Originally Posted By: yvon_la
The trucking industry made a research (beats me if it was oil filter maker or trucking tho)about particulate size and according to them,if the filter cant trap visible particulate,those visible particulate are hurtfull for the engine.my own experience?i had more engine problem because of computer wire being improperly fixed and wrong coolant then because of oil particulate size.why the coolant?on the coolant front particulate did mather .we used to have silicate (pretty much sand)and that sand was literally grinding everything it could .so you ended up with sleeve with hole in them or engine block problem.no silicate fixed the issue.oil parriculate wont be an issue very long i suspect,we ll probably move to graphene instead of todays zinc,calcium,phosphore,magnesium .molybden combo
There existed an oil years ago called Arco Graphite, but it became unpopular and was discontinued not long after introduction.
