New altitude world record parachute jump
by Drew99GT
10/24/14 02:30 PM
Replacing Valve Stem Seals, Honda or Aftermarket?
by zpinch
10/24/14 02:28 PM
Saw Mercedes out testing the Concept Coupe SUV
by 01rangerxl
10/24/14 02:24 PM
high speed wipers
by hardcore302
10/24/14 01:59 PM
does one need all 4 winter tires?
by hardcore302
10/24/14 01:53 PM
Bosch Icon Wipers
by gpguy
10/24/14 01:41 PM
School shooting, near Seattle
by CourierDriver
10/24/14 01:36 PM
Crankcase Gunk Removal Idea
by Phishin
10/24/14 01:00 PM
Canadian Tire - 5L Castrol 0W40 & 5W40 - $28
by Mr_Accord
10/24/14 11:51 AM
Is radius rod same thing as sway bar
by Vikas
10/24/14 11:35 AM
window tinting: outside or inside
by friendly_jacek
10/24/14 10:11 AM
NYC police officer injured after hatchet attack.
by dave1251
10/24/14 10:11 AM
Dumy, SethTanner, mrfitz, 69P, newbull87
51678 Registered Users
110 registered (Astro14, Apollo14, A_Harman, 95MarkVIII, 12 invisible), 1860 Guests and 208 Spiders online.
51678 Members
64 Forums
221153 Topics
#3373344 - 05/16/14 02:24 PM Power Steering Fluid vrs. Hydraulic AW ISO 68
ARHND Offline
Loc: Honduras
URGENT!!!
I have a customer that insists on using Hydraulic AW ISO 68 as his Power Steering fluid in a Toyota Corolla 2000.
If somebody has a comparison, damages and problemas that could happen on doing this please.
Thanks to all of you
#3373356 - 05/16/14 02:52 PM Re: Power Steering Fluid vrs. Hydraulic AW ISO 68 [Re: ARHND]
901Memphis Offline
Loc: Northern Kentucky
Power steering systems are hydraulic systems, so it's not crazy that someone would want to use another fluid. From what I remember Toyotas aren't picky about what fluid you use as far as genuine power steering fluid vs Dexron atf, so hydraulic fluid should be fine. The viscosity of the ISO 68 is 8.5 cSt @ 100ºC.
1999 Ford Taurus 145k (Vulcan v6) - M1 High Mileage 5w30 | Fram Ultra XG 3600
2002 Buick Century 102k - PU 5w30 / Fram Ultra XG 3980 / Filter mag
#3373359 - 05/16/14 02:56 PM Re: Power Steering Fluid vrs. Hydraulic AW ISO 68 [Re: ARHND]
tinmanSC Online   content
Loc: Oswego, IL
When you are using transmission fluid (i.e. Dexron) in your power steering system, all you're really doing is using transmission fluid as hydraulic oil. Probably be no problem.
Cost of Hobby=2L
(Where L=Cost of Lubricant)
95 Lexus SC300 5-spd@200K, 2000 GS300@120K both VML Full Syn+Purolator PSL20195(soon to be Wix)
#3373368 - 05/16/14 03:06 PM Re: Power Steering Fluid vrs. Hydraulic AW ISO 68 [Re: ARHND]
901Memphis Offline
The ISO 68 is 8.5 cSt @ 100ºC like I said before and the Toyota manual calls for dexron 2 or 3. Dexron 3 has a maximum viscosity of 7.5 cSt @ 100ºC, so the ISO is marginally thicker than necessary but should be fine.
Some power steering systems are picky, like Acura/Honda but not Toyotas.
#3373438 - 05/16/14 04:34 PM Re: Power Steering Fluid vrs. Hydraulic AW ISO 68 [Re: ARHND]
JosephHarmon Offline
Loc: Eagan, Mn
Consideration is needed for operating temperature.
#3373456 - 05/16/14 05:06 PM Re: Power Steering Fluid vrs. Hydraulic AW ISO 68 [Re: ARHND]
EyesofThunder Offline
Loc: North Central Illinois
I would keep Dex II/III in there. The friction modifiers are specific for it. It might cause chatter in the steering with an unknown fluid.
Ultimately it is his car, if he asks you to do it, it is on him for issues.
Edited by EyesofThunder (05/16/14 05:08 PM)
#3373465 - 05/16/14 05:14 PM Re: Power Steering Fluid vrs. Hydraulic AW ISO 68 [Re: EyesofThunder]
Kira Offline
Loc: Champlain/Hudson Valley
Hello, Did you ask him why?
1) Got the AW ISO 68 for free or had it lying around
2) Was told to use it by a friend
3) Just a general 'know-it-aller'
Kira
#3375489 - 05/19/14 10:06 AM Re: Power Steering Fluid vrs. Hydraulic AW ISO 68 [Re: 901Memphis]
ARHND Offline
Loc: Honduras
Thanks a lot for your obswevation,
Regards
#3375491 - 05/19/14 10:08 AM Re: Power Steering Fluid vrs. Hydraulic AW ISO 68 [Re: Kira]
ARHND Offline
Loc: Honduras
He used it just because he wanted to prove that nothing happened.
Thanks
#3375501 - 05/19/14 10:14 AM Re: Power Steering Fluid vrs. Hydraulic AW ISO 68 [Re: ARHND]
ARHND Offline
Loc: Honduras
Guys is the viscosity of Power Steering 7.5 cSt? or whatg is it?
#3377378 - 05/21/14 12:59 PM Re: Power Steering Fluid vrs. Hydraulic AW ISO 68 [Re: ARHND]
MolaKule Offline
Loc: Midwest
Thanks
An event happening in the short term or long term????
If it was my shop I would not guarantee any work for him.
My bank has a service where they text me my balance every afternoon. I just don’t think they should add “LOL” to the end. smile
#3377386 - 05/21/14 01:13 PM Re: Power Steering Fluid vrs. Hydraulic AW ISO 68 [Re: ARHND]
MolaKule Offline
Loc: Midwest
http://www.bobistheoilguy.com/viscosity-charts/
An ISO 68 hydraulic oil would be slightly thicker at 8.5 cSt to 9.6 cSt verses a DexronIII-like ATF at 7.5 cSt.
While an application specific PSF, ATF, and the ISO AW 68 are all hydraulic oils, each uses a different PI (additive) package and mix of base oils.
Edited by MolaKule (05/21/14 01:21 PM)
