Ford Powershift Gearbox Class Action (Oz)
by hpb
05/04/16 03:50 AM
Central Mississippi automotive goods
by mjoekingz28
05/04/16 02:11 AM
Free: 5 Quart jug Peak 5W-30
by Indyvwhonda
05/04/16 01:01 AM
Subaru Oil Burning Class Action
by Bandito440
05/03/16 11:43 PM
'01 Toyota 3.0: oil to clean up sludge?
by HawkeyeScott
05/03/16 11:06 PM
What is the purpose of a 4.4 litre oil container?
by vitez
05/03/16 10:56 PM
Cut Open: Nissan OEM, Bosch D3300 & Mobil M1-110
by davison0976
05/03/16 10:38 PM
Briggs and stratton flathead?
by pdxglocker9mm
05/03/16 10:27 PM
Charcoal
by dlundblad
05/03/16 09:43 PM
2013 Dodge Dart: replace AF on miles or time?
by vitez
05/03/16 09:20 PM
Rotella T5 10w30 or QSUD 5w30
by GumbyJarvis
05/03/16 09:04 PM
People running thru red lights. You ever follow th
by motor_oil_madman
05/03/16 08:30 PM
Palmer, jessanmark16, danbee, PTT, greasy_knuckles5
57790 Registered Users
37 registered (Astro_Guy, bandz7, alcyon, car51, Bookmaker, 7 invisible), 537 Guests and 314 Spiders online.
57790 Members
66 Forums
248438 Topics
#3368972 - 05/11/14 09:31 PM Want to change from Mobil 1 - compatibity
BMW318tiCS Offline
Loc: Fort Collins, CO
Hi, I want to move away from using the M1 synthetic grease in the ball joints and u-joints of my Jeep. I don't like the way it constantly weeps out of my gun or joints. I found here that it's a lithium complex type, so I'm looking for something compatible, chemistry-wise, to switch to. Any recommendations for a quality grease that's available at common autoparts stores?
Thanks!
#3368973 - 05/11/14 09:33 PM Re: Want to change from Mobil 1 - compatibity [Re: BMW318tiCS]
artificialist Offline
Loc: Florida
I use Valvoline Durablend and never have a problem. If you want a fully synthetic grease, there is Valvoline Synpower.
You can get them at Carquest, and possibly at NAPA.
2010 Lancer Ralliart Sportback
#3368994 - 05/11/14 10:08 PM Re: Want to change from Mobil 1 - compatibity [Re: BMW318tiCS]
Rand Offline
Loc: NE,Ohio
I have noticed that about m1 grease also.. its by far the worst offender I've ever used or seen at juicing
2015 Forester I-Premium 6MT
#3369020 - 05/11/14 10:37 PM Re: Want to change from Mobil 1 - compatibity [Re: BMW318tiCS]
JHZR2 Offline
Loc: New Jersey
I've never had luck with any grease. Even some high end amsoil I had in my gun with the pressure removed ultimately separated into a big mess.
#3369034 - 05/11/14 10:58 PM Re: Want to change from Mobil 1 - compatibity [Re: BMW318tiCS]
Black_Thunder Offline
Loc: Wisconsin
I either run the Mystik brand or even the Rotella brand.
seems to stick fairly well.
I'd buy Callahan autoparts if I could.
#3369106 - 05/12/14 04:47 AM Re: Want to change from Mobil 1 - compatibity [Re: artificialist]
Char Baby Offline
Loc: Western NY
I have had the RED Mobil 1 greace and it too weeped out of my greace gun. I switched to the Valvoline Synpower grease and it looked a bit like clay, not creamy and I thought it was a bad tube. I haven't used either since.
Edited by Char Baby (05/12/14 04:48 AM)
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#3369114 - 05/12/14 05:21 AM Re: Want to change from Mobil 1 - compatibity [Re: BMW318tiCS]
NHGUY Offline
Loc: USA
I wouldn't have used M1 at all,and gone to your Chrysler dealer and ask for Mopar Multi Mileage Lube.Its long strand and contains barium .Its been around Chrysler since the 1960s anyway.
#3369163 - 05/12/14 07:25 AM Re: Want to change from Mobil 1 - compatibity [Re: BMW318tiCS]
Eddie Offline
Loc: Florida, Cape Coral
Agree that the best is the MOPAR grease. Used it since 1995 witout any problems with weaping or BALL JOINTS.
CX5 Touring 2.5L :-)
#3370216 - 05/13/14 08:28 AM Re: Want to change from Mobil 1 - compatibity [Re: BMW318tiCS]
tig1 Offline
Loc: Illinois
A good quality grease is supposed to have some seperation for the best lubrication. Here is an article from M1 on the subject.
http://www.mobil1.lt/galery/_mobil1/Tepalai/alyvos_istekejimas_is_tepalo_angl.pdf
Edited by tig1 (05/13/14 08:30 AM)
2007 Ford Fusion 179,000 miles
M1 0-20 AFE
2007 Ford Focus 153,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#3373548 - 05/16/14 06:40 PM Re: Want to change from Mobil 1 - compatibity [Re: BMW318tiCS]
SargeBB Offline
Loc: Texas
Mystik JT-6 Hi-Temp NLGI #2 is Lithium Complex, available at Wal-Mart and meets the stringent Spicer standards for U-Joints. It also meets NLGI GC-LB requirements, which means it is Nationally certified for the applications you specify. Being LC (like Mobil-1) it is certainly compatible w/the M-1. Also two other bonuses are no moly and, if you'll lock back the grease-gun handle after each use, it bleeds little, if any.
#3376607 - 05/20/14 03:34 PM Re: Want to change from Mobil 1 - compatibity [Re: BMW318tiCS]
buck91 Offline
Loc: West Michigan
Been using valvoline synpower grease in my 14oz gun for the past couple years. I take the pressure off but have stores it upright as well as flat, through summer and wintrr in the garage with little to no weeping/dripping.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
1980 Yamaha XS850G
#3377998 - 05/22/14 04:51 AM Re: Want to change from Mobil 1 - compatibity [Re: SargeBB]
Rob_Roy Offline
Loc: Northern, NY
JT-6 is arguably one of the best greases that is on the shelf in most areas. To do better you need to look at the specialty oil companies. Amsoil, LE, Schaeffers, Texas Refinery, etc.
2015 Subaru Legacy 3.6
2014 Subaru Outback 2.5
1999 Ford F350, V10 workhorse
