ACDelco X66P
by OldEuroCarLover
08/26/16 12:07 AM
FL910S C&P, 4,000 miles
by cb4017
08/26/16 12:02 AM
Mobil 1™ Full Synthetic $3.99 AR Menards
by John_K
08/25/16 10:32 PM
Causes of steering wheel shudder
by buck91
08/25/16 10:14 PM
Brand new Focus ST...
by Striker
08/25/16 09:55 PM
Chevy Volt bad idea for BITOG members!
by kohnen
08/25/16 09:22 PM
Looking for oil suggestion Chevy Express 3500 6.0L
by Goofball1205
08/25/16 08:38 PM
What ATF? 2004 Toyota Sequoia 4WD
by ShadowSix
08/25/16 08:35 PM
Tundra steering wheel
by RN89
08/25/16 08:11 PM
98-02 Corolla and Oil Consumption
by mmorri16
08/25/16 08:10 PM
How does fuel dilution affect HTHS viscosity?
by HKPolice
08/25/16 07:58 PM
Volkswagen bets big on EV(Electric Vehicle)
by HTSS_TR
08/25/16 07:50 PM
sledhead1, AtillatheHunk, Goofball1205, Djlmedic, BigHoss256
58926 Registered Users
29 registered (crinkles, bmod305, 1foxracing, Bandito440, Bud, 1 invisible), 643 Guests and 37 Spiders online.
58926 Members
66 Forums
253568 Topics
Page 3 of 3 < 1 2 3
#3344616 - 04/16/14 02:14 PM Re: Mobil 1 vs Kendall full synthetic 09 SLK55 AMG [Re: riggaz]
riggaz Offline
Loc: England
Originally Posted By: riggaz
[quote=Andyslk]I recently switch from Mobil 1 0w-40 to Kendall GT-1 Full Synthetic Euro Motor Oil 10w-30 in my AMG SLK55. I'm noticing that my engine oil is running roughly 3-4C hotter than with the mobil 1. With Mobil 1 im at 100C to 103C. Now I'm running around 103C to 106C. Does anyone know if this 3-4C difference is enough to be of concern? Should I switch back to Mobil 1?
Thanks,
Basically nothing will go bang but the 229.51 is a low saps oil, it has reduced amounts of anti wear additives in to protect diesel particle filters, it's also thinner than necessary when it's hot so will have lower film strength. To be belt and braces, i'd change it out for the correct oil.
Kendal do a 5w40 which is the one for your torque fest of an engine
http://lubeoil.com/wp-content/uploads/2012/11/Kendall-GT-1-Full-Syn-5w-40.pdf
Can you explain how 229.5 is thinner then 229.5?
Once again i think you've misunderstood what i've said
The AMG engine needs a 229.5 0w or 5w 40
The OP has put a 229.51 5w30 in
#3344868 - 04/16/14 05:43 PM Re: Mobil 1 vs Kendall full synthetic 09 SLK55 AMG [Re: riggaz]
edyvw Offline
Loc: Colorado Springs
Thanks,
OK< because you are saying 229.5 and 229.51 so I am thinking how is thinner if it is same viscosity. But, yeah I get what you saying.
13' BMW X5 35d (Valvoline 5W40 MST+ OEM filter)
11' VW Tiguan 2.0T (Castrol 0W40+OEM filter)
#3345220 - 04/17/14 03:06 AM Re: Mobil 1 vs Kendall full synthetic 09 SLK55 AMG [Re: edyvw]
riggaz Offline
Loc: England
OK< because you are saying 229.5 and 229.51 so I am thinking how is thinner if it is same viscosity. But, yeah I get what you saying. [/quote]
Yeah, you were completely wrong, again, I'll break it down for you since you are incapable of following a thread properly or reading and typing in English.
229.5 is a performance approval given to many different viscosities.
The SLK55 AMG oil has to be both 229.5 and an SAE 40 when it's hot.
Edited by riggaz (04/17/14 03:07 AM)
#3376383 - 05/20/14 10:55 AM Re: Mobil 1 vs Kendall full synthetic 09 SLK55 AMG [Re: Andyslk]
ARHND Offline
Loc: Honduras
GT-1ฎ Full Synthetic Euro Motor Oil
Kendallฎ GT-1 Full Synthetic Euro Motor Oil is a premium quality,
full-synthetic, low-SAPS engine oil designed to provide maximum
protection for European passenger cars under all operating
conditions. It also is recommended for other vehicles operating at extreme temperatures or under severe driving conditions, such as towing heavy loads. It is recommended for use in many gasoline
and light-duty diesel engines, including TDI diesel engines with
unit injectors and select diesel engines equipped with diesel
particulate filters (DPFs).
Applications
• Audi automobiles, gasoline engines (except R8 GT) and diesel
engines, standard drain only
• BMW automobiles, gasoline and diesel engines, except
M-series & Z8 with S54, S62, S65 or S85 engine
• Mercedes-Benz automobiles, diesel engines with or without
DPF (except BlueTEC engines), plus select gasoline engines
(M156, M159, M266, M270, M271, M271 EVO & M274)
• Volkswagen automobiles, gasoline engines and diesel engines,
standard drain only (includes diesel engines with or without
unit injector, and with or without DPF)
• Passenger cars, light trucks and sport utility vehicles that do
not require an ILSAC GF-5 oil for warranty coverage,
especially when operating under severe driving conditions
GT-1 Full Synthetic Euro Motor Oil meets or exceeds the
requirements of:
• API Service SN
• ACEA C3-10, A3/B4-08
GT-1 Full Synthetic Euro Motor Oil is fully approved for service fill under the following OEM specifications:
• BMW Longlife-04 Oil
• Mercedes-Benz Sheet 229.51
• VW Standard 505.01, 505.00, 502.00
Page 3 of 3 < 1 2 3
