loc: New England
Two non-sensical posts in a row...
14 Forester XT
PUPPP + Subie blue filter
08 Civic LX (Auto)
VWB 5W-20 + Fram Ultra (3rd OFI)
#3378715 - 05/22/14 08:33 PM Re: graphene please! [Re: yvon_la]
andyd Offline
Loc: Marshfield , MA
I never heard of graphene, is it real? I have heard of graphite in oil. IRRC, an oil with graphite was sold back in the 70s
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3378718 - 05/22/14 08:38 PM Re: graphene please! [Re: yvon_la]
dave5358 Offline
Loc: North Bend
I had never heard of graphene until you posted. Wikipedia describes graphene here and potential applications for graphene here. Most of these applications are in electronics and science, but, nowhere is mentioned using it as an additive or friction reducer in lubrication. And, if you were to apply it to lubricants, you might start with greases or paste applications - not motor oil
Graphite comes to mind, but it has not proven useful as an oil additive, at least for the reason that it cannot take high pressures.
2006 Forester XT
2008 Corolla LE
#3378823 - 05/22/14 10:47 PM Re: graphene please! [Re: yvon_la]
Loc: quebec canada
Not sure about graphite it is size dependant !wasnt there issue with graphite a few years back.graphene is suposedly a nice natural lubricant (graphite also but quality control about size in the past were issue (or so the urban legend goes)
Truck driver
#3378825 - 05/22/14 10:52 PM Re: graphene please! [Re: yvon_la]
Loc: quebec canada
Truck driver
#3378973 - 05/23/14 06:56 AM Re: graphene please! [Re: yvon_la]
dave5358 Offline
Loc: North Bend
No, you read correctly, at least as far as it went. But you might also check this forum or the net for "graphite in motor oil". ARCO Graphite was such a product. ARCO Graphite suffered from serious agglomeration issues, clogged filters and a series of other woes. Worse, graphite simply doesn't withstand pressure, although it is frequently used in low-pressure applications such as lubricating lock mechanisms. From Wikipedia:
"The use of graphite is limited by its tendency to facilitate pitting corrosion in some stainless steel, and to promote galvanic corrosion between dissimilar metals (due to its electrical conductivity). It is also corrosive to aluminium in the presence of moisture. For this reason, the US Air Force banned its use as a lubricant in aluminium aircraft, and discouraged its use in aluminium-containing automatic weapons. Even graphite pencil marks on aluminium parts may facilitate corrosion."
Sources are cited in the Wikipedia article. Graphite is a good lubricant for certain applications, but internal engine use applications or even assembly use applications has been very limited. Molybdenum Disulfide is normally used instead - it can withstand extreme pressure and suffers from none of the limitations of graphite.
It is not clear that graphene overcomes these issues, but the proposed uses cited by Argonne Laboratories sound a lot like the existing uses for graphite.
2006 Forester XT
2008 Corolla LE
#3379078 - 05/23/14 09:05 AM Re: graphene please! [Re: yvon_la]
camelCase Offline
Loc: Southeastern, USA
Graphene is simply a single layer of graphite.
Graphite is a great lube because the vanderwalls bonds slip easily when a shear is acted on it.
Graphene is extremely strong because you're applying stress directly to the ionic/covalent bonds that make up the crystal structure.
Carbon nanotubes are simply the single layer of graphite rolled into a tube.
Graphene as an antiwear material is still in early research stages, but there is potential to use it as a spray in coating for things like cylinder linings and such.
#3379376 - 05/23/14 03:54 PM Re: graphene please! [Re: yvon_la]
alternety Offline
Loc: Pacific NW
Use IF WS2 instead. It is in the form of Bucky Baal made up of WS2 molecules. It also fractures and forms even smaller particles. It has characteristics better than pretty much any other metal lubricant (e.g, Moly).
Search this forum for more info.
There is also a Graphene like form of WS2, but I believe it is quite rare if you try to find some. There are indications it may be as good or better than IF WS2.
Edited by alternety (05/23/14 03:55 PM)
#3379482 - 05/23/14 06:28 PM Re: graphene please! [Re: yvon_la]
Loc: quebec canada
Graphene is anti-corrosion,graphite is corrosive
Truck driver
#3379483 - 05/23/14 06:30 PM Re: graphene please! [Re: yvon_la]
Loc: quebec canada
You better hope mobil doesnt sell this without certification because i will put this in my oil and not sweat one iota .
Truck driver
#3383503 - 05/28/14 08:40 PM Re: graphene please! [Re: yvon_la]
Loc: quebec canada
Truck driver
#3383506 - 05/28/14 08:43 PM Re: graphene please! [Re: yvon_la]
Joe_Power Offline
Loc: USA - Coast to Coast, Border t...
2011 Jeep Wrangler
2015 Chevrolet 2500HD LTZ
2011 Harley Davidson FLHX
Common sense is a flower that doesn't bloom in everybody's garden.
Page 1 of 2 1 2 >
